Best cable for SVS 3000? - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #1 of 34 Old 12-10-2019, 04:42 PM - Thread Starter
juice2544's Avatar
Liked: 0
Is the AudioQuest Boxer really the best option? Also, wondering which other brands/models would be good (under $150 for 1.5-2m) and how Pangea Premier SE rca-rca or Pangea XL Digital Coax would compare, thanks!
juice2544 is offline
post #2 of 34 Old 12-10-2019, 04:52 PM
jsc79's Avatar
Quoted: 476 Post(s)
Liked: 631
Blue Jeans LC1 and call it a day would be my opinion.
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2EX - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3/Ascend Sierra 2
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is offline
post #3 of 34 Old 12-10-2019, 05:00 PM
eljaycanuck's Avatar
Quoted: 1983 Post(s)
Liked: 2807
A good-quality, 2-metre-long sub cable should cost you less than $20. If you REALLY want to splurge, maybe $30.*
That said, if you're a self-professed "audiophile", you should consider spending no less than $25/ft. Unless you're adding Shakti Stones, in which case you can get away with cable @ $15/ft.**
_________________________
(*Seriously. **Not so much.)
Alan P likes this.
eljaycanuck is offline
post #4 of 34 Old 12-10-2019, 05:02 PM
smcmillan2's Avatar
Quoted: 1021 Post(s)
Liked: 857
https://www.monoprice.com/product?p_id=2683, although they can be fairly stiff.
No reason to spend more than 10USD for a 6ft subwoofer cable. Also look into Amazon Basics and/or Mediabridge.
Zorba922 likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 34 Old 12-10-2019, 05:03 PM
Quoted: 272 Post(s)
Liked: 138
I use quad shield RG6. Left over from sat install. not very flexible but works great.
ipca204 is offline
post #6 of 34 Old 12-11-2019, 10:02 AM
Alan P's Avatar
Quoted: 6710 Post(s)
Liked: 6263
Alan P is offline
post #7 of 34 Old 12-11-2019, 10:05 AM
Kensmith48's Avatar
Quoted: 127 Post(s)
Liked: 36
This is the best and cheapest way to go.
Kensmith48 is offline
post #8 of 34 Old 12-11-2019, 10:15 AM
KidHorn's Avatar
Quoted: 1880 Post(s)
Liked: 1297
Any RG6 with RCA ends should work fine.
KidHorn is offline
post #9 of 34 Old 12-11-2019, 10:15 AM
Mocs123's Avatar
Quoted: 329 Post(s)
Liked: 178
I agree with the other posters saying don't spend over $20. Here is a nice one for under $6. Every bit as good of signal as the high dollar snake oil cables.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is online now
post #10 of 34 Old 12-11-2019, 05:01 PM
bear123's Avatar
Quoted: 2931 Post(s)
Liked: 4480
Get the BJC LC1 subwoofer cable. No reason for magical unicorn cables, but avoid the monoprice garbage. The LC1 will give you much better noise suppression to eliminate hums you get with cheap, garbage, race to the bottom of the barrel cables. It also has better build quality and very high quality terminals....you won't risk shorting your sub amps due to shoddy construction as happened to me and others with junk Monoprice cable. Many folks have eliminated hum by replacing bargain basement garbage cables with a good quality, reasonably priced BJC cable.
Or buy some cheap garbage, they might work.
d-rail34, darthray, badboi and 3 others like this.
bear123 is offline
post #11 of 34 Old 12-11-2019, 05:05 PM
bear123's Avatar
Liked: 4480
False, those cable are pure and utter garbage. You couldn't pay me hundreds of dollars to use them. I threw two of them in the trash after they shorted due to incredibly shoddy construction and blew the DSP amps in two of my PSA subwoofers. Stiff as hell too, good luck routing that garbage. Sometimes you get what you pay for...in this case....a 25 foot cable for $6.....which includes markup and profit.
Yes, I'm sure the rebuttal will be "nun-uh" I used them and their fine", but anyone who has been around here a while can tell you that *many* AVS members have had issues with them, and many have replaced them and eliminated noise and hum. A subwoofer cable is a very simple product.....defects should be extremely close to zero, and that is definitely not the case for that junk.
Alan P, darthray and d-rail34 like this.
bear123 is offline
post #12 of 34 Old 12-11-2019, 06:15 PM
d-rail34's Avatar
Quoted: 484 Post(s)
Liked: 990
+1 to @bear123 's rec for the Blue Jeans cables. These seem to be the most recommended on here.
I actually have the SVS Soundpath cable (8m) that I purchased from Amazon for much cheaper than what they're sold for on the SVS site and I haven't had any issues with it, so this could be another option for you as well.
Here are the links for both of these:
BLC (10ft)
https://www.amazon.com/Blue-Jeans-Ca...1&rps=1&sr=8-3
SVS (2m)
https://www.amazon.com/SVS-SoundPath...jaz10cnVl&th=1
Hope this helps,
Darrell
[EDIT] After double checking, the SVS isn't on sale currently, but still a good option nevertheless.
darthray likes this.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelf (4) w/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is online now
post #13 of 34 Old 12-11-2019, 06:34 PM
darthray's Avatar
Quoted: 2390 Post(s)
Liked: 3665
Originally Posted by Alan P View Post
+1 for Blue Jeans Cable LC1.
One more vote for the Blue Jeans LC1, been a very good cable with solid connection. And also is CL2/CL3 rated for in wall installation.
Darth
yanks1 likes this.
darthray is offline
post #14 of 34 Old 12-11-2019, 06:35 PM
Liked: 35
CDMC2 is offline
post #15 of 34 Old 12-11-2019, 06:39 PM
Mocs123's Avatar
Quoted: 329 Post(s)
Liked: 178
If there are issues, then it is due to shoddy Monoprice QC and not the cable itself. This is coming from someone that has bought Audioquest cables before (and still use them). Other than the fancy jacket and quality connectors, there is nothing special about the cable itself. The funny thing is they have directional arrows as if electrons care about the direction of the cable.
For goodness sake don't spend any more money than getting a cable from Blue Jeans Cable - a 6ft cable runs about $24. They use Belden cable and Canare connectors that are truly professional quality.
darthray, yanks1 and bear123 like this.
post #16 of 34 Old 12-11-2019, 06:43 PM
JerryIII's Avatar
Quoted: 191 Post(s)
Liked: 115
Amazon basics xlr works great for me for cheap. I am not a cable snob but I do use blue jeans cables for the others.
LG 65C7p | Sony PS3 | Sony PS4 | Apple Ariport Express | Emotiva UMC-200 | Parasound HCA2003a | Parasound HCA1000a x 2 | Monster HTS3500 | AC Infinity Aircom T8 x 2 | NHT 1.5 | NHT VS2 | NHT Super Ones | SVS SB16 Ultra w/ sound isolation feet | Harmony Elite | Salamander Venice 237 | Sound Anchors Cone Coasters | Vibrapods
JerryIII is offline
post #17 of 34 Old 12-11-2019, 06:45 PM
darthray's Avatar
Liked: 3665
Had some of the same issues with two 3 footer, they were stiff and the connection was flimsy as not very solid into the AVP and Amp.
Darth
darthray is offline
post #18 of 34 Old 12-12-2019, 01:57 AM
bobknavs's Avatar
Quoted: 2501 Post(s)
Liked: 1780
Any thoughts on the Mediabridge Ultra?
They're cheap. (Genuine Copper Clad Steel coax.) I'm using a 25' (7.6m) one with good results. (Touch wood.)
bobknavs is online now
post #19 of 34 Old 12-12-2019, 02:15 AM
jamiebosco's Avatar
Quoted: 840 Post(s)
Liked: 2113
I think if they work - they work - so if it aint broke,don't fix it. If you ever have troubles in the future the BJC LC1 is a very solid choice
yanks1 and darthray like this.
TV: Panasonic P65ST60 AVR: Denon X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is offline
post #20 of 34 Old 12-12-2019, 07:39 AM
confinoj's Avatar
Quoted: 1314 Post(s)
Liked: 1165
I like the mediabridge cables. Inexpensive and seem very well made. I have used up to 15ft in length without issues. Like others not a fan of the monoprice sub cables - very stiff. Right now I have 2 long runs (50+ ft) to the rear of my room and needed high quality shielding and something a little more low profile and flexible to get around corners. Went with Blue Jeans Belden 1505F which has been great.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | HDHomeRun Quatro | Nvidia Shield Pro 2019 | ATV 4K | Oppo UDP-203 | 40TB Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #21 of 34 Old 12-12-2019, 07:50 AM
basshead81's Avatar
Quoted: 349 Post(s)
Liked: 10037
I tried monoprice, ended up throwing everyone away... I switched to Mediabridge Ultra(2x25ft and 1x15ft) and have had no issues in the last 4yrs. I still think the BJC stuff is worth the money but I wouldn't pay for anything higher priced then that stuff.
Alan P, LGWGM, darthray and 1 others like this.
basshead81 is offline
post #22 of 34 Old 12-12-2019, 07:57 AM
darthray's Avatar
Liked: 3665
Much better quality than the Monoprice, and have a solid connection from the design point of view.
Darth
yanks1 likes this.
darthray is offline
post #23 of 34 Old 12-13-2019, 08:19 AM
Ed Mullen's Avatar
Quoted: 420 Post(s)
Liked: 921
The subwoofer signal is low in frequency and narrow in bandwidth - so it's not terribly difficult for an RCA cable to carry.
The biggest check marks for purchasing any RCA cable for subwoofer use are:
  • multi-layer shielding to reduce RFI and other external sources of noise
  • directional shielding where it is tied to ground at the source side and floated at the receiving side
  • robust construction at the cable/jack union - we hand-solder these connections and the above posters are correct - cheaply built cables fail here first/frequently
  • gold plated center conductor and ground shield to avoid oxidation and loss of signal over time
Our SoundPath RCA cables meet the above criteria and are also a good value. The same can be said of any BJC product - I recommend them frequently to customers who need XLR cables or in-wall RCA cables (which need to meet CMP or similar rating for NEC fire code).
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #24 of 34 Old 12-13-2019, 09:10 AM
no_cure's Avatar
Quoted: 223 Post(s)
Liked: 163
I wholeheartedly recommend any SVS product, their cables included - both my dual SVS subs are driven by SVS' own SoundPath RCA cables. They do a fantastic job, solidly built and don't feel that I broke the bank.
no_cure is online now
post #25 of 34 Old 12-13-2019, 09:34 AM
confinoj's Avatar
Liked: 1165
I actually forgot about the SVS cables mentioned by Ed. While a little more costly than Mediabridge still reasonably priced and very well built with a nice braided jacket. I have several and really like them too. Even though they are nice looking they don't come in black or white so may not blend as well if in plain site depending on your room.
confinoj is offline
post #26 of 34 Old 12-14-2019, 02:54 PM
joms's Avatar
Quoted: 122 Post(s)
Can i be a bit off topic as im also looking for a sub cable but dont know if i should buy 1 or 2. If i have a denon x4500 that has 2 sub out, do i connect both of that to the 2 rca of my PC13 ultra or do i only connect 1sub out using 1rca then use a splitter near the subs to connect the rca to the 2 rca input of the subs?
joms is offline
post #27 of 34 Old 12-14-2019, 08:27 PM
bobknavs's Avatar
Liked: 1780
https://system.na1.netsuite.com/core...85391&_xt=.pdf
You connect a single RCA cable from the number one sub output of the 4500 to the right (also LFE) low level input of the PC13. Just the one cable, no splitters. That is the best way connect the sub to the AVR.
The 4500's two sub outs are for two separate subwoofers. (The subs are independent. The room correction software in the 4500 can assign different distances to two subs.)
The two inputs on the PC13 are for cases where the source has no LFE (low frequency effects) output, but just a stereo line-level output. In that case, the PC13 mixes the stereo signals to mono, and uses that. You don't need, or want, to do anything like that.
joms likes this.
post #28 of 34 Old 12-14-2019, 09:42 PM
darthray's Avatar
Liked: 3665
Very much agree
Between the SVS and the BJC, money wise. Both are a winner, for excellent cables for the money. The BJC do have the advantage, for those folks that do in wall/or in ceiling installation. Been rated CL2 (residential) and CL3 (commercial) rating, for fire rating. Been very important Insurance wise, not to have a claim denied.
Darth
darthray is offline
post #29 of 34 Old 12-17-2019, 06:57 PM
Liked: 0
If I don’t need the cl2 ratings, is svs a better cable or are they equal in sound transmiSsion clarity/ interference shielding
Doctaandrew is offline
post #30 of 34 Old 12-17-2019, 07:43 PM
darthray's Avatar
Liked: 3665
A well made cable, is a well made cable.
Both are the same, sound wise.
Darth
darthray is offline
