Atlantic Technology 262 PBM crackle sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-30-2019, 06:05 PM - Thread Starter
fox1541's Avatar
Quoted: 50 Post(s)
I'm not sure what's going on with this and I'm not exactly sure how to describe it.
It doesn't seem blown since most of the time it sounds good (even at high volumes there is good clean bass)
Every once in a while I'll get a crackle sound when it's trying to play the bass. This can be at any volume.
Is this a bad speaker or something else?
If it is a bad speaker, would I be better off replacing just the speaker or getting something else?
Here are the specs of the sub
262 PBM
Driver 12"
Output Power: 150W
Distortion (Amplifier) 0.05% max
Freq. Response (+- 3 dB) 35Hz – low pass filter setting up to 125Hz
Input Impedence
High Level (Speaker) 10kΩ
Low Level (Line) . 1kΩ
Peak SPL . 105dB
Dimensions . 19.75 x 14.75 x 13.75in 502x375x350mm
Weight 53lbs/117kg
Power Requirements: 120V AC 50/60Hz 240V AC 50/60Hz
TV: Vizio P75-F1 (2018) AVR: Yamaha RX-V683
Speakers: Polk S60 Towers / S35 Center / S20 Bookshelf Speakers / Atlantic Technology 262 PBM Sub
TV: 55LW5600 (mfg date 3/11) AVR: Pioneer VSX-45
fox1541 is offline
post #2 of 6 Old 11-30-2019, 09:40 PM
The_Nephilim1's Avatar
Quoted: 141 Post(s)
Liked: 36
Hi, Are you using the sub for Movies or music??
My Humble HT: Integra 40.3 Audyssey Calibrated / Denon 1930Ci SACD/DVD-A Player / Sony 3600 3D blu Ray / Behringer iNuke 3000DSP / Mach 5 IXL 18.4 Subwoofer / Optoma HD142x 3D REady 1080P DLP Projector / 92" 16:9 Manual screen / miniDSP HD2x4
The_Nephilim1 is offline
post #3 of 6 Old 12-01-2019, 10:21 AM - Thread Starter
fox1541's Avatar
Quoted: 50 Post(s)
This is mostly for Movies.
The sub is from my family room speaker set but I moved it to the main Movie watching room.
The rest of the set is Polk (as shown in my sig)
fox1541 is offline
post #4 of 6 Old 12-01-2019, 05:15 PM
Quoted: 141 Post(s)
Liked: 36
Well maybe you can run some test tones on the sub and see what frequency it happens at.. it could be a blown driver or loose object in the sub?
post #5 of 6 Old 12-01-2019, 05:27 PM
Oledurt's Avatar
Quoted: 443 Post(s)
Liked: 583
Look into something called tinsel slap. There is a wire that attaches to the spider which is under the cone. Sometimes it can come unglued and slap the back of the woofer cone causing a rattling or cracking sound. If it is that it’s super easy to fix. You’re going to need to remove the woofer and inspect it to find out.
Oledurt is offline
post #6 of 6 Old 12-21-2019, 10:49 AM - Thread Starter
fox1541's Avatar
Quoted: 50 Post(s)
I checked the items mentioned but didn't find anything obvious.
This sub is pretty old so I've been looking at replacing it.
I'm considering the Polk HTS12 and the reviews seem mixed. What are some thoughts?
My room is about 11' x 11' and my speakers are listed in my signature.
fox1541 is offline
