How good are JL audio subs - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By xcjago
  • 2 Post By derekmoore
post #1 of 4 Old 10-18-2019, 07:26 PM - Thread Starter
Yervais's Avatar
Quoted: 16 Post(s)
Looking into these subs... they definitely look cool.
This would be used for a large area with ambient music, it hast to play and look the part... any experiences?
Yervais is offline
post #2 of 4 Old 10-21-2019, 09:41 AM
Quoted: 349 Post(s)
Liked: 229
They are generally regarded to be very good subs.
However, they are way, way over priced from a performance to dollar ratio in comparison to other ID options. Seaton, Rythmik should be two brands at the top of your list to consider/research as alternatives since music is a priority. Also, for the money the JL F series go for, you could get into something from Funk Audio. www.funkaudio.ca These should have no problem "playing and looking the part".
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is offline
post #3 of 4 Old 10-21-2019, 12:31 PM
xcjago's Avatar
Quoted: 72 Post(s)
Liked: 68
I still think JL is the best performance for the size. But you pay a lot for that unless you go used. If you can handle a larger sub, then definitely check out Funk/Rythmik/JTR, etc...
GatoGoat likes this.
xcjago is offline
post #4 of 4 Old 10-21-2019, 02:41 PM
Quoted: 349 Post(s)
Liked: 229
JL F113 $4299 https://www.amazon.com/F113-Gloss-Fa.../dp/B00794223I
Dimension 19.25 H x 16.5W x 19.25 D
FR -3 dB at 18 Hz / 127 Hz and -10 dB at 16 Hz / 154 Hz
Very impressive for a 13.5"sub on the low end, but for one of these you could alternatively get.....
Two of these http://www.rythmikaudio.com/E15.html for ~$2750/3100 depending upon amp
Two of these http://www.rythmikaudio.com/F25.html for ~$3200
Two of these http://www.rythmikaudio.com/F18.html for ~$3500
Two of these http://www.rythmikaudio.com/G25HP.html for ~4750
One of these with slave https://seatonsound.net/product/submersivehp/ for ~3K
Or one or more of these https://www.funkaudio.ca/store/c14/Classic_Series.html
Add world class customer service on top of the 2x performance upgrade, and less or comparable cost and I know who I'd give my money to. Or who I wouldn't give it to at least.
Heide264 and GatoGoat like this.
