SVS PB12 or SB3000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-13-2019, 04:16 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 2
SVS PB12 or SB3000?
I just got the PB12 and the Ultra tower speakers after in Piano finish. PB12 sounds amazing but is huge and not piano finish . Its not the end of the world but the SB3000 is a little smaller and in piano. Do you think there will be a huge difference for the extra money or will one be better? Any one have had both, heard or have knowledge?
promtber is offline
post #2 of 13 Old 12-13-2019, 05:38 PM
confinoj's Avatar
Quoted: 1314 Post(s)
Liked: 1165
We will need more info. What size room? What are your movie/music percentages? How loud do you listen?
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | HDHomeRun Quatro | Nvidia Shield Pro 2019 | ATV 4K | Oppo UDP-203 | 40TB Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #3 of 13 Old 12-13-2019, 07:04 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 2
Room is about 20x20, mostly movies/tv some music. I do like my movies somewhat loud.
promtber is offline
post #4 of 13 Old 12-13-2019, 07:14 PM
rhelliott2's Avatar
Quoted: 251 Post(s)
Liked: 435
Go ported then
Living Room: 5.1.2 PSA MT110L/R | PSA MTM210C | Polk TSi100 S/R | Atmos in-ceiling Mag6R
SUB: PSA V1512
RECEIVER: Denon X3400H
DISPLAY: Vizio P65-C1
SOURCES, MISC, & 2ch: Xbox One X, Harmony Elite, Aircom T10, Chane A1.5 & AD18
rhelliott2 is online now
post #5 of 13 Old 12-13-2019, 07:23 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 2
My question is how does the PB12 compare to the SB 3000 or 4000?
promtber is offline
post #6 of 13 Old 12-13-2019, 07:41 PM
radXge's Avatar
I cannot talk about the PB12 but I own a SB-3000 and it is quite a beast despite its smaller size... this thing goes down to 18Hz, which is a bit higher than the 16Hz from the PB-12.
I suspect that that the SB-3000 is more tighter and more dynamic than the PB-12... The SB-3000 will not as loud at the extreme low end but you will get more quality at higher frequencies.
I also own a mighty PB-4000 and I am telling you that the SB-3000 is surprisingly VERY powerful and sounds amazing.
Frankly, most people would be very happy with a SB-3000... much smaller footprint than ported models... in addition, the app makes the setup a breeze.
Depending on your budget, you could also consider getting two SB-3000s...
LG C9 65" | Denon X4500H | Panasonic UB820 | Apple TV 4K | i1Pro2 | Monitor Audio Silver RS6+RSLCR+RSFX + SVS PB-16U + PB-4000
radXge is offline
post #7 of 13 Old 12-14-2019, 06:55 AM - Thread Starter
Quoted: 23 Post(s)
Liked: 2
Have you heard a PB2000? its kinda similar to the PB12. The PB12 sound great for my ears, just wondering if the SB3000 will blow it away?
promtber is offline
post #8 of 13 Old 12-14-2019, 04:56 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 2
So to keep my topic going. I have the PB12 and it sounds really good just large and doesn’t match my Ultra towers in piano. What would you pick for a good movie / music sub for a 20x20 room normal ceiling heights. I currently have a Denon 4500.
1 PC2000
2 PC4000
3 SB3000
4 SB4000
5 Just keep what I have
promtber is offline
post #9 of 13 Old 12-14-2019, 05:24 PM
confinoj's Avatar
Liked: 1165
1 PC2000
2 PC4000
3 SB3000
4 SB4000
Of those choices in that size room for primarily loud movies the PC-4000 by far. There are lots of other options outside of SVS in that price range as well with better bang for the buck if you are interested.
post #10 of 13 Old 12-14-2019, 05:36 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 2
What would you recommend?
promtber is offline
post #11 of 13 Old 12-14-2019, 06:56 PM
confinoj's Avatar
Liked: 1165
In that size room the more powerful ported sub the better. What is your max budget? I take it you are looking for a piano black finish? Are you willing to go duals?
post #12 of 13 Old 12-14-2019, 07:16 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 2
I rather just have one for now. Would like to spend around 1k but can go more.
promtber is offline
post #13 of 13 Old 12-14-2019, 08:30 PM
confinoj's Avatar
Liked: 1165
While Hsu hasn’t had any new products for a while their VTF-15H MK2 sub is still considered one of the best subs at the $1000 price point. It’s supposed to be pretty well rounded in terms of deep bass, mid bass, and musicality. They have a decent finish and the triangular ports are distinctive looking.
http://www.hsuresearch.com/products/vtf-15hmk2.html
I would also look at some of the ported options from PSA and Rythmik. I have SVS PC-4000s which I love and was floor space limited so they worked out well. If I had no such limitations I would be very interested in the Rythmik FV18 with paper cone which is a similar price. It seem to do everything extremely well and is well suited for a large space. That’s well above 1K but you had the PC-4000 on the list.
