High output, high fidelity subwoofer - AVS Forum | Home Theater Discussions And Reviews
 13Likes
  • 5 Post By audiofan1
  • 1 Post By Soulburner
  • 1 Post By rhelliott2
  • 2 Post By ALRLIFE
  • 2 Post By ratbuddy
  • 1 Post By Ferrari_1996
  • 1 Post By darthray
post #1 of 10 Old 11-17-2019, 11:52 PM - Thread Starter
Liked: 4
I'm looking for a high output subwoofer with excellent sound quality. i prefer a passive design, but I understand they are a dying breed nowadays so I will accept other options if need be. My budget is $2,500. I prefer larger drivers in the 15" or 18" variety. Also not opposed to using a ported design if it retains fideluty with minimal port chuffing.
I probably will have to go with a dual woofer design since I don't have a lot of space. My room is 22feet wide by 16 feet deep. Thank you in advance for any suggestions.
ALRLIFE is offline
post #2 of 10 Old 11-18-2019, 12:02 AM
audiofan1's Avatar
Quoted: 2365 Post(s)
Liked: 2988
This would be the perfect choice
http://http://www.rythmikaudio.com/G25HP.html
audiofan1 is offline
post #3 of 10 Old 11-18-2019, 12:11 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1855
+1. You pretty much described the G25HP exactly.
darthray likes this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #4 of 10 Old 11-18-2019, 12:14 AM
audiofan1's Avatar
Liked: 2988
Could be the easiest recommendation ever!
post #5 of 10 Old 11-18-2019, 12:20 AM
rhelliott2's Avatar
Quoted: 219 Post(s)
Liked: 372
rhelliott2 is offline
post #6 of 10 Old 11-18-2019, 05:22 AM
eljaycanuck's Avatar
Quoted: 1952 Post(s)
Liked: 2754
DeepSeaSound Mariana 18S:
- 18" driver
- 4000W (RMS/continuous) amp
- "17-180Hz +/-0.75db (strong 10 Hz typical in-room response)"
- $2,400
eljaycanuck is offline
post #7 of 10 Old 11-19-2019, 12:39 AM - Thread Starter
Liked: 4
Thank you to everyone for your suggestions. The IPAL subs from Power Sound look have my attention at the moment.
ratbuddy and darthray like this.
ALRLIFE is offline
post #8 of 10 Old 11-19-2019, 12:00 PM
ratbuddy's Avatar
Quoted: 873 Post(s)
Liked: 1229
If you can up your budget to $3200 you'll be looking at a TV36ipal, which I can personally recommend as the both the most brutal and best sounding sub I've ever heard.
rhelliott2 and darthray like this.
ratbuddy is offline
post #9 of 10 Old 11-19-2019, 08:02 PM
Quoted: 213 Post(s)
Liked: 227
In that price range, I like Power Sound Audio's TV3612 for just $100 over your budget.
rhelliott2 likes this.
Ferrari_1996 is offline
post #10 of 10 Old 11-19-2019, 08:13 PM
darthray's Avatar
Quoted: 2337 Post(s)
Liked: 3455
And very well deserve, PSA has taken a giant step with those new driver and do have lots of support
Darth
darthray is offline
