Monolith M10-S for music? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-21-2020, 06:19 AM - Thread Starter
01svtL's Avatar
Quoted: 162 Post(s)
Liked: 45
All, moving into a smaller place. My main focus is music, and want to keep footprint to a minimum. I've seen GREAT feedback on the ported 10" Monolith, but don't know that I've seen much, if anything, on the sealed version. Is the Monolith considered a good option for music? I listen to rock/metal with fast double bass drums, so need the subs to be quick and accurate. I don't like the bass drums to blend together into a boomy mess. Also considered dual RSL Speedwoofers, but have seen several threads of people recommending the Monolith over the RSL - though I think that was more for overall output for home theater.
Martin Logan Motion 40 mains
HSU ULS-15 MK2 and SVS PC-2000
NAD T757 with AM200 audio card
01svtL is offline
post #2 of 6 Old 02-21-2020, 08:58 AM
Quoted: 2019 Post(s)
Liked: 1646
Rythmik L12.
Leave it at 8 ohms and call it a day :)
Russdawg1 is offline
post #3 of 6 Old 02-21-2020, 09:32 AM
Marc Alexander's Avatar
Quoted: 6110 Post(s)
Liked: 5668
Are you purchasing duals of whatever you end up deciding on? Do you have a budget limit?
I own the ported Monolith 10 (placed in our master bedroom).
Don't assume that the ported version is a boomy bloated mess compared to the sealed. It is not (it's a myth based on poorly designed ported subs of the past). In fact, there probably isn't any detectable difference in that regard as the Monolith 10-S is a derivative of the original ported 10 design.
I would reconsider the dual RSL Speedwoofers, the Monoliths, and also the Rythmik L12. No subwoofer I have listened to performs better with the most complex bass lines than the Rythmiks (without spending 2-3x the price).
http://rythmikaudio.com/
Marc Alexander is offline
post #4 of 6 Old 02-21-2020, 09:33 AM
Liked: 5668
Originally Posted by Russdawg1 View Post
Rythmik L12.
post #5 of 6 Old 02-21-2020, 07:35 PM - Thread Starter
01svtL's Avatar
Quoted: 162 Post(s)
Liked: 45
Yea I’m looking to run duals. I may even sell the Martin Logans and go with book shelves again; maybe LS50’s
01svtL is offline
post #6 of 6 Old 02-24-2020, 06:06 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2421 Post(s)
Liked: 3785
The SpeedWoofer 10S doesn't have any real weakness so that's a good option to consider. Anything Rythmik is a worthy contender. I don't know how the Monolith M10-S sounds but I do have experience with the M15-S. If the 10" variant is just a smaller version of the 15" that one is pretty solid too.
If you take yourself too seriously expect me to do the exact opposite
JimWilson is offline
