It has arrived !!!!! - AVS Forum | Home Theater Discussions And Reviews
 15Likes
  • 8 Post By JMR74
  • 2 Post By osu fan
  • 4 Post By bobknavs
  • 1 Post By indebtbassfreak
post #1 of 7 Old 12-02-2019, 09:53 AM - Thread Starter
Liked: 8
JMR74 is offline
post #2 of 7 Old 12-02-2019, 10:27 AM
osu fan's Avatar
Quoted: 55 Post(s)
Liked: 106
Congrats. Get that box opened,let's go!!
audiofan1 and indebtbassfreak like this.
Video Samsung UN65KS8000, Sony UBP-UX80
Audio Denon X4500H, PSA MTM-210T, MTM-210C, MT-110 X2, SVS PB12NSD & SVS PB1-ISD
osu fan is offline
post #3 of 7 Old 12-02-2019, 11:34 AM
bobknavs's Avatar
Quoted: 2504 Post(s)
Liked: 1780
Great.
95 lbs.
I suggest the following, especially if you're working without help, and are as wimpy as me:
Carefully turn the box upside down.
Open the bottom.
Carefully turn it right-side up again.
Lift the box off the sub.
(Bob's your uncle.)
Have a small rug or large towel handy, to place under it to make it easier to drag around. Hsu recommends that. (Its rubber feet make that difficult otherwise.)
If you're rugged enough to manhandle it around safely, more power to you.
bobknavs is online now
post #4 of 7 Old 12-02-2019, 12:02 PM
indebtbassfreak's Avatar
Quoted: 1515 Post(s)
Liked: 2919
Been a couple hours,,,,,,,,,,,,Update!!!!!!!
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #5 of 7 Old 12-07-2019, 12:32 PM - Thread Starter
Liked: 8
So far so good, though im limited for space still.
I have both the PSA and HSU in the front listening position, placed on the outsides of my front speakers and i can feel the deep low bass, which is what i was looking for . though i had to move both subs back in due to people coming in for holidays... and now the sound is not as deep...and thats moving it just 2ft..
JMR74 is offline
post #6 of 7 Old 12-07-2019, 01:00 PM
Liked: 2919
Good to hear. Once holidays are over you can fine tune sub placement and let er rip,,,, and yes one or two feet in any direction can make a huge difference in performance.
darthray likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #7 of 7 Old 12-07-2019, 01:32 PM
jasonwc07's Avatar
Quoted: 91 Post(s)
Liked: 126
Originally Posted by bobknavs View Post
Great.
95 lbs.
Open the bottom.
(Bob's your uncle.)
The manual says the MK2 is 95 lbs but the website says 110 lbs. I wonder which is correct. I figured the 110 lbs might refer to gross weight with packaging but when I called and asked, they said the package would actually be 125 lbs (33"x24"x33").
jasonwc07 is offline
