Recommendations for dual subwoofer config? - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 2 Post By eljaycanuck
  • 2 Post By indebtbassfreak
  • 1 Post By Kini62
  • 1 Post By eljaycanuck
  • 1 Post By m0j0
post #1 of 23 Old 11-20-2019, 12:18 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
I am refreshing my TV room over Black Friday and am looking to set up a 5.2.4 configuration, mostly for movies/TV with some occasional music/video games (in that order)... and am wondering what will be the best subwoofer setup for my preferences.
To be transparent, I am already leaning towards going with a pair of RSL speedwoofers, but am open to be talked out of it . I currently own a pair that I use in a larger space (for music) and have loved them. However, I see a lot of people point to the Monoprice Monolith 10s as the best ~$500 budget HT sub and wanted to know if anyone has any experience/thoughts on using them in a dual setup vs. the RSLs... or anything else I should take a serious look at? Most of the comparisons I have seen between these two are standalone comparisons, but I feel like the RSLs really shine in dual+ (and I'm not concerned about the power rating difference... which I could understand swaying some votes for the Monolith in other cases).
The layout relative in the room will not be symmetrical (TV+seating will basically be on one side of the rectangle), so I was planning on going w/ a dual setup to mitigate that a bit and get more even bass, most likely dual 10s. The room is under 400sqft (+8' ceilings).
I am not concerned about the power difference since I know dual RSLs will have plenty of power for the space. Outside of that, the biggest thing I see in favor of the Monolith seems to be the extension. With a dual setup, how much am I losing out on by not having subs that go as deep? I have read some people claim HT audio doesn't usually go below 40hz often (with "meaning"). Also, perhaps relevant, is that the new seating will have a couple soundshakers installed. Anything else to consider between the two? (other than size/form factor, which favors RSL in my case, but that's not a deal breaker).
I really am a fan of how tight and controlled the sound from the RSLs and think that would translate really well to a lot of action scenes, etc (IE: gunshots in John Wick, etc)... and I want to keep as much of that as possible, but not clear on what I could be leaving on the table (a bit more bottom end, etc?). I have owned/liked others subs that extend deeper on paper (IE: LFM-1 EX, etc), but (IMO) didn't sound as good/clean as the RSLs... and the RSLs have no problem shaking the walls when it is called for.
FWIW, I will be testing some movie content on the RSLs shortly, but because the final setup will be completely different, I wanted to get some other thoughts before I commit to anything.
TL;DR; Comparing and contrasting dual RSLs vs Monolith 10s (ignoring RMS power), primarily for HT, in 400sqft room... and others to consider?
Koeikan is offline
post #2 of 23 Old 11-20-2019, 12:22 PM
eljaycanuck's Avatar
Quoted: 1952 Post(s)
Liked: 2754
IMO it's dual Monolith 10" over dual Speedwoofer 10S, no question. The Monoliths will have much greater overall output, significantly better extension, their THX certification means they should sound just as tight and controlled" as the RSLs, and they offer ported/sealed tuning flexibility.
eljaycanuck is online now
post #3 of 23 Old 11-20-2019, 12:23 PM
indebtbassfreak's Avatar
Quoted: 1487 Post(s)
Liked: 2881
The RSL is a good performing punchy sub,,, but they fall off pretty hard below 30Hz. The Monolith 10 will not only have at least as good of sound quality but will dig much deeper. For movies that often these days play well below 30Hz i know what my choice would be.
eljaycanuck and basshead81 like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #4 of 23 Old 11-20-2019, 12:34 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
Thanks for the replies.
So the Monoliths really are that good?
I know the RSLs are a couple years old, but I have viewed them as a budget competition killer (in their areas of strength). Though, I am not concerned about the output between the two. Are the monoliths as punchy/controlled in that >30hz range?
I guess another part of what I'm wondering is how important is it that a subwoofer can hit subsonic levels (how much of it impacts the sound vs. feeling the sound and/or just hearing reverberation, etc)? ...and if that is partially mitigated with soundshakers/buttkickers/etc.
Can the Monoliths hang with the RSLs in musicality/control?
EDIT: also, any info w/r/t what is required for THX sub certification? Poking around online, but having a hard time locating info that isn't really dated, beyond that it means extending down to 20hz.
Koeikan is offline
post #5 of 23 Old 11-20-2019, 12:41 PM
Liked: 2881
Pretty much every post i've read on the three different Monoliths 10/12/15" subs have indicated yes that they are very good performing subs that have low distortion and are clean sounding. Add to that deeper extension and it becomes a two-fer lol. Once you get into a sub that can hit 20Hz it brings a whole new and better movie experience especially when delivered with low distortion. Just adds weight to those scenes where those frequencies are.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #6 of 23 Old 11-20-2019, 12:45 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
Thanks... and I assume people generally recommend the ported version for HT, but would sealed make more sense considering I am not concerned about output in this space?
Koeikan is offline
post #7 of 23 Old 11-20-2019, 12:47 PM
m0j0's Avatar
Quoted: 752 Post(s)
Liked: 820
I currently have two Monolith 10's in my HT and yes, they are pretty amazing. I did have a Monolith 15 in the room but the amp went bad so I threw the two 10's in there and they really fill the room (and several others) with bass during movies, but are always controlled and clean. Those two coupled with my BOSS mini riser makes watching movies a real experience!
m0j0 is online now
post #8 of 23 Old 11-20-2019, 12:50 PM
drh3b's Avatar
Quoted: 2108 Post(s)
Liked: 4261
No. The Monoliths are supposed to have a very clean sound, almost Rythmik like from what I've seen(not heard them myself). The ported will just have more energy for blockbuster action flicks.
My World Beating System!
Spoiler!
drh3b is offline
post #9 of 23 Old 11-20-2019, 12:57 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
I am not sure more energy is what I would prefer. In general, I have been under the impression sealed subs have a cleaner and more controlled sound (where other factors are the same) and that the main drawback for sealed was that they aren't as power efficient w/r/t output and that ported subs have more potential to sound 'boomy' (or 'sloppy'... but that might be too strong of a word). Is that line of thinking off in this context?
Koeikan is offline
post #10 of 23 Old 11-20-2019, 01:02 PM
bjaurelio's Avatar
Quoted: 171 Post(s)
Liked: 99
If you have about a $1k budget for two subs, I highly recommend going the DIY route. Get two of the 18" ultimax subwoofers with flat packs. They're easy to assemble. You can run both off a single amp with DSP. Given your budget, you should be able to get a Crown or QSC instead of the budget Behringers. Given the high xmax, you can easily make those flat down to 15-20Hz with DSP. The lower extension you go, the lower your overall headroom, but with two of these monsters, you will have plenty of output.
bjaurelio is offline
post #11 of 23 Old 11-20-2019, 01:04 PM
Liked: 2881
Modern ported subs have come a long way for many reasons including driver technology and design. The Monolith 10 will be very articulate for music and movies. But will have the ability to perform better under 35Hz for movies. This doesnot mean any increased boomyness which most of the time is caused by poor set up. It is one of the best $500 subs you can buy short of DIY.
I have a pair of one of the very best "sealed" subs you can buy period,, and have just placed my order for two "ported" from the same company. I've always been a sealed guy but ported has come a long way!!
drh3b and Koeikan like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #12 of 23 Old 11-20-2019, 01:10 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
I like the way you think, but I think this would be overkill for my needs . While the room is a bit under 400sqft, I'm only using about half of that for the TV/seating/speakers.
Power/output is not a concern for me. I would definitely prioritize SQ > SPL since I'm expecting output to be sufficient with any decent dual sub purchase.
Koeikan is offline
post #13 of 23 Old 11-20-2019, 01:10 PM
Kini62's Avatar
Quoted: 2760 Post(s)
Liked: 2611
You're currently using ported subs and seem to be quite satisfied with them. If anything the Monoliths will have less distortion and sound "cleaner" than the RSLs. Plus you can always plug the port and run it as a sealed sub if you want.
Koeikan likes this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #14 of 23 Old 11-20-2019, 01:23 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
Very true, but I also don't have a sealed RSL to compare it against . Plus, I was taking size into account as well. Something on the smaller side give me more placement flexibility.
Koeikan is offline
post #15 of 23 Old 11-20-2019, 01:29 PM
Liked: 2754
OP, your resistance to the strong case being made for the Monolith 10" over the Speedwoofer 10S suggests that you'd really just rather have a pair of 10S. Assuming that this is the case, IMO you should go with the 10S and enjoy.
post #16 of 23 Old 11-20-2019, 01:30 PM
bjaurelio's Avatar
Quoted: 171 Post(s)
Liked: 99
If it's overkill, save a couple hundred bucks and go with the 15" subs. I have a 15" sealed, and with DSP on my Behringer amp gives me flat extension below 20Hz with the SQ benefits of sealed. If the subs are for HT, you want the extra extension that a 10" simply won't provide.
post #17 of 23 Old 11-20-2019, 01:33 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
It's more the comfort of the known vs. the concern of the unknown... but if you look at posts after the first one, I don't know if it's fair to say I was resisting... just a couple follow up questions and then questions about ported vs. sealed w/r/t the Monoliths...
...like I said at the start, I'm open to be talked out of the RSLs... just not blindly .
Koeikan is offline
post #18 of 23 Old 11-20-2019, 01:41 PM
Liked: 2754
I understand the reluctance, but since no-one is championing the RSLs it seems odd not to let that option go.
Anyway, I apologize if I've misunderstood where you're coming from on this, and since I've said my piece I'll politely bow out of this thread.
Whatever subs you end up with, I sincerely hope they make you happy.
Koeikan likes this.
post #19 of 23 Old 11-20-2019, 03:28 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
Just throwing it out there, but would dual Monolith 12s in a <200sqft (<1600cf) viewing area set in a <400sqft (<3000cf) room be a waste/insane?
After looking at some more reviews/charts, it seems like the RSLs excel at the lower mid bass punch that I really enjoy and the M10s are a touch weak in that area (but have better extension)... the M12s seem to be strong in both areas, based on what I've since read.
If I had to choose, I think I would definitely prefer the punch over rumble (as a generalization, to a degree)... and would prefer to keep the costs down to a reasonable amount (waiting on BF deals either way), but is this overkill if I'm not looking to blow out my windows/eardrums .
...or might I be best served plugging up one or both of the Monolith 10s to improve mid-bass punch at the cost of some extension output?
(If you haven't noticed, I can suffer from some paralysis by analysis ...)
Koeikan is offline
post #20 of 23 Old 11-20-2019, 03:37 PM
m0j0's Avatar
Quoted: 752 Post(s)
Liked: 820
Going with the 12's definitely wouldn't be a waste, as having multiple subs will provide better frequency response but will share in the load in terms of the overall calibrated SPL for LFE.
Koeikan likes this.
m0j0 is online now
post #21 of 23 Old 11-20-2019, 03:40 PM
Quoted: 31 Post(s)
Go with 15 inch subs . Nothing lower
Bellaseni is offline
post #22 of 23 Old 11-20-2019, 04:03 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
Ya'll are crazy .
I mean that in a good way, but for context, I should probably mention I had an Outlaw LFM-1 EX sub in the room before (which has since been repurposed in an office) and usually didn't find that was particularly lacking in output for my typical listening levels... but SQ/punch and more consistent frequency response (based on location in room) are the main areas I am looking to improve.
I certainly won't mind having some more output as well, but I think dual 15s is really going to be more than I need... and probably would have a much harder time placing them without taking over the room (aesthetically, etc), unless sealed.
Koeikan is offline
post #23 of 23 Old 11-24-2019, 01:12 PM - Thread Starter
Koeikan's Avatar
Quoted: 20 Post(s)
JFYI for anyone following this or may stumble on it later... but tested some movie/HT content on my 2.2 setup with the RSLs and now better understand why people were steering me away from them for my 5.2.4 setup.
While I love them for music, the drop off for the dual RSLs is much more apparent watching movies. Comparing the RSLs against just one LFM-1 Ex and it was clear what they were missing (even though for music, I much prefer the RSLs).
Anyway, I'll be targeting the Monolith 12s over BF... unless there is some other crazy BF deal that makes me think twice (I'll be keeping an eye on SVS/HSU/PSA/etc as well).
Koeikan is offline
