Anybody know the trick to opening up a Klipsch Sub 12 HBG?
My kids managed to break off the center conductor of the line in cable, inside the connector.
I took out the dozen or so screws around the plate, and can lift it up about 1/4 to 1/2 inch...which is not enough to do any work.
Do I need to remove the speaker and go in that way?
