Would the SVA SB2000 be an upgrade over my HSU VTF-2 MK4? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By skylarlove1999
  • 1 Post By biglen
post #1 of 8 Old 02-12-2020, 02:42 PM - Thread Starter
biglen's Avatar
Quoted: 648 Post(s)
Liked: 121
My movie room is 13'x16' with 8' ceiling. Would the SVA be an upgrade?
Sent from my SM-N975U using Tapatalk
biglen is online now
post #2 of 8 Old 02-12-2020, 08:37 PM
skylarlove1999's Avatar
Quoted: 1496 Post(s)
Liked: 1210
I don't think it would be an upgrade . More of a lateral move. Same Size woofer and similar amplifier power. The Hsu will dig a little lower and probably provides little more room pressurization due to the two ports. The SVS probably is a little quicker responding. Think of a sharper slapping sound on a table with very little delay in response due to slightly higher quality components.
To really hear a difference when using SVS I believe you would need to go to the PB3000. If I were looking at subs around $1k I would be looking at this new sub from Power Sound Audio. I think it is on a 3 month back order right now . But you get a 60 day trial. More likely to want a second one after 60 days.
https://www.powersoundaudio.com/products/V1512DF
Sent from my SM-G965U using Tapatalk
rhelliott2 likes this.
skylarlove1999 is online now
post #3 of 8 Old 02-12-2020, 09:00 PM - Thread Starter
biglen's Avatar
Quoted: 648 Post(s)
Liked: 121
I meant the PB2000, not the SB2000. I'd want the ported version for movies. SVS has a great sale going on, and shipping is free. So the PB2000 wouldn't be an upgrade over the HSU?
post #4 of 8 Old 02-12-2020, 09:12 PM
Liked: 1210
The 2000 series SB or PB both have similar specs to your current subwoofer. Could the PB sound a little better? Maybe. I don't think you would be blown away by the difference. Generally you need more power with a bigger woofer to hear a significant difference. That isn't to say that a higher quality woofer of the same size and amplification with the same power but a better design couldn't provide a different sonic experience, but I don't know if most people could hear a difference.
post #5 of 8 Old 02-12-2020, 09:16 PM - Thread Starter
biglen's Avatar
Quoted: 648 Post(s)
Liked: 121
Gotcha. Thanks for the info !
skylarlove1999 likes this.
post #6 of 8 Old 02-12-2020, 09:29 PM
rhelliott2's Avatar
Quoted: 282 Post(s)
Liked: 498
Naw it would be about the same. If you want the next step up in subs then check out
http://jtrspeakers.com/
rhelliott2 is online now
post #7 of 8 Old 02-12-2020, 11:29 PM
confinoj's Avatar
Quoted: 1329 Post(s)
Liked: 1195
Extrapolating from Audioholics reviews of pb-2000 and vtf-2 mk5 and the fact that the mk4 is down about 2-3db from the mk5, the pb-2000 will be similar to the mk4 above 40-50hz but have a significant advantage in extension and low bass output up to about 3db at 20hz which is ~50% more output. So it would be a step up (but not a huge step up) for movie watching but not a difference for music. This is comparing 1 port closed on hsu for best extension.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | HDHomeRun Quatro | Nvidia Shield Pro 2019 | ATV 4K | Oppo UDP-203 | 40TB Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #8 of 8 Old 02-13-2020, 05:32 AM
Kothoga's Avatar
Quoted: 156 Post(s)
Liked: 212
This.
Theater: JVC RS540U, 2.35:1 142" screen, Onkyo RZ1100, Panasonic UB820, Outlaw Audio M2200 Monoblock x3, Klipsch RF7II, RC64II, RS62II, 5800CII x4 Atmos, PSA V3611 Subwoofer x2.
2 Channel: Parasound P6, Parasound A23+, Rega Planar 6 with Ortofon 2M Bronze, Klispch La Scala II.
Kothoga is online now
