Subs behind the couch? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-09-2019, 08:21 PM - Thread Starter
Quoted: 92 Post(s)
Liked: 4
I’m trying to clean up our basement (3 young kids running around) and was considering selling my two SVS 12” ported subs for two 12” sealed subs. My reason for doing so is because they would then fit in the space between the theater couch and wall (and I don’t have to worry about the kids climbing on them, running into them, etc.). My primary use is movies, tv, sports with a little music. I know sealed subs don’t play as low as ported, and I’m not sure if the subs wouldn’t sound as good being tucked away? Any thoughts/suggestions? Appreciate!
sbinkley is offline
post #2 of 6 Old 12-09-2019, 08:59 PM
Liked: 35
Dr. Hsu often recommends this setup which places you in the nearfield of the sub.
CDMC2 is offline
post #3 of 6 Old 12-09-2019, 09:09 PM
leehan76's Avatar
Quoted: 89 Post(s)
Liked: 76
There are definitely some great benefits to running subs nearfield. Some of them can include increased tactile feel, greater midbass, greater output over far field placement without needing to turn up your subs as high, etc. Try it and see which you prefer. If you can get your hands on a mic and the REW software you can measure and compare your subs to their previous locations in a very precise way.
Speakers: KEF R300 (R,L), KEF R600C (C), JBL 306p mkII (Surrounds), KEF Ci160QR (In-Ceiling) Subs: JTR Captivator S1 x2 Processor/Amps: Anthem AVM60, ATI AT4003, Rotel RB985 mkII Misc: ATV 4k, Sony PS4, Samsung K8500, MiniDSP 2x4HD, Crowson MAs x2 Video: BenQ HT2050, 100” Screen Room: 2500 cu sq. ft. sealed on suspended floor
leehan76 is offline
post #4 of 6 Old 12-14-2019, 04:37 AM - Thread Starter
Quoted: 92 Post(s)
Liked: 4
Thank you for the advice! Maybe I’ll start the 12” I have and try moving it behind the couch...it’ll be a tight fit and the port won’t be able to face the couch, so better to have it face toward the wall (about 4’ away still) or face the other direction where it’ll just be open space?
The reason I set it up in the front of the room in the corner is from everything I’ve read, however With how big this sub is I couldn’t put it in the center because I worry about the little ones smacking into it.
As always, I appreciate the advice 😉
sbinkley is offline
post #5 of 6 Old 12-14-2019, 06:54 AM
m0j0's Avatar
Quoted: 912 Post(s)
Liked: 1098
Running subs near field behind seating is a lot of fun. Just be careful with spl/volume since they will be much closer to your ears.
m0j0 is online now
post #6 of 6 Old 12-15-2019, 08:18 PM
leehan76's Avatar
Quoted: 89 Post(s)
Liked: 76
You’re quite welcome. There may not be a huge difference with which direction the ports face on your subs since the bass frequencies are generally omnidirectional. I’d recommend however you try both directions at a time to determine which port direction sounds better to your ears. One of the wonderful things about the REW software and getting a microphone to measure is again it enables you to fine tune your system very precisely. One sub, or more, in front and one in back is working excellently for many a bass enthusiasts on here.
leehan76 is offline
