Recommendation - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Jean-Michel Quillien
post #1 of 8 Old 01-14-2020, 08:48 PM - Thread Starter
Jean-Michel Quillien's Avatar
Liked: 1
Recommendation
Hello,
I have a room small size 17X17X8 or 2312 cubic feet who open to the kitchen and hallway, Floor are tiles. I currently own 2 Klipsch R-100SW, it dial pretty well but I do see a need for more accurate bass. I recently upgraded and I have 2 martinlogan 60XT with a 30I martinlogan and Motion 30I and Atmos. Anyway I need a little recommendation on what you think will be the right way to go on replacing this 2 subs. Thinking 2 RSL Speedwoofer 10S or 2 Hsu Research ULS-15 mk2 or 1 Rythmik audio FVX12 due to size I cannot feet 2 or f12 or l12. Will that be overkill? Anyway thanks for your reply in advance maybe you have some other suggestion. Budget 1600$ let's say that I can spend 900$ right now and the rest when tax are coming just so you are aware. I do listen to Music 30% and movies 70% of the time. or should I keep what I have
Jean-Michel Quillien is offline
post #2 of 8 Old 01-15-2020, 06:50 AM
eljaycanuck's Avatar
Quoted: 1993 Post(s)
Liked: 2825
Originally Posted by Jean-Michel Quillien
… I have a room small size 17X17X8 or 2312 cubic feet who open to the kitchen and hallway … Thinking 2 RSL Speedwoofer 10S or 2 Hsu Research ULS-15 mk2 or 1 Rythmik audio FVX12 due to size I cannot feet 2 or f12 or l12. … Budget 1600$ let's say that I can spend 900$ right now and the rest when tax are coming just so you are aware. I do listen to Music 30% and movies 70% of the time. …
I wouldn't go sealed in your space unless you were looking at two very powerful sealed subs. What are the max dimensions (l x w x h) available for the subs? If you can't fit Rythmik FVX12s, can you fit LV12Fs?
(The Speedwoofer is a well-rated sub but it will fall a bit short on extension for movies, especially in your larger space.)
eljaycanuck is offline
post #3 of 8 Old 01-15-2020, 07:38 AM - Thread Starter
Liked: 1
D is 26, W 15, H doesn't matter i can maybe squeeze a little more moving the speakers, but it will be hard.
post #4 of 8 Old 01-15-2020, 07:44 AM
Liked: 2825
post #5 of 8 Old 01-15-2020, 08:46 AM - Thread Starter
Liked: 1
Thanks for the information.
post #6 of 8 Old 01-15-2020, 08:59 AM
Liked: 2825
post #7 of 8 Old 01-15-2020, 02:24 PM - Thread Starter
Liked: 1
Bienvenue.
Merci! After multiple going back and forth I did talk to Rythmic as well I decided to go with the L22. Since I do want a small foot print I think that will work better. Will let you know and thanks for your help.
eljaycanuck likes this.
post #8 of 8 Old 01-15-2020, 02:26 PM - Thread Starter
Liked: 1
Rythmik, failed terribly
