SVS PB-12NSD vs PB2000? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By promtber
  • 1 Post By eljaycanuck
post #1 of 6 Old 12-03-2019, 04:47 AM - Thread Starter
Liked: 1
Any real huge difference in the two for the extra $300? I’m more of a movie guy with some music. Going in a 20x20 room, replacing a Paradigm PDR 10 that’s about 10 plus years old. Amp is going to be a Denon 4500z
promtber is offline
post #2 of 6 Old 12-03-2019, 05:15 AM
eljaycanuck's Avatar
Quoted: 1953 Post(s)
Liked: 2763
The PB-2000 has an extra 100W (RMS) so it should have a bit more overall output and maybe slightly stronger sub-20Hz response but, IMO, not enough to merit the $300 premium over the PB12 (which will be a significant upgrade over the PDR-10).
eljaycanuck is offline
post #3 of 6 Old 12-03-2019, 05:21 AM - Thread Starter
Liked: 1
Just what I wanted to hear. If I don’t like it I can always upgrade or just get two.
eljaycanuck likes this.
promtber is offline
post #4 of 6 Old 12-03-2019, 06:37 AM
Quoted: 609 Post(s)
Liked: 346
I thought the PB2000 averaged 3db more ? thats pretty significant but then again there's stiff competition at that price point which makes the PB12 or TWO a much better value
Speakers: KEF Q100, Q300, Q750, Q650C / Fluance Signature Series, SX6, XL5F/ Mirage M-190 / DCM TP160S-CH Subwoofers: Outlaw Ultra X12 (x2) / BIC H100-II
Receiver: Denon AVR-X4500H, AVR-X1400H Integrated Amplifier: Yamaha A-S501/ Fosi Audio TPA3116 mini amp Extras: MiniDSP Umik-1 Amplifier: Emotiva BasX-A300
macgallant is offline
post #5 of 6 Old 12-03-2019, 06:43 AM
Liked: 2763
FWIW, according to basshead81's comments in a couple of threads including this one:
… The PB2000 has 2.5db more output above 25hz and a shallower roll off below port tune so it extends deeper. The PB12-NSD had a very steep 48db per octave filter. Both are still great subs, but at 499.00 the PB12 is a better deal. …
basshead81 likes this.
post #6 of 6 Old 12-04-2019, 04:21 AM
MIX_MASTER_ICE's Avatar
Quoted: 2676 Post(s)
Liked: 2484
FWIW, I had both the PB-2000 and PB12-NSD in a 2700 ft^3 room and the difference in the two subs was minimal. I think in a larger room the PB-2000 would allow for some additional output potential, but depending on how you run your sub(s) it may not be worth a $300 additional cost. I would rather opt for going dual PB12's.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. SIVGA SV004. SA HDTwo. HyperX CloudPS4. TB Elite AtlasAero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
