Dual sub for SVS PB1000...... - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 7 Old 02-09-2020, 06:40 AM - Thread Starter
jedviper's Avatar
Quoted: 16 Post(s)
Hi,
My living room size is approx.225 sq.fts., Currently I am using SVS PB1000 subwoofer since 2015, happy with the overall performance of this sub, but still it is not giving chest thumping bass….. now I am thinking of adding one more SVS PB1000… will it make a big difference? Will I get chest thumping bass?
but considering it’s current price, it is out of my budget…. What are other options left? and it should be a good match with SVS PB1000…..
jedviper is offline
post #2 of 7 Old 02-09-2020, 07:07 AM
eljaycanuck's Avatar
Quoted: 2030 Post(s)
Liked: 2887
A second PB-1000 will provide additional overall output, but not necessarily the level of mid-bass ("chest thumping bass") you seem to be looking for.
Before you buy another sub to solve the problem, have you exhausted other possible way of improving the performance of your current sub such as trying different placement relative to your main listening position (MLP)?
Also, how is your current sub set up (what are its controls set to)? Have you run your AVR's auto-cal program (Audyssey, MCACC, YPAO, etc.) and then bumped up the subwoofer level in the AVR's speaker set-up menu?
d-rail34 likes this.
eljaycanuck is offline
post #3 of 7 Old 02-13-2020, 06:44 AM - Thread Starter
jedviper's Avatar
Quoted: 16 Post(s)
current setting, Volume=3, Phase=0, LPF crossover =LFE
jedviper is offline
post #4 of 7 Old 02-13-2020, 09:05 AM
spyboy's Avatar
Quoted: 248 Post(s)
Liked: 189
Can you place your PB-1000 nearfield? That is, within 4 feet of the main listening position?
spyboy is online now
post #5 of 7 Old 02-13-2020, 11:14 AM
Quoted: 31 Post(s)
Liked: 53
Are you coming from car audio? Easy to get chest thumbing bass in a car. A good 10" sub can achieve that.
However, the inside volume of a car is no bigger than a walk-in closet. To get that kind of bass in a room requires A LOT of sub.
Sell your PB-1000 and get an HSU VTF-3 MK5. Plus it has different tuning options that you can tweak that could help you meet your goals.
raistlin65 is online now
post #6 of 7 Old 02-13-2020, 10:52 PM - Thread Starter
jedviper's Avatar
Quoted: 16 Post(s)
HSU VTF-3 MK5 is out of budget, any economical solution using PB-1000?
jedviper is offline
post #7 of 7 Old 02-13-2020, 10:56 PM
Ryan Statz's Avatar
Quoted: 796 Post(s)
Liked: 476
What are the settings in your AVR?
Home Theatre: Onkyo TX-NR747 (Pending: Marantz SR6014) | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is online now
