Sub volume for setting up sub. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 3 Old 02-14-2020, 06:01 PM - Thread Starter
mikejl43's Avatar
I was wondering where I should set the sub volume when first setting up subwoofer . This would be the SVS pb2000 pro.
mikejl43 is online now
post #2 of 3 Old 02-14-2020, 06:51 PM
eljaycanuck's Avatar
Quoted: 2030 Post(s)
Liked: 2887
Start at "noon" (which, according to pg. 16 of the manual, would be -30dB).
d-rail34 likes this.
eljaycanuck is offline
post #3 of 3 Old 02-15-2020, 09:10 PM
d-rail34's Avatar
Quoted: 551 Post(s)
Liked: 1170
+1 to this! ^^^
Also, if you're using an AVR with room correction software (Audyssey, YPAO, AccuEQ, etc.), you want a post calibration sub trim (AVR) of about -10db. That way you have room to bump it up a few dbs, or lower it (who does this?? ) if so desired.
Keep in mind that if you run the room correction and the sub trim is somewhere around, say -5db, raise your sub's gain and re-run calibration until you reach the desired -10db range. If it's -12db (or more depending on what AVR you own), then lower the gain until you hit the -10db range.
Placement of your sub is also crucial, so I would also suggest that you Google "Sub Crawl". This will help you find the best location for your sub to help eliminate nulls that might occur at your MLP (Main Listening Position).
I know this might sound like alot of work, but this is what it will take to achieve the best results.
Hope this helps,
Darrell
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelf (4) w/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
Last edited by d-rail34; 02-16-2020 at 09:16 AM. Reason: Because my OCD wouldn't allow a spelling error...
d-rail34 is online now
