Subwoofer advice - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By Jesuscookies
  • 1 Post By qguy
  • 1 Post By indebtbassfreak
post #1 of 4 Old 01-14-2020, 09:09 AM - Thread Starter
morasp's Avatar
Quoted: 55 Post(s)
Subwoofer advice
I have an older sub-woofer that's pretty good but no longer available. my receiver allows two subs so I added a second one from a HTIB speaker set to help fill in the sound. I've decided to send back the HTIB speakers but will miss the sub. I'm looking for an affordable < $300 sub that could help fill in the sound. The best sellers on Amazon are brands like Polk, Yamaha, Klipsch, and BIC. Could someone recommend an affordable option whose faults are ones of omission rather than commission? For anyone interested here is an old review of a previous model of my subwoofer.
http://www.enjoythemusic.com/magazin...5/acititan.htm
Thanks in advance.
morasp is offline
post #2 of 4 Old 01-14-2020, 09:30 AM
Jesuscookies's Avatar
Quoted: 60 Post(s)
Liked: 64
Have you taken a look at the under $300 budget subwoofer thread just slightly above this one?
They have a lot of knowledgeable folks, and good list to choose from.
I have owned a BIC F12, and while it won’t shake your crowns loose, it does an adequate job at the price point.
eljaycanuck and morasp like this.
Jesuscookies is offline
post #3 of 4 Old 01-14-2020, 09:44 AM
qguy's Avatar
Quoted: 232 Post(s)
Liked: 112
I would save a bit more coin and get the $499 SVS PB12-NSD at amazon
morasp likes this.
qguy is offline
post #4 of 4 Old 01-14-2020, 09:46 AM
indebtbassfreak's Avatar
Quoted: 1515 Post(s)
Liked: 2919
Good advice already posted ^^,,,,,, I'll add,,, despite your limited budget,, just $100 more will get you into a much better sounding sub like the RSL- Speedwoofer. If thats not an option then as mentioned check out the budget sub thread.
morasp likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
