Distance from back wall for couch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-18-2020, 03:13 PM - Thread Starter
Quoted: 85 Post(s)
Liked: 69
Good evening everybody. Finally have all the pieces for our home theater so will be putting together this week. With the understanding that sub/speaker placement needs to be played around with some what would you say would be a good general distance/rule to start with for couch on back wall. I have the 10x11x9 room. I will also have some acoustic tiling hanging behind an old large map also hung on the wall directly behind couch/MLP. I am wondering if since the distance to speakers will be roughly 7' if having couch along back wall would be that big of a deal. I could move couch off back wall (also adjust L/C/R speakers back a foot or so up front too if necessary) up to say around 18-24 in. Thanks for any input you may have. Steve
Steve Huss is offline
post #2 of 3 Old 02-18-2020, 03:32 PM
Alan P's Avatar
Quoted: 6975 Post(s)
Liked: 6810
It is often recommended that the MLP (Main Listening Position) be away from the back wall 1/5th - 1/3rd the depth of the room. In your case if the 11' dimension is the depth, that would be 2.2'-3.6' from the back wall.
Your room is almost square...square rooms are notoriously bad for subwoofers. Are you planning on dual subs?
Alan P is offline
post #3 of 3 Old 02-18-2020, 03:43 PM - Thread Starter
Quoted: 85 Post(s)
Liked: 69
The 10' dimension is front to back portion of room. I will be running dual Rythmik F18's. So 2' for my ears off back wall would work yes? Thanks @Alan P
