WHATCHATHINK? Sub(s) for MUSIC only, $400 max - AVS Forum | Home Theater Discussions And Reviews
 60Likes
post #1 of 84 Old 11-27-2019, 03:57 PM - Thread Starter
Zorba922's Avatar
Quoted: 7763 Post(s)
Liked: 5880
This is for a 2 channel, music-only living room setup. Philharmonic BMRs, listed as 34Hz at +/- 2db roll-off. However, they are only 85db sensitivity and I'm powering them with a Pioneer LX502 which is a class D3 receiver with 120wpc...probably would be better off with an external amp to get the most out of them.
Right now the BMRs sound good, but don't have as much bass authority/presence as I would like...I don't listen to truly bass-intensive genres like hip-hop, house, techno, etc. though...mostly jazz, classical, and some acoustic/alternative rock now and then.
So, I am considering these options:
  • 2 x Sony Core subs, $200 shipped on sale
  • 1 x SVS SB12 on sale for $400 shipped
  • 1 x RSL Speedwoofer 10 regularly priced at $400 shipped
Now obviously the SB12 is the best performing (I think---correct me if I'm wrong) but am wondering if the RSL would have higher output due to its front ported design vs the SB12's sealed design.
The Sony Core subs are definitely weaker (115watts) but having two of them, positioned next to my 2 speakers, should provide a more even (flatter) frequency response, from what I've been reading. (In the best of all possible worlds I would be able to buy 2 x SB12 of course, lol.)
If I got the SVS or RSL subs I was thinking of nearfield placement to maximize output.
So, one strong sub in nearfield, or two much weaker subs by the mains? Or would the SVS or RSL be enough if corner-loaded, next to the FL speaker?
(See attached photo.)
Name:	Room diagram.jpg
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #2 of 84 Old 11-27-2019, 04:09 PM
WLDock's Avatar
Quoted: 189 Post(s)
Liked: 215
For music, get the SVS and be done. Or save a little and get a Rythmik.
http://www.rythmikaudio.com/clearance.html
Sent from my Pixel 3a using Tapatalk
HDTV - Sharp AQUOS LC-70LE600U 70" | AVR- Anthem MRX 300 | Media Player - Fire TV Box 2nd Gen | Blu-Ray/Media/Gaming - PS3-320GB / Xbox One
Speakers - Main - Boston Acoustics Lynnfield VR965 | Center - Boston Acoustics Lynnfield VR920 | Rear - Artison Portrait LRS
| Sub - DIY Stereo Integrity HT 15 | Sub Amp - O Audio BASH 500
WLDock is offline
post #3 of 84 Old 11-27-2019, 04:19 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
I would go with dual JBL 550P’s for less than $400 shipped 😊
My humble main system:
Vizio M75-E1; Oppo 203 universal UHD player; Denon 4300H AVR, Dual PSA S1801's; Monitor Audio Silver RX-6 mains, RX center, and RX surrounds; one pair NHT mini Atmos speakers; Home-built HTPC (Xeon E1230, 16gb RAM, Crucial M500 480gb SSD, GeForce 980Ti, Corsair CX600, CoolerMaster mini-ITX case); Roku Premiere+; Amazon 4K Fire TV
sk373 is online now
post #4 of 84 Old 11-27-2019, 04:22 PM
Quoted: 442 Post(s)
Liked: 240
Dont cheap out too much on sub(s), its much better to not use a sub than to use one or two bad ones. Also placement, next to the speakers may not be the best even if two.
Leeliemix is online now
post #5 of 84 Old 11-27-2019, 04:49 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Really? I thought that's the ideal for music.
Zorba922 is offline
post #6 of 84 Old 11-27-2019, 04:52 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Do you think a single SB12 would be enough for my space? Would nearfield be an absolute necessity?
Zorba922 is offline
post #7 of 84 Old 11-27-2019, 04:57 PM
Quoted: 442 Post(s)
Liked: 240
I assume this is placement related, same rules apply to music and home theater for sub placement, unless for some reason its crossed over very high but you wont do that so. There can be one difference, some place sub in HT for max output like in a corner but mostly the sub(s) should be placed optimally for an even frequency response.
post #8 of 84 Old 11-27-2019, 05:00 PM
eljaycanuck's Avatar
Quoted: 1994 Post(s)
Liked: 2832
eljaycanuck is offline
post #9 of 84 Old 11-27-2019, 05:04 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Originally Posted by eljaycanuck View Post
SB12-NSD ftw.
The simplicity of a single sub is very tempting, just wondering about sufficient output in my space since it's basically open plan.
Zorba922 is offline
post #10 of 84 Old 11-27-2019, 05:05 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Well, it's a living room so my placement options are very limited...wish I had the liberty of using a subwoofer crawl to pick the optimal spot but I don't.
Zorba922 is offline
post #11 of 84 Old 11-27-2019, 05:07 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
I am going to reiterate my recommendation of dual JBL 550P’s. At the sale price of $189 each shipped, the 550P is unbeatable—it offers SB12 class performance for less than half the price.
christoofar, bear123 and drh3b like this.
sk373 is online now
post #12 of 84 Old 11-27-2019, 05:08 PM
Liked: 2832
You mentioned that you "don't listen to truly bass-intensive genres like hip-hop, house, techno, etc. though...mostly jazz, classical, and some acoustic/alternative rock now and then". Sounds like you mostly just need a more robust bottom end. IMO the SB12 should do the trick.
post #13 of 84 Old 11-27-2019, 05:15 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Thanks, am leaning that way right now...they are backordered until 12/14 which also gives me a little breathing space.
sk373 likes this.
Zorba922 is offline
post #14 of 84 Old 11-27-2019, 05:35 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Well, just got off the phone with SVS. They said 2 x SB12 would produce "just moderate" output given my room dimensions, so one would definitely not suffice even in nearfield placement.
Hmm, another possibility would be to order one for my media room and move the RBH I-12 I currently have there into the living room...the media room is really quite small for the I-12, maybe 12 x 12 tops.
Zorba922 is offline
post #15 of 84 Old 11-27-2019, 05:39 PM
Liked: 2832
Well, just got off the phone with SVS. They said 2 x SB12 would produce "just moderate" output given my room dimensions, so one would definitely not suffice even in nearfield placement. ...
I'm surprised they'd say that but, then again, what constitutes "sufficient output" is entirely subjective.
(FWI(subjectively)W: I recall demo-ing a single Energy S10.3 - 200W RMS, 21Hz +/-3dB - in my ~3,400 cu.ft. basement HT space and I was pleasantly surprised by what it added to the bottom end.)
post #16 of 84 Old 11-27-2019, 05:40 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Yeah, that's true.
That's why there's a part of me that simply wants to try out a pair of those ridiculously cheap $98 Sony Core subs.
Zorba922 is offline
post #17 of 84 Old 11-27-2019, 05:57 PM
Quoted: 1895 Post(s)
Liked: 1504
DIY out of your options Zorba?
Also the larger surface area of the SB12 should lead to more output than the Speedwoofer 10S, and even though there is the roll-off down low of the sealed sub, it should be DSP’ed so it’s flat to 18hz or so where they measured the F3 point.
Zorba922 likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #18 of 84 Old 11-27-2019, 09:46 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
I think you would be fine. I don’t think they were really taking your application into consideration. Yes, the subs will see the entire room—but you are not using them in a HT application.
IMHO, a pair of SB12’s or 550P’s would be a very good match with your BMR’s. I don’t reckon that your BMR’s would go much past 105 dB at max. The SB12 is capable of 101 dB @ 31.5 Hz and 104 dB @ 40 Hz (CEA 2010). That’s an outdoor ground plane measurement from data-bass. Of course, the SB12 is not an output monster, but I don’t think you’re looking for that.
sk373 is online now
post #19 of 84 Old 11-27-2019, 11:09 PM
RayGuy's Avatar
Quoted: 3107 Post(s)
Liked: 2898
SB12 has been criticized as a bit wimpy, so I would avoid that selection in that size room. As to one good sub or two lesser subs, one good sub is always the preferred method. You can always add one later, if you find the one does not fill out the room well. Frankly, if it were me, I would not pair those speakers with cheap subs, as they would just end up dragging the overall performance down to the sub's level.
Rythmik L12 or the ported LV12-R would be my selection for music reproduction. Yeah, a few more bucks than you want to spend, but worth it, even if you have to wait. However, if the wife will divorce you if you go over $400, then go with the RSL.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #20 of 84 Old 11-28-2019, 07:47 AM
bear123's Avatar
Quoted: 2960 Post(s)
Liked: 4506
You have very high quality speakers...I wouldn't pair them with a bargain budget sub. The SB12 is pretty much the lowest output sub ever tested on data-bass...which means fine for a small room or modest listening levels.
I agree, save just a little more and get a nice Rythmik sub. Add another some day if you feel the need. Although your room placement options may be limited, I believe your objective is to get the best sound quality. In order to accomplish this, I would strongly recommend getting a Umik-1 mic from MiniDSP, download REW, and measure your response. This will help tremendously with properly integrating your sub(s) with the speakers. Its a nice, very long term investment as well for the audio hobbyist as it is something you can always use over the years to tinker or improve things.
Placement options are often limited due to real life, room layout, etc. But I have found that when people in search of the best sound quality possible measure and find they have a dreadful response in the low frequencies with large dips or nulls, it becomes a bit easier to work on finding better placement. Or you might find that where you want to put the sub works well, and measuring simply helps dial things in better.
Good luck!
bear123 is online now
post #21 of 84 Old 11-28-2019, 11:42 AM
sivadselim's Avatar
Quoted: 510 Post(s)
Liked: 437
Are you (or anyone else) familiar with this sub?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #22 of 84 Old 11-28-2019, 12:03 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
Yes, there have been several threads over the years regarding the 550P, both here and on other audio sites. At the sale price of $189 there is absolutely nothing that touches it—again, it has comparable performance to the SB12. It’s overpriced at full retail ($599), but a complete steal @ $189. I have yet to see anyone that is not pleased with its performance.
The SB12 extends a bit lower than the 550P (23 Hz vs 27 Hz), but that’s not particularly important for a music only system. The 550P is a sealed design, like the SB12. The SB12 has a 12” driver, while the 550P has a 10” driver, but the 550P has a bigger and heavier cabinet.
sivadselim likes this.
sk373 is online now
post #23 of 84 Old 11-28-2019, 12:33 PM
sivadselim's Avatar
Quoted: 510 Post(s)
Liked: 437
*following
I'm kinda looking for the same thing. Mostly music. ~$400 give or take a hundred or so.
I'd add the Polk HTS 12 to your list. $320 at both Best Buy and Amazon right now:
https://www.bestbuy.com/site/polk-au...?skuId=6170709
https://www.amazon.com/Polk-Audio-Su...tronics&sr=1-3
And the Polk HTS 10 is $220:
https://www.bestbuy.com/site/polk-au...?skuId=6170705
post #24 of 84 Old 11-28-2019, 01:53 PM
Quoted: 97 Post(s)
Liked: 111
It’s hard to argue with dual JBL 550P for sub $400 in a music only system.
Mocs123 and sk373 like this.
Epson 5040 UB ; 120 inch Elite Cinewhite 1.1 gain 16:9
XBOX One S ; Denon X3300W
(4) KEF Q100 ; Q200C ; (2) SVS Prime Elevation ; HSU VTF3 MK3 (5.1.2)
Category5 is offline
post #25 of 84 Old 11-28-2019, 02:01 PM
Mocs123's Avatar
Quoted: 330 Post(s)
Liked: 178
I haven't heard them but from what I hear, this would be the best combo in your budget for music.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #26 of 84 Old 11-28-2019, 03:12 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
Thanks for all the feedback, guys. I pulled the trigger on a pair of the 550s yesterday. JBL lists them as "backordered until 12/14" so I'll post my impressions then. Am hoping I won't have to use their free return shipping, since these things weigh 50lbs each!
Actually I plan to take one out of the box and see if it suffices by itself before opening the second box, so we'll see... Another forumite, Geoff @gajCA swears that he's quite happy with just a pair of cheap Yamaha 8" subs in his music setup (even cheaper/smaller than the Sony Core subs!) ... which is what got me wondering about the Sonys.
Also, I plan to compare the performance of my RBH I-12 by itself in the LR vs 1 or 2 of the JBLs...who knows I might end up keeping the RBH there, moving one of the JBLs to the small media room, and sending back the second JBL. Choices, choices...we're lucky to have such first world problems!
sk373, WLDock, bear123 and 2 others like this.
Zorba922 is offline
post #27 of 84 Old 11-28-2019, 05:22 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
yeah...am lacking the tools, skills, and non-laziness.
christoofar, sk373 and drh3b like this.
Zorba922 is offline
post #28 of 84 Old 11-28-2019, 05:22 PM
basshead81's Avatar
Quoted: 350 Post(s)
Liked: 10079
I would of went with the SB12NSD. I had a couple JBL ES250 12" subs that I used with my Touch tunes juke boxes and the amps didn't last. I have had much better luck with Polk subs on the lower tier products. SVS also gives you much better product support and warranty.
Far as performance, my experience is that the SB12 it produces a bit more output then Data-bass.com outdoor testing shows placed in room. I am using one in my den which is not that large(10x12x8) but it is open to larger spaces.
basshead81 is offline
post #29 of 84 Old 11-28-2019, 06:41 PM
WLDock's Avatar
Quoted: 189 Post(s)
Liked: 215
I was going to say get those and the SVS if you could to compare. However, two subs will give you more coverage. I hope they work out for you.
Interesting thread here: https://forums.audioholics.com/forum...review.108994/
WLDock is offline
post #30 of 84 Old 11-28-2019, 08:38 PM - Thread Starter
Zorba922's Avatar
Liked: 5880
https://www.youtube.com/watch?v=vEd8SGJJGHU
Yeah, I have read a few anecdotes of people having issues with the JBL sub amps, which is somewhat surprising in the case of the 550p since it's a class D amp which should be more durable.
Am curious, how hard do you push your subs? I will be using mine mainly for bass presence than any real slammin' and jammin' so I am keeping my fingers crossed this will prolong their lifespan.
Also, how close do you sit to your SB12? It looks like a desktop setup so you're in nearfield position?
Zorba922 is offline
