How to configure crossover, phase, and level for subwoofer - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By mthomas47
  • 2 Post By mhweb
post #1 of 7 Old 01-10-2020, 02:45 PM - Thread Starter
Liked: 4
This is a random image of the back of a monolith subwoofer, but I wanted to use it as a reference to ask how the nubs should be set for crossover, phase, and level to have proper configuration. Or at least, what should be recommendation.
This sub is in a small 15 x 12ft room with 8-9ft ceiling, and wooden floor.
Also, if understand correctly, the level should stay at THX, right?
mhweb is offline
post #2 of 7 Old 01-11-2020, 07:05 AM
Wayne A. Pflughaupt's Avatar
Quoted: 468 Post(s)
Liked: 390
Most people just let the AVR handle crossover, phase and level. Are you not going to be doing that?
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #3 of 7 Old 01-11-2020, 07:20 AM
eljaycanuck's Avatar
Quoted: 1984 Post(s)
Liked: 2808
My recommendation is to start with the settings specified in the owner's manual.
eljaycanuck is offline
post #4 of 7 Old 01-11-2020, 07:22 AM
Dargent0628's Avatar
Quoted: 252 Post(s)
Liked: 141
Crossover set to MAX Phase IMO has no audible effect Gain set to nine o' clock (-12dB) THX settings OFF (initially...). Then run your receiver's room correction setup. The receiver should set your subwoofer's gain to somewhere near 0dB (within a point or so...). If your receiver sets the gain appreciably higher or lower than that then adjust the gain knob on the subwoofer accordingly (higher for too low gain in your receiver, lower for too high gain in your receiver...) and then run the setup program again until you get to around 0dB. THEN you can toy around with the THX switches to see if they effect/improve the sound TO YOUR EARS. IMO those switches are gimmicky, but I don't own that subwoofer and they may well have a positive effect.
Dargent0628 is offline
post #5 of 7 Old 01-11-2020, 07:24 AM
AVS ***** Member
mthomas47's Avatar
Quoted: 5665 Post(s)
Liked: 11242
Hi,
As Wayne said, your AVR will help you to determine your subwoofer gain (level) setting. But, if I were you, I would leave the phase set at "0" and I would set the crossover at the max setting. I can't tell whether the crossover control knob is even operational unless the crossover switch is set to the "On" position. Your owner's manual may answer that question.
In any event, for calibration purposes, you will want your AVR's automated room correction system (if your AVR has one) to be able to EQ the subwoofer's full frequency range, and initially at least, you will want your subwoofer to be able to play as high as it is able to. Once your AVR sets crossovers for your various speakers that may or may not be quite as important.
With respect to the sub's level (the gain control) I would start with it at about the -12 position, and then adjust upward or downward a little, as required during the calibration process. After your AVR finishes its calibration, you would ideally like for your AVR sub trim to be in negative numbers. If you want to understand more about that, you can refer to the Cliff Notes, in the Guide linked in my signature, or you can read as much detail as you would like to in Section II.
I think that the Guide may be helpful to you as you implement your new subwoofer.
Mike
mhweb and Adamg (Ret-Navy) like this.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #6 of 7 Old 01-13-2020, 05:06 PM - Thread Starter
Liked: 4
Wayne A. Pflughaupt
I would rather have the AVR handle everything, I'm still new on audio, so I'm just trying to understand how everything works to things properly.
mhweb is offline
post #7 of 7 Old 01-13-2020, 05:07 PM - Thread Starter
Liked: 4
Originally Posted by mthomas47 View Post
Hi,
Mike
This info help, I'll ready the guide to understand subs better.
mhweb is offline
subwoofer
