SVS sub too boomy - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #1 of 50 Old 01-24-2020, 05:36 AM - Thread Starter
Liked: 3
SVS sub too boomy
Hi All,
I have had an SVS SB1000 sub for a few months. I ran Audyssey and listened for a while. It was way too boomy sounding, especially on any music (such as commercials). I have B&W CM2 bookshelves and matching center run through a Marantz NR1607 AV receiver. Audyssey has these correctly set to small. I changed crossover to 80 and then 120 and have reduced sub output down to -4dB. None of this has provided satisfactory results and I am really wishing my 20 year old Velodyne did not fail on me. Sub is placed in a corner about 8" from either wall.
What else can I try to make this sub transparent until it is really needed for special effects?
Thanks, Russ
sacbut is offline
post #2 of 50 Old 01-24-2020, 05:44 AM
chevman's Avatar
I have never used Audyssey, but I have heard of a couple of people who ran it and still had some issues. When it comes to subwoofer placement, there is something called nulls in a room, which is where the bass drops out. The opposite of that is something called peaks, which is where the level is increased. Others here are a lot more knowledgeable than I am, but it could be that your old sub worked in that same spot but this one doesn't. It may be that there is another spot in the room that would allow the sub to blend more smoothly with your speakers. To accomplish that you can simply put the sub in other areas and see how it sounds to your ears. Another more exact approach is doing something called a sub-crawl which is what you think it is. It is placing the sub in other areas and crawling around with a mic measuring the output of the sub in order to figure out the peaks and nulls for the best sub performance.
With all due respect to you and your knowledge... I reserve the right to be wrong about what I say and think.
chevman is online now
post #3 of 50 Old 01-24-2020, 05:56 AM
SuperFist's Avatar
Quoted: 1490 Post(s)
Liked: 6191
Originally Posted by sacbut View Post
Hi All,
Thanks, Russ
Yeah, it sounds to me like your sub is being corner loaded with quite a bit of room gain - good for some, but not for others. Move it to another spot and see how it sounds.
SuperFist is online now
post #4 of 50 Old 01-24-2020, 06:04 AM
ClawAndTalon's Avatar
Quoted: 593 Post(s)
Liked: 441
Hi All,
Thanks, Russ
1. Try moving the sub six inches to foot out of the corner.
2. Do Audyssey again with a tighter or larger mic pattern, opposite of what you did before.
3. Do not judge your sub performance by commercials, they are the worst.
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is online now
post #5 of 50 Old 01-24-2020, 08:24 AM
basshead81's Avatar
Quoted: 352 Post(s)
Liked: 10208
likely a room response issue. Move the sub around the room until you find a better spot. Outlaw offers a nice wireless kit that makes placing subs around the room much easier.
ClawAndTalon likes this.
basshead81 is offline
post #6 of 50 Old 01-24-2020, 11:06 AM
gajCA's Avatar
Quoted: 9667 Post(s)
Liked: 6702
Hi All,
Thanks, Russ
Make sure you have Dynamic EQ "off."
Geoff A. J., California
gajCA is offline
post #7 of 50 Old 01-24-2020, 11:47 AM
H Stevens's Avatar
Quoted: 183 Post(s)
Liked: 149
This is the big one right here, Dynamic EQ and Dynamic Volume is way over the top especially if your running the sub "hot".
H Stevens is offline
post #8 of 50 Old 01-24-2020, 01:36 PM
Ed Mullen's Avatar
Quoted: 454 Post(s)
Liked: 984
Great advice above -
  • Pull the sub a bit farther away from the corner.
  • Set the gain to 1 o'clock.
  • Run Audyssey with the mic at head level where you sit - don't move it too far left or right for the next two measurements.
  • Save the results.
  • Confirm the speakers are set to Small
  • Set the crossover to 80 Hz (unless Audyssey set it higher, which is unlikely)
  • Set the subwoofer mode to LFE and the LPF/LFE to 120 Hz
  • Go under Audio/Audyssey and disable Dynamic EQ and disable Dynamic Volume
Normally I'm a fan of DEQ - but if you are sensitive to its bass emphasis - particularly at lower playback levels - you'll likely prefer it disabled.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #9 of 50 Old 01-24-2020, 02:02 PM
Spewdom's Avatar
Quoted: 241 Post(s)
Liked: 219
Yep. DEQ is awesome.
Spewdom is online now
post #10 of 50 Old 01-24-2020, 07:53 PM
Sevenfeet's Avatar
Quoted: 370 Post(s)
Liked: 385
Moving the sub off direct contact with the floor may help too, especially if what's under the floor is causing trouble. Years ago I discovered that the sub in my theater was sounding awfully boomy. Turned out that the garage under by theater room was the cause. The large space with metal cars and concrete floor caused all kinds of problems, much like a drum stuffed with hard objects. The solution was a Aurelex Mo-Pad which is a foam platform to decouple the sub from the floor and the difference was night and day. SVS also sells add-on feet that effectively do the same thing. I have them on a different SVS sub in the house and this solution works well too.
altpensacola and Rolls-Royce like this.
Sevenfeet is offline
post #11 of 50 Old 01-25-2020, 10:42 AM
gajCA's Avatar
Liked: 6702
That's the thing, some people love it, but, for me, with modern content it makes my usually great sounding 1250 watt DD15 sealed servo sub sound like crap...muddies and adds boominess to my Usher V603 center channel as well.
On old content like black and white movies or documentaries which lack modern soundtracks it can help with a 10-15db offset.
MUDCAT45 likes this.
gajCA is offline
post #12 of 50 Old 01-26-2020, 01:22 AM
Peja's Avatar
Quoted: 88 Post(s)
Liked: 61
The Outlaw OAW3 Wireless Audio System is no longer available. https://outlawaudio.com/products/OAW3.html
Peja is offline
post #13 of 50 Old 01-26-2020, 04:52 AM
osu fan's Avatar
Quoted: 61 Post(s)
Liked: 120
Been replaced with this one. https://outlawaudio.com/products/OAW4.html
Peja likes this.
Video Samsung UN65KS8000, Sony UBP-UX80
Audio Denon X4500H, PSA MTM-210T, MTM-210C, MT-110 X2, SVS PB12NSD & SVS PB1-ISD (Subs soon to be upgraded)
osu fan is online now
post #14 of 50 Old 01-27-2020, 11:24 AM
mbroadus's Avatar
Quoted: 1190 Post(s)
Liked: 490
I always forget about checking DEQ and Dynamic Volume.
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-203, Bluesound Node 2i, Focal Aria 936/CC900
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is offline
post #15 of 50 Old 01-29-2020, 09:31 PM
Liked: 1
Agree with comments above.
You bring ports into consideration, sealed subs are a little more forgiving to place.
If you have or know someone that has something like Omnimic or XTZ Room Analyzer Pro or Room Eq Wizard (REW is a free download or a donation) you just need a mic, calibrated USB is fine for cheap think they are about $80 depends where you live. It will probably be your best investment towards your system.
Use the RTA (real time analyzer) in the software and place the sub (like the sub crawl mentioned above) and move the mic around the room while watching the RTA for smoothness. Easier to move the mic around than move the sub around. Better again get someone else to help you so you can concentrate on the RTA graph.
All the above products are all very good in their own right. XTZ has a delay alignment tool (extra easy to use) which fixed my systems subs. The Yamaha YPAO receiver and SVS Aseq1suggested 7.15 metres the XTZ suggested 6.35 metres. I measured for quite sometime and XTZ was right.
Philips752 is offline
post #16 of 50 Old 01-31-2020, 12:14 PM
Quoted: 12 Post(s)
Liked: 6
I did the same thing you did. Added isolation pads/feet to my svs sub and it definitely made a big difference. Those isolation platforms/pads are so worth the price.
Craig Peer and altpensacola like this.
filip629 is offline
post #17 of 50 Old 01-31-2020, 12:56 PM
Quoted: 593 Post(s)
Liked: 441
Hi All,
Thanks, Russ
Anything work?
post #18 of 50 Old 01-31-2020, 01:09 PM
Quoted: 593 Post(s)
Liked: 441
Not to get the post off the rails, but the idea of these subwoofer “pads” suggesting “decoupling” vibrational energy from the sub to the floor is pure nonsense.
If a subwoofer has no feet whatsoever ever, rubber feet, like hardware store variety, are all that is needed to creat a level seal of the cabinet to the floor. Nearly all name brand subs do. Absent any feet, this pad would do that, at a premium, but there’s no secret sauce.
Any sonic change is due to the physical upward movement of the sub, which even a few inches, can cause an audible change. Anything around your subwoofer that is rattling is doing so from acoustical energy, not vibrational energy. The pad under the sub couldn’t possibly absorb a fraction of low sub 80hz sound waves. You’d need a mattress thick pad to do that. However, moving the sub in the right direction, including upwards, can shift that acoustical energy, and bass modes, and cause things to no longer rattle.
My suggestion is to use the styrofoam frame that the sub came in. And see how the sub performs with that around it. If you like that, sure, get the pad, it does look nicer. But again, sonic benefits are coming from the sheer movement of the sub. Not some gee wiz effect of the pad.
post #19 of 50 Old 02-01-2020, 03:34 PM - Thread Starter
Liked: 3
update
So just a quick update. First I travel a fair amount so I have not tried all suggestions yet. But I did turn off Dynamic EQ and that significantly improved my situation. Next will be to move the sub and re-run Audyssey. Thanks for all the assistance.
Craig Peer, d-rail34 and gajCA like this.
sacbut is offline
post #20 of 50 Old 02-01-2020, 08:09 PM
altpensacola's Avatar
Quoted: 297 Post(s)
Liked: 173
When I had a down firing sub on an off grade wood floor a 2 inch thick piece of granite made a noticeable difference in boom and other resonation (?).
It didn't absorb the sound, just kept the floor from rattling and tightened up the bass if that describes it . I don't use it now because I moved to front firing x's 2.
Music, more music.
altpensacola is offline
post #21 of 50 Old 02-01-2020, 08:59 PM
Quoted: 593 Post(s)
Liked: 441
The only thing you truly need is a way to seal the bottom of the subwoofer to the floor in such away that you have a firm connection so it doesn’t rock or tip due to uneven contact with the floor. Same with your speaker tower. Rubber feet, or carpet spikes do this fine.
Assuming this was done, if adding anything else under a subwoofer made an actual change (accounting for placebo, or expectation bias, so properly controlled) then it was due to the subwoofer changing locations, in this case upwards. This can and will change response at the same listening location.
Front and down firing are the essentially same thing. You have bass imitating from a specific point inside the driver and spreading across the room. When you changed to a front firing subwoofer, that location of the focal point of the bass, which comes from inside the cabinet, inside the driver itself, was changed, relative to your room, causing different room mode reactions, and possibly what vibrates before didn’t vibrate now. In short switching from one configuration to the other is like moving the sub.
There’s some tertiary concerns with down firing vs front firing but to suggest a down firing subwoofer necessitates or benefits in any way to something, even a small granite slab, under the down firing sub to “catch and soften the bass” or something is just that’s just not how it works.
post #22 of 50 Old 02-01-2020, 09:11 PM
Quoted: 297 Post(s)
Liked: 173
It didn't catch or soften the sound, it kept the wood floor from vibrating like a drum. Resonation. You could even tell the difference from under the house (3 foot off grade , 2 x12 framing, room 14x 25 I think.)
Music, more music.
post #23 of 50 Old 02-02-2020, 07:00 AM
Quoted: 593 Post(s)
Liked: 441
SVS sub too boomy
I’m not so much questioning the effect it had, but why; because you moved the focal point of the sound relative to the room a number of inches. If the acoustical energy is generating an enhanced room mode it will do that.
post #24 of 50 Old 02-03-2020, 09:26 AM
Craig Peer's Avatar
Quoted: 7599 Post(s)
Liked: 9364
Save the results.
This needs to be done every time Audyssey is run. It always sets my Motion 40's to large and my wide channel Motion LX16's to 40Hz. And using a boom mic stand to get the Audyssey mic right at ear level with it sitting on the floor has been the best $25.00 I've spent !
Craig Peer is online now
post #25 of 50 Old 02-03-2020, 02:19 PM
Sevenfeet's Avatar
Quoted: 370 Post(s)
Liked: 385
I'll be the first to agree with you on your main points. I'm a big critic of home theater/audiophile "hocus pocus". I've gotten into a lot of arguments online with people on the merits of various schemes to get better audio, especially in the age of digital audio/DACs (hey this "audiophile USB cable really works!").
But in this case, I was able to run my own test. Years ago when I was building my theater in the house we moved into, the den/theater was built over a garage. And I noticed that bass sounded really awful and I couldn't figure out why. After some time I realized that the problem might be a structural issue with the house so I played a test track that was bass heavy and sure enough, if I stood directly underneath in the garage, it was pretty pronounced and bouncing sound all over the concrete floor and/or metal cars parked there. Putting the sub on top of a table (for the purpose of the test) changed the situation dramatically. In the end, I used an Aurelex MoPad and that worked too (though not quite as well as the table).
Years later the sub broke (amp died) and I eventually replaced the amp but moved the sub (and it's MoPad) into a different 5.1 room. In this room, MoPad isn't as useful since there is a dirt surface 3 feet under the subfloor but since the sub is sitting off of the main carpeted area on a wood floor, it's better than the sub's bottom having direct contact with a hard surface. I also have a SVS SB13 Ultra in a 2 channel listening area (also on a hardwood floor) and I used the new subwoofer feet that SVS sells to get that sub off the floor with just the feet as contact points.
Bottom line? Your mileage will vary on this topic....A LOT. But it did work for me due to the specific nature of my house.
post #26 of 50 Old 02-03-2020, 02:25 PM
Quoted: 593 Post(s)
Liked: 441
My main point is that they can “work” but only as far as moving a sub a few inches in any direction will work. Moreover if you sub doesn’t have feet, rubber or thick felt etc, then this will provide a decent level seal to the floor. Most ID subs have proper mounting feet already. A very cheap hardware store trip will help if they don’t.
post #27 of 50 Old 02-04-2020, 05:02 PM
Quoted: 33 Post(s)
Liked: 2
I’m just going to say that a shiny hardwood surface makes a very noticeable reflection. Boom. Just raising the sub or placing it on something that cuts down the reflection right near the box makes a huge difference in the sound. Just placing a small carpet under the sub on a hard shiny floor will drastically affect the sound. Carpeted rooms sound very different than shiny hardwood floored rooms and concrete rooms sound different than these. Anything shiny reflects like glass.
New7.1 is offline
post #28 of 50 Old 02-04-2020, 06:35 PM
mbroadus's Avatar
Liked: 490
Do the SVS isolation feet work well on hard wood floors?
mbroadus is offline
post #29 of 50 Old 02-04-2020, 06:36 PM
Quoted: 593 Post(s)
Liked: 441
Work at doing what? What kind of sub?
post #30 of 50 Old 02-04-2020, 06:37 PM
Quoted: 593 Post(s)
Liked: 441
That’s not really how bass behaves.
18Hurts likes this.
