2x SVS PB 2000's or 1x SVS PB 4000 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1 of 34 Old 12-19-2019, 02:06 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 5
Room is 12' W about 15' deep. I will use it for 90% movies and 10% music all genres and LOUD! I want to feel it in my chest when I hear a gunshot. I was going to get the SVS PB 4000 but my buddy is trying to convince me to do 2x SVS PB 2000's. Only experience i've had with subs have been klipsch all sizes 10"-15". I love their speakers but in my opinion their subs suck and do not give me what i'm looking for.
If there are other options let me know. Budget is $2,000.
notoriouskeef is offline
post #2 of 34 Old 12-19-2019, 02:08 PM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
Dual Outlaw X13 $1998 free shipping
You wont get more sub for the money!
Speakers: KEF Q100, Q300, Q750, Q650C, Q50a / Fluance Signature Series/ DCM TP160S-CH Subwoofers: Outlaw Ultra X12 (x2) / BIC H100-IIReceiver: Denon AVR-X4500H, AVR-X1400H Integrated Amplifier: Yamaha A-S501/ Fosi Audio TPA3116 mini amp Extras: MiniDSP Umik-1 Amplifier: Emotiva BasX-A300 Next Speakers: Triangle BR03, Revel Concerta2 M16, KEF LS50, Dynaudio Emit M20, Buchardt S400, Triangle Comet ez, KEF R3
macgallant is online now
post #3 of 34 Old 12-19-2019, 03:11 PM
bear123's Avatar
Quoted: 2957 Post(s)
Liked: 4506
Dual Hsu VTF3 MK5 or dual VTF15 MKII would be my pick for the best subs under $2k. If you are looking for chest kick, these will do so much better than the SVS as they have substantially higher mid bass output.
I believe both of these subs will outperform the X13 Ultra overall, which has good low bass but mediocre mid bass, imo.
bear123 is offline
post #4 of 34 Old 12-19-2019, 03:38 PM
Zorba922's Avatar
Quoted: 7752 Post(s)
Liked: 5871
You want the healthy mid-bass more than the deep deep subsonic stuff, in that case...I'd take a pair of the Hsu that bear123 mentioned.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #5 of 34 Old 12-20-2019, 07:56 AM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
If you want lots of tactile, go with the single PB-4000, as far as mid bass it has lots there also but frankly you can only use so much mid bass anyways.
Pioneer SC-95, Axiom M80, VP180, Dual SVS PB-4000 subs, ISCO III, RS540 + Stewart Cima Neve 133
microwiz is offline
post #6 of 34 Old 12-20-2019, 08:09 AM
Quoted: 29 Post(s)
Liked: 30
Drop SVS from consideration if you're searching for chest punching mid bass. Dual 15" HSU VTF-3.5's should give you what you want in that size room.
Kothoga likes this.
Sn1per666 is offline
post #7 of 34 Old 12-20-2019, 08:23 AM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
I wouldn't drop the PB-4000, PB-4000 probably has more mid bass than he will ever use.
microwiz is offline
post #8 of 34 Old 12-20-2019, 08:42 AM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
In the $2000 price range the PB4000 has the less mid-bass, both the Rythmik FV18(2-4dB advantage) and PSA V18 IPAL has more mid-bass response than the PB4000.
In fact even the $900 even a single HSU VTF-3 MK5 has more mid-bass response so Dual VTF3 MK5 would have a 6-10dB mid-bass advantage over 1 PB4000
Kothoga likes this.
post #9 of 34 Old 12-20-2019, 08:50 AM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
Sure but you can only use so much mid bass, if he can't even use all the mid bass a PB-4000 can produce whats the point of more output at those frequencies?
microwiz is offline
post #10 of 34 Old 12-20-2019, 09:22 AM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
Depends on the size room and the distance to the MLP and It Also it depends on how loud the OP listens to.
For me personally I wouldn't be maxing out Dual Outlaw X13's since i'm not even maxing out my dual X12's!!
But my best friend often listens to movies at reference levels sometimes +5
But to get back on point the VTF3 MK5 will give the same/better mid bass for half the price so going with duals will obviously offer the benefits of duals for the same price as 1 pb4000.
post #11 of 34 Old 12-20-2019, 09:33 AM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
Well i'm speaking from experience here, not hearsay. A single PB-4000 has more mid bass than I can use in my 3300 sqft room which is much bigger than his.
Now the tactile performance of a single PB-4000 would not be good enough for me in a 3300 sqft room, it would work but I would need to run it a bit hotter than I would like, but in a room his size that's not going to be a problem at all.
Also not to state the obvious but mid bass is the easiest to make and is also aided by your main speakers, not the case with tactile frequencies.
microwiz is offline
post #12 of 34 Old 12-20-2019, 12:12 PM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
Thats literally why dual HSU VTF3MK5 makes the most sense for him since a single VTF3MK5 has a stronger 40hz-100hz response than the PB4000
post #13 of 34 Old 12-20-2019, 12:16 PM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
40hz-100hz is mid bass, not tactical bass.
microwiz is offline
post #14 of 34 Old 12-20-2019, 12:36 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
You're speaking from *your* experience. Enough mid-bass for you may not be enough mid-bass for someone else. Further, the OP said he wants to "feel it in his chest" when he hears a gunshot. Chest punch is mid-bass in spades. Therefore, the proper recommendation is for the strongest mid-bass performer.
The sub is for the OP, not you.
macgallant and bear123 like this.
My humble main system:
Vizio M75-E1; Oppo 203 universal UHD player; Denon 4300H AVR, Dual PSA S1801's; Monitor Audio Silver RX-6 mains, RX center, and RX surrounds; one pair NHT mini Atmos speakers; Home-built HTPC (Xeon E1230, 16gb RAM, Crucial M500 480gb SSD, GeForce 980Ti, Corsair CX600, CoolerMaster mini-ITX case); Roku Premiere+; Amazon 4K Fire TV
sk373 is online now
post #15 of 34 Old 12-20-2019, 12:37 PM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
I want to correct myself the HSU has 2-3 dB more bass from 31.5hz to 80 hz (not 40hz)
PB4000: 20hz; 112.3 25hz: 113.3 31.5hz: 114.8 40hz: 116.8 50hz: 118.7 63hz: 117.7 80hz: 116.2
VTF3MK5: 20hz: 106.2 25hz: 111.4 31.5hz: 116.2 40hz 119.9 50hz: 120.3 63hz: 119.1 80hz 118.4
also the "chest" slam bass is mostly MID bass not deep LFE which is what the OP is after (50hz to 100hz)
If he wants more LFE and wants to spend all his $2000 on 1 sub then the Rythmik FV18 will serve him better than a PB4000 as it has significantly more ultra LFE output from 10-20hz
post #16 of 34 Old 12-20-2019, 12:44 PM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
But I do feel it in my chest from gun shots, I feel the pull and push of my ear drums in spades. I can feel the thud from closing doors and even thump from foot steps.
So if we don't want to use my experience with the very sub he asked about to convey what to expect who's should we use?
microwiz is offline
post #17 of 34 Old 12-20-2019, 01:17 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
Your experience is fine. However, you are arguing for a single PB4000 largely because that is the sub you own and use. I get it--we all like to defend our choices and purchases.
We have measurements, and dual HSU VTF3-MK5's will get much more bang for the OP's buck than a single PB4000. Especially for chest punch. It's all about headroom, and dual subs will give him smoother bass response with proper set up.
macgallant likes this.
sk373 is online now
post #18 of 34 Old 12-20-2019, 01:30 PM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
I don't think you actually read his post, he is the one who asked about SVS dual PB-2000 vs a single SVS PB-4000. I simply responded to which one I think would be better in his room.
Also bang for buck isn't just output, well at least not for everyone. Looks, Warranty, Customer Service, technology, return policy etc weigh into that as well.
microwiz is offline
post #19 of 34 Old 12-20-2019, 01:35 PM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
Also bang for buck isn't just output, well at least not for everyone. Looks, Warranty, Customer Service, technology, return policy etc way into that as well.
He did ask for suggestion (literally the last thing he asked)
thats all nice but performance should be the #1 priority and the VTF3 MK5 performs better than the PB4000 for what the OP is looking for while costing 60% less.
If the OP really wants the best customer service / warranty / return policy then look no further than PSA (the industry standard IMO)
sk373 likes this.
post #20 of 34 Old 12-20-2019, 01:40 PM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
Not if they all exceed the output I need to get what I want, there is a point where more output doesn't help. Maybe he would prefer the best looking sub, maybe he would prefer to use the app to fix drops and peaks or just boost the entire mid punch area with an app.
microwiz is offline
post #21 of 34 Old 12-20-2019, 01:51 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
To be fair, SVS delivers customer service on the same level as PSA. And SVS's warranty and return policy are just as strong. Which makes sense since Tom co-founded SVS.
That said, dual VTF3-MK5's over a single PB4000 all day, every day, IMHO. And I have no dog in this fight--I'm a PSA owner. I would recommend the PB4000 if the OP were looking for more ULF. But the OP is looking for chest punch. Max output isn't just about output. It's about headroom. And dual VTF3-MK5's won't work nearly as hard as a single PB4000--especially in the midbass.
sk373 is online now
post #22 of 34 Old 12-20-2019, 02:01 PM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
But he has head room and ULF. Not sure if ya'll looked at the numbers but 118dB at 63hz is the same loudness as a turbo fan jet engine taking off, which is actually painful to 100% of the population, good luck not finding that loud enough in a smallish 2300 sqft room.
If that's not headroom I don't know what is. 5 year warranty, looks and technology do appeal to some of us, maybe it does for him as well.
microwiz is offline
post #23 of 34 Old 12-20-2019, 02:18 PM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
Even then if he was looking for Ultra LFE the rythmik FV18 has more LFE output and more Mid bass AND cost $200 less + servo subs sound tighter!
IMO the PB4000 is priced oddly and way too high. Its an amazing sub but that price.... .....
I'm into audio first and foremost for the sound. Looks matter but there's no hidding a sub once you get to 12" sub.
I know my X12 is overpriced unless on a killer sale and I'll be the first to admit it 🙂!
IMO there's nothing worse than fanboys in ANY industry but we cant expect everyone to be 100% objective.
post #24 of 34 Old 12-20-2019, 02:29 PM
sk373's Avatar
Quoted: 833 Post(s)
Liked: 1203
118 dB at 63 Hz is different from 118 dB at 315-6300 Hz, which is the frequency range for a jet engine. the lower the frequency, the less sensitive we are to the volume level.
bear123 likes this.
sk373 is online now
post #25 of 34 Old 12-20-2019, 03:04 PM
microwiz's Avatar
Quoted: 314 Post(s)
Liked: 207
Less sensitive in some ways but more sensitive in other ways. It won’t quite sound as loud but it will feel louder.
microwiz is offline
post #26 of 34 Old 12-20-2019, 03:18 PM
joxr's Avatar
Quoted: 50 Post(s)
Liked: 27
He could wait for one of the holiday outlet sales .. like the one probably for xmas or new years and get a no damage pb4000 for $1599 like I did on cyber monday sale.
5.2.4
joxr is offline
post #27 of 34 Old 12-20-2019, 03:38 PM
macgallant's Avatar
Quoted: 729 Post(s)
Liked: 452
Monolith 15 surpasses the pb4000 performance in extension, mid bass etc. And it only cost $1338. You can buy this anytime.
@$1599 you may as well spend the extra $200 and grab the Rythmik FV18 which is a significant step up from the pb4000
post #28 of 34 Old 12-20-2019, 04:20 PM
Quoted: 29 Post(s)
Liked: 30
The OP likes to listen loud with a focus on mid-bass I don't think a single PB-4000 would suit him unless he could get 2 and that is far over budget. If $2,000ish was my budget I would be emailing Tom (PSA) to see if he had any outlet V3611-12 in stock.
sk373 likes this.
post #29 of 34 Old 12-20-2019, 04:26 PM
Kothoga's Avatar
Quoted: 136 Post(s)
Liked: 182
lol, right. SVS are weak just about everywhere when compared to bigger and better subs that cost less, the return on investment with SVS is awful. When it came to midbass, my two PB16s didn't equal one of my PSA V3611s.
bear123, sk373 and macgallant like this.
Theater: JVC RS540U, 2.35:1 142" screen, Onkyo RZ1100, Panasonic UB820, Outlaw Audio M2200 Monoblock x3, Klipsch RF7II, RC64II, RS62II, 5800CII x4 Atmos, PSA V3611 Subwoofer x2.
2 Channel: Parasound P6, Parasound A23+, Rega Planar 6 with Ortofon 2M Bronze, Klispch La Scala II, Behringer NX6000D, B&C 21DS115-4 powered Devastator V1 x2.
Kothoga is offline
post #30 of 34 Old 12-20-2019, 04:38 PM
Kothoga's Avatar
Quoted: 136 Post(s)
Liked: 182
Mine, as I had two PB16 Ultras and they are no where close to my two PSA V3611s when it comes to chest slam from mid bass. Night and day difference, the PB16 dug a little deeper in my room but there was no advantage to that over getting punched in the chest by shotgun blasts.
Kothoga is offline
