REW subwoofer alignment Video using MiniDSP complete walk through! - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 266Likes
post #331 of 591 Old 05-14-2020, 02:18 PM
chevman's Avatar
Quoted: 95 Post(s)
Liked: 69
Originally Posted by juanchibiris View Post
I´ll look into it tonight, maybe some dB boost at 58Hz should flatten the response a little.
My crossover is at 80Hz so no need to correct anything beyond that I believe? I´m not expert also as I´m just learning, this video was a great start.
Do you think some Devastators will add to the theater?
Sorry, I am not familiar with Devastators.
Video: 65" Sony 900X XBR; Sony X800M2 Blue Ray; OTA Tivo Roamio; Apple TV 4K
Audio Electronics: Rotel Pre-amp RSP-1066, RMB-1075 120x5 Amp; Schiit Modi 2 Uber DAC; Denon 2930CI DVD; MiniDSP DDRC-88A/BM
Speakers: Klipsch Forte III, CDT-5800 II (Surround); B&K Sounds CSC-1 (Center); Dual SVS SB 3000's
chevman is offline
post #332 of 591 Old 05-14-2020, 03:50 PM - Thread Starter
cdy2179's Avatar
Quoted: 953 Post(s)
Liked: 883
You need to get familiar..
https://shop.gsgad.com/products/deva...-horn-two-pack
I plan on having two of them in my new HT which i'm about to upload one of two designs I've decided on to the YouTube channel right now.
cdy2179 is offline
post #333 of 591 Old 05-15-2020, 06:49 AM
chevman's Avatar
Quoted: 95 Post(s)
Liked: 69
Dimensions: 48.00" high, 24.75” wide, 30.00” deep (121.9cm x 62.9cm x 76.2cm) assembled.
Good googly moogly that is a big sub. I am sure it is amazing, but I am sure I would have to enjoy it outside behind the treeline behind our house because I would have about a less than zero chance of "sneaking" that one by the wife. Here I am trying to figure out how I might slip one or two more of these little SVS-SB3000's into the room and they are like a tick compared to those.
chevman is offline
post #334 of 591 Old 05-15-2020, 09:56 AM
Lesmor's Avatar
Quoted: 857 Post(s)
Liked: 390
a Google search fails to find the answer so can anyone tell me what it means when the blue light starts flashing every second on a miniDSP HD?
Lesmor is offline
post #335 of 591 Old 05-15-2020, 10:31 AM
chevman's Avatar
Quoted: 95 Post(s)
Liked: 69
while waiting on your answer, I would contact support at minidsp.com, they will respond within a day or 2. The sight also has a forum, which might include and answer to your problem as well. Good luck.
chevman is offline
post #336 of 591 Old 05-15-2020, 12:17 PM
Balbolito's Avatar
Quoted: 506 Post(s)
Liked: 901
Balbolito is offline
post #337 of 591 Old 05-15-2020, 02:04 PM
Lesmor's Avatar
Quoted: 857 Post(s)
Liked: 390
Originally Posted by Balbolito View Post
Thanks for posting I did find that post
unfortunately it mentions a blue light inside a balanced box
my light is on the outside of a unbalanced miniDSP
the light is usually steady blue
Lesmor is offline
post #338 of 591 Old 05-15-2020, 02:06 PM
Lesmor's Avatar
Quoted: 857 Post(s)
Liked: 390
I might have to do that as I cant find the answer on the forum
Lesmor is offline
post #339 of 591 Old 05-15-2020, 02:27 PM
Balbolito's Avatar
Quoted: 506 Post(s)
Liked: 901
@Lesmor did you try resetting your miniDSP?
post #340 of 591 Old 05-15-2020, 02:40 PM
Lesmor's Avatar
Quoted: 857 Post(s)
Liked: 390
Its just recently started playing up
I did try a factory reset which doesn't help
Although it showed connected it wouldn't mute my front sub
The option to synchronise popped up which I did but this results in a loud thump from the subs
that seems to fix things but then that's when the blue light starts to flash
Lesmor is offline
post #341 of 591 Old 05-15-2020, 04:39 PM
ki11abee's Avatar
Quoted: 150 Post(s)
Liked: 88
I want to get this, but im scared i would fail at knowing how to use it and get the REW software going the right way. I dont know, maybe ill still do it.
Samsung 3D UN65H7150;Yamaha RX-A2070 5.2.4 Atmos/DTS-X
Def Tech L&R Promonitor 1000 Procenter 2000 Promonitor 800 ceilings & surrounds
SVS PC13 Ultra & PC12 Plus;Monster HTS 2600MKII Power Conditioner
Oppo UDP-103 Bluray;Apple TV 4K;Harmony Elite;PlayStation 4
AC Infinity Aircom T8;MediaLight Quad Bias Light
ki11abee is offline
post #342 of 591 Old 05-15-2020, 06:09 PM
Balbolito's Avatar
Quoted: 506 Post(s)
Liked: 901
The video is amazing at explaining how to set it up. honestly i couldn't of done it without it.
Much better in my opinion than to read a huge PDF guide.
Make sure you get the 2x4HD.
Any questions just ask, you could also PM me if required.
Good luck.
lizrussspike likes this.
post #343 of 591 Old 05-15-2020, 07:44 PM
ki11abee's Avatar
Quoted: 150 Post(s)
Liked: 88
Good luck.
Thanks man. I really think i will pull the trigger and do it one of these days.
Balbolito likes this.
ki11abee is offline
post #344 of 591 Old 05-15-2020, 09:19 PM
cheyneb25's Avatar
Liked: 1
I spent weeks probably months reading forums and guides to do what's in the video. Heck I used to use a radio shack meter to take REW measurements and loaded EQ filters in a Behringer BFD with a rotary dial on the front..
First off, excellent videos sir, they have really been the best source of information for me in getting everything situated properly.
And speaking of coming a long way, I realized recently just how far i had come when I compared my setup from 3 years ago to what I'm using now. I had a single sub hooked up to my AVR, ran a 5.1 system, and barely knew how to use Audyssey - now I run 6 subs integrated into the system with a minidsp 2x4 hd, use a power amp for 5 of the base level channels in my 7.6.4 Atmos setup, and have multiple Gik panels/traps throughout it.
I know that 6 subs may seem excessive but they aren't that powerful (Bic F12's are rated for 150 watts RMS) and i have an oddly shaped room, so being able to place them at key points really helps to smooth it all out.
A friend of mine recently gave me 2 more identical subs so i'm keen to add them into the system as well and i wondered what minidsp unit would be the best for this task since my current 2x4 hd can't accurately accommodate that many subs. I've teetered between a few of their units (the 4x10, the 8x8, and the C-DSP 6x8) but I'm leaning towards going with the 2x8 kit/box and running the 10x10 Crossover v1 plug-in with it so that i can still get the max delay of 15ms and the 48kHz sample rate.
I would love to hear your thoughts on this, and if it helps to give you better perspective, i had 2 prev. posts in this thread (post # 219 and 234) that gives some more information about the room.
cheyneb25 is offline
post #345 of 591 Old 05-17-2020, 01:08 PM
RGB1's Avatar
Liked: 0
New subs or New mesurments
My setup is a modest one but would like to obtain the best from it as possible. I currently have a Living room setup as 7.2.2 all going through my Marantz sr7010. The first sub is an old Tannoy HTS, FR-6dB 29Hz-200Hz, 8" long throw driver down firing CF 50-200Hz. Sub 2 is a Tannoy TS2.8 Low F roll off -6dB 34Hz, 8" long throw side firing woofer+ 8" long throw auxiliary bass radiator, CF 50-150Hz.
I had to invert sub 1 as couldn't get any better results. both subs are at front either side of the mains. I have been looking at two new subs and have narrowed it down to Two, any thoughts as to which to purchase?.
Monitor Audio silver w12 Low f response 20hz
or
Dali E-12F- F range 28-190
Name:	sub 1 - Main seat with L and R seat.jpg
ID:	2728160   Click image for larger version
Name:	Final with EQ and filter.jpg
RGB1 is offline
post #346 of 591 Old 05-23-2020, 07:33 AM
Liked: 3
Excellent video! However, cant get pass the setting up of the mini dsp! I am sure that once I get it to work I will be able to fallow you. Hello there I am very frustrated that I cant get the mini dps hd to work. It produces no sound i have followed the instructions and so not know what to do I finally gave up. Dennon 4200, connected the rca to sub 1 out from receiver one to mini dsp. And both subs to out on dsp. Powered subs and no sound. Used rew and as output it shows dsp doesn't recognize the dennon to play the content over the avr. I can get the dap connected finally. But that is it. When I tried to produce the pink noise of 60hz over the subs nothing. Had all the crossover se to 250hz. Thanks for any help this way. This cost me over $ 300 to have it not work! Thanks in advance!
bpilot4ever is offline
post #347 of 591 Old 05-23-2020, 07:44 AM
Quoted: 347 Post(s)
Liked: 343
Make sure to have the MiniDsp set to Analog on the Control Panel, it may be set to USB, it's on the input screen, it can be overlooked as a option if not looking for it
cdy2179 likes this.
Jimmy2Shoes is online now
post #348 of 591 Old 05-23-2020, 09:34 AM - Thread Starter
cdy2179's Avatar
Quoted: 953 Post(s)
Liked: 883
As Jimmy said check that it's set to analog. Look in the description of Ep 7 and I tell you where to find the setting depending on what minidsp you're using.
Jimmy2Shoes likes this.
cdy2179 is offline
post #349 of 591 Old 05-24-2020, 08:13 AM
jacked's Avatar
Quoted: 62 Post(s)
Liked: 29
No sound from Marantz AVP
@cdy2179
This is a great tutorial and I`ve now got a 2x4 HD and REW to really dial in my 2 subs.
The problem I have before I even start is my Marantz AVP won`t play any sounds from my Windows 10 laptop on micro HDMI, every setting I can think of is checked and correct and the Marantz is the selected playback device and drivers updated etc but it won`t play any sounds on any speaker configuration. If I connect the laptop to a tv the sound / test tones work as normal but nothing through the Marantz.
I`ve tried both Java and Asio4all options on REW but still nothing, although I realise it`s not going to work if Windows 10 test tones are silent as well.
Has anyone else had an issue like this and got it sorted ?
Thanks very much.
Dave
jacked is offline
post #350 of 591 Old 05-24-2020, 08:28 AM
Killroy's Avatar
Quoted: 779 Post(s)
Liked: 763
Originally Posted by jacked View Post
@cdy2179
Thanks very much.
Dave
Is the MiniDSP 2x4 HD set to analog in the input section (left side)?
Killroy is online now
post #351 of 591 Old 05-24-2020, 08:38 AM
jacked's Avatar
Quoted: 62 Post(s)
Liked: 29
Yes that is set correct and the subs play normally, it`s getting the laptop to play any sound through the Marantz at all that was the issue.
Just got it working !
I tried HDMI in the front aux input, then one of the rear inputs and neither worked. Swapped it to another input and it started working, very odd !
Cheers,
Dave
cdy2179 and Jimmy2Shoes like this.
jacked is offline
post #352 of 591 Old 05-24-2020, 11:38 AM - Thread Starter
cdy2179's Avatar
Quoted: 953 Post(s)
Liked: 883
Cheers,
Dave
Awesome. Thanks guys for helping each other out. i wish there was a forum like this or something similar on Youtube so guys could help from the video besides just the comments section. I'm not able to spend too much time helping as this is all a side hobby and I stay so busy.
jacked and Jimmy2Shoes like this.
cdy2179 is offline
post #353 of 591 Old 05-24-2020, 11:52 AM
jacked's Avatar
Quoted: 62 Post(s)
Liked: 29
I`ve been into home theater for 25+ years and even now thought REW as being too complicated to get into, but after seeing your videos and how you explain the details, and subscribing to your channel, I`m really keen to learn more and max out my subs.
Before I got my JL subs a few years back I did make a failed attempt to build a pair of 15" subs, got the first completed and setup. It seemed to go deep but not much else, never got round to building the second sub and scrapped the idea completely.
Understanding REW and learning what you can measure with it will make a future DIY attempt an option.
Dave
jacked is offline
post #354 of 591 Old 05-24-2020, 12:08 PM - Thread Starter
cdy2179's Avatar
Quoted: 953 Post(s)
Liked: 883
Dave
And I recently did videos on designing subs in winISD as well so just follow that and you'll never buy another non DIY sub again.!
cdy2179 is offline
post #355 of 591 Old 05-24-2020, 12:17 PM
jacked's Avatar
Quoted: 62 Post(s)
Liked: 29
Yes I know that`s what I`m afraid of
cdy2179 likes this.
jacked is offline
post #356 of 591 Old 05-26-2020, 10:14 AM
RockDawg's Avatar
Quoted: 234 Post(s)
Liked: 62
It seems like most people connect the laptop (REW) to the AVR with an HDMI cable. I do not have an HDMI cable nearly long enough to do that but I do have a very long 1/8" to RCA cable. Would it be a bad idea to use that to output the test signals to my AVR?
RockDawg is offline
post #357 of 591 Old 05-26-2020, 11:24 AM
imureh's Avatar
Quoted: 3568 Post(s)
Liked: 4863
I would spend $25-30 and get a longer HDMI cable
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #358 of 591 Old 05-26-2020, 11:48 AM
muad'dib's Avatar
Quoted: 449 Post(s)
Liked: 138
Question..
I know the new beta can be used to align subs with main speakers.. Let's say at 80hz etc..
Can this same new tool be used to align just subs together?
I have 2 subs I want to align to each other, then align the 2 subs together to main speakers.
If this can work just for subs, what settings do I choose..
thanks
Sent from my SM-G986W using Tapatalk
muad'dib is online now
post #359 of 591 Old 05-26-2020, 12:20 PM
Balbolito's Avatar
Quoted: 506 Post(s)
Liked: 901
even with a 5-6ft regular HDMI cable you could sit close to your AVR. just make sure the mic is at the MLP.
post #360 of 591 Old 05-28-2020, 09:39 AM
IAmSpectre's Avatar
Quoted: 14 Post(s)
I have an odd shaped living living room with a smaller room on the one side of the back wall. It has two other openings to the living room without doors and one exterior door. I have Two sealed subs, one in the front right corner and one in the rear left corner. I have gain matched them using your video 8 and have started aligning them with this video 7. I am using a mini dsp hd and mini dsp mic. With the odd shaped room I am having difficulty getting them close to being aligned like yours are but I guess that is to be expected with the shaped of my room. So my question is, what else can I do besides using delay and inversion in the mini dsp settings to get them better aligned?
Equipment: Denon AVR-X3300W, mini DSP 2x4 HD, Front towers Pinnacle STWR12, Definitive Pro 1000 Center/ Pro 800 surround and Atmos rear, Definitive Prosub 800 x2 on Left/right channel, LFE1: PSA S3611, LFE2: PSA S3000i, Samsung Q70 75", Nvidia Shield TV
IAmSpectre is offline
