PSA S1812 v Deep Sea Mariana 18S v Seaton F18 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
  • 4 Post By blake18
  • 3 Post By madhuski
  • 1 Post By Gorilla Killa
  • 1 Post By eljaycanuck
  • 2 Post By basshead81
  • 1 Post By ClawAndTalon
  • 2 Post By Jeff Permanian
  • 1 Post By Jeff Permanian
  • 1 Post By Ccondo1
post #1 of 27 Old 02-24-2020, 03:07 PM - Thread Starter
Ccondo1's Avatar
Quoted: 236 Post(s)
Liked: 50
Considering an upgrade my current dual HSU VTF-15H MK2 setup. Considering dual PSA S1812s, Deep Sea Mariana 18S or Seaton F18s as possible choices... Any thoughts which is the best route to go? My focus isn't just the lowest of frequencies but tight, flat response. Thanks for any advice.
Ccondo1 is online now
post #2 of 27 Old 02-24-2020, 03:08 PM
blake18's Avatar
Quoted: 695 Post(s)
Liked: 402
I hate to say it, but Seaton has been having issues with fulfilling orders in a timely fashion. They seem to be struggling lately.
toddct, rhelliott2, flat4 and 1 others like this.
Lumenlab "Community driven video lab".
blake18 is offline
post #3 of 27 Old 02-24-2020, 03:40 PM
madhuski's Avatar
Quoted: 1560 Post(s)
Liked: 1020
i’d also add the Funk 18.0e and JTR RS1 to your list
flat4, toddct and Jeff Permanian like this.
madhuski is online now
post #4 of 27 Old 02-24-2020, 03:49 PM
tvuong's Avatar
Quoted: 2868 Post(s)
Liked: 2831
What’s lacking currently? What are you looking for that the vtf15 pair cannot provide? Are you more into music or movie? How big is your room? Do you have graph of your vtf15s? Depends on your answers, moving to sealed might not be an upgrade or might just be a lateral move.
tvuong is online now
post #5 of 27 Old 02-24-2020, 04:17 PM
Gorilla Killa's Avatar
Quoted: 1598 Post(s)
Liked: 2374
wait for it.....
d-rail34 likes this.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #6 of 27 Old 02-25-2020, 05:13 AM
eljaycanuck's Avatar
Quoted: 2044 Post(s)
Liked: 2930
Considering an upgrade my current dual HSU VTF-15H MK2 setup. Considering dual PSA S1812s, Deep Sea Mariana 18S or Seaton F18s as possible choices... My focus isn't just the lowest of frequencies but tight, flat response. …
The 960-watt S1812 seems seriously outmatched here. Although the F18+ w/ F18-Slave is the better value, personally I'd be all over a pair of DSS 18S subs.
Just my 2¢. YMMV, of course.
Matt37 likes this.
eljaycanuck is offline
post #7 of 27 Old 02-25-2020, 06:10 AM
ClawAndTalon's Avatar
Quoted: 653 Post(s)
Liked: 491
What are your room dimensions? Is it sealed off or open to other rooms? Any opening larger than a doorway is considered open to other rooms.
If you’re in a smallish medium sized sealed room, you will get some ultrasonics out of those sealed subs you couldn’t get with the HSU.
A. It won’t be anything like night and day, and only noticeable with some material.
B. You will lose some headroom at around 25-30 HZ.
C. IMO this would only be advisable if you are under or around ~2000 cubes. Sealed room, and plan on getting four subs eventually.
PS: I’d hold off on Seaton until he gets caught up, it is like 6 mos to 1 year waiting rn. All are great subs, PSA is cheapest of bunch by a grand, but no slouch, but consider the S1812 IPAL. The S3612 is the same price, as other two albeit larger.
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is offline
post #8 of 27 Old 02-25-2020, 06:35 AM - Thread Starter
Ccondo1's Avatar
Quoted: 236 Post(s)
Liked: 50
Honestly, the biggest factor is I want to decrease the footprint to allow more placement options. If I’m upgrading I want to make the best decision possible given the options
post #9 of 27 Old 02-25-2020, 06:37 AM - Thread Starter
Ccondo1's Avatar
Quoted: 236 Post(s)
Liked: 50
Room is 21L x 16.5W x 9.5H
Sealed room
post #10 of 27 Old 02-25-2020, 07:05 AM
basshead81's Avatar
Quoted: 372 Post(s)
Liked: 10609
I don't think it's seriously out matched at all. The BMS 18" driver(Similar in specs to the IPAL) hit 90db @ 10hz 2m rms. The standard B&C Neo 21" hit 90db(The 18 down 2db)... The S1812Ipal uses a similar size cab as Ricci uses in his sealed sub testing. The Mariana is using a smaller cab then Ricci used to test the HST-18. So I would put the standard S1812 down a couple db under 30hz to the F18 and HST, but the IPAL will likely be right there down low and both the NEO/Ipal will have the advantage up top. Moral of the story, I believe they all will have similar capability down low(+/-2db), but the Neo/Ipal will have the advantage up top. I don't think there is one choice better then the other...it all will come down to the type of sound you are looking for. Only way to know is order one of each and compare.
rhelliott2 and Mike Butny like this.
basshead81 is offline
post #11 of 27 Old 02-25-2020, 07:13 AM
Quoted: 653 Post(s)
Liked: 491
Sealed room
You’re just past the upper end of sealed performance in total room volume. Your longest dimension determines room gain. At 21’ that means room gain will start at 26 hz, and increase by 2-4 dB by 20hz, and exponentially on down.
The HSU subs are port tuned at ~22-25hz, likely providing more headroom at that range than the sealed subs, even with their roomgain, but the sealed subs still have quite a bit.
If you want ultrasonics, the sealed will give that where the HSU can’t, but you can get a taste for that by plugging the ports on the HSU and switching to sealed mode. You’ll also need a movie with ultrasonics. I like War of the Worlds where the alien ship comes out of the street.
From about 30hz and up the sealed subs will have more headroom but this won’t really be a factor unless you are running over reference and or loud.
All of these subs will give you tight flat bass before being over driven, the HSU included. The sealed subs will have more headroom above 30hz, but will only be realized if you were actually going over the headroom of the HSUs which is still quite a bit.
Have you thought about using REW to see exactly how you are performing?
post #12 of 27 Old 02-25-2020, 07:17 AM
tvuong's Avatar
Liked: 2831
Sealed room
That is >3200 cubic ft which considered to be a big room. Switching to sealed 18" could be a downgrade in output but if you do not listen that loud (we don't know), it does not matter. Out of the three, I have listened to the Seaton F18s, they sound fantastic.
post #13 of 27 Old 02-25-2020, 07:25 AM
tvuong's Avatar
Liked: 2831
22Hz is one tuning option of the VTF15, there is also a 16Hz port tuned option.
post #14 of 27 Old 02-25-2020, 08:27 AM - Thread Starter
Ccondo1's Avatar
Quoted: 236 Post(s)
Liked: 50
I’ve been running the HSUs with both ports plugged in an effort to avoid boomy bass, is that something I should revisit?
post #15 of 27 Old 02-25-2020, 08:30 AM
Quoted: 653 Post(s)
Liked: 491
The notion that sealed is tighter and ported more boomy is a myth.
I just realized you have VTF15, I misread that as VTF2. I wouldn’t upgrade to those subs in that case.
I would suggest REW, and MiniDSP, a $200 investment and use PEQ as needed.
Ryanosaur likes this.
post #16 of 27 Old 02-25-2020, 08:36 AM
Jeff Permanian's Avatar
Quoted: 946 Post(s)
Liked: 2215
The BMS 18m862's xmax spec is geometric, it has a 50mm tall voicecoil with a 12mm gap (50-12=38mm/2= 19mm overhang). The BC 18Ipal has a 44mm tall coil with a 12mm gap (44-12=32mm/2= 16mm overhang). The BMS has 3mm more overhang and Xmax since they have the same gap.
jamiebosco and Kini62 like this.
Jeff Permanian is offline
post #17 of 27 Old 02-25-2020, 08:42 AM
tvuong's Avatar
Liked: 2831
IMO, even though the VTF15 has an option to run as sealed with both port plugged, I wouldn't buy it to run it as such. I would try to set them in 16Hz mode (1 port open), adjust your Q control and phase (if necessary) and re-run audio calibration. Do you have graph(s) of your subs?
post #18 of 27 Old 02-25-2020, 08:45 AM
Quoted: 653 Post(s)
Liked: 491
Originally Posted by Gorilla Killa View Post
wait for it.....
Right?!
It’s posts like this which help ensure that my block/ignore list is proper.
Gorilla Killa likes this.
post #19 of 27 Old 02-25-2020, 07:23 PM
basshead81's Avatar
Quoted: 372 Post(s)
Liked: 10609
Thanks for that...I thought the Xmax on the Ipal was 19mm.
post #20 of 27 Old 02-25-2020, 07:51 PM
Quoted: 946 Post(s)
Liked: 2215
You always have to read the fine print when it comes to speaker specs. The 18Ipal spec of 19mm isn't geometric or overhang but overhang plus 25% of the gap (25% of 12mm) which is 3mm (16+3=19mm). Drivers with gaps less than about 0.75" usually end up with a 30% down of bl (10% distortion) when the coil is 25% of the way through the gap. Drivers with gaps greater than about 0.75" usually end up with a 30% down of bl when the coil is 30% of the way through the gap. The BMS with the xmax spec'ed the same as the 18Ipal would be 22mm.
basshead81 likes this.
post #21 of 27 Old 02-25-2020, 08:11 PM
Sorny's Avatar
Quoted: 100 Post(s)
Liked: 117
Tight flat response? Save your money and do the MiniDSP 2x4HD, UMIK-1, and REW routine as suggested by others. Try running EQ1 and 1 port, or EQ2 and both ports also. Running sealed defeats the purpose of the enclosure size and ports on the VTF-15H Mk2...
**edited to remove comments on the V1812 that don't apply to the S1812.
MiniDSP 2x4HD, UMIK-1, REW... The holy trinity for running multiple subs.
Sorny is online now
post #22 of 27 Old 02-25-2020, 08:20 PM
tvuong's Avatar
Liked: 2831
^^ He is asking about the sealed 1812 denoted by the letter S in the model name, not the ported v1812.
post #23 of 27 Old 02-25-2020, 08:53 PM
Sorny's Avatar
Quoted: 100 Post(s)
Liked: 117
Good catch, I totally spaced S instead of V, thanks.
My advice about miniDSP, Umik-1 and REW still stands.
If getting smaller subs for more placement options, speaking of box size, not driver size, then I'd also recommend going with 4 subs instead of 2 in addition to the MiniDSP 2x4Hd, Umik-1, and REW.
Sorny is online now
post #24 of 27 Old 02-26-2020, 06:39 AM - Thread Starter
Ccondo1's Avatar
Quoted: 236 Post(s)
Liked: 50
I already use a MiniDSP HD and UMIK and REW. I’ll see if I can dig up my curves later. I would like more room placement options (namely front corners or one in back) but maybe this is just a symptom of upgraditis and I should be happy with my current setup... Though I could swap out my cheap Polk Atmos speakers for some RSLs.... 😜
Bruce N likes this.
post #25 of 27 Old 02-26-2020, 08:47 AM
Quoted: 653 Post(s)
Liked: 491
Have your tried running a sweep with your subs? The corner vs where they are? Just move furniture enough to get them in there for testing purposes.
The best thing is to find your first placement that is flattest. Corners do tend to work best for most folks. Second is to find a place for sub number two which compliments any dips in sub number one.
Sight unseen I’d want a front corner and an opposing back corner.
Also, most of those subs are wider but just less deep. I’m not sure you’d gain much real estate but I can’t see what you can. Keep in mind a sub doesn’t have to be pointed at you.
post #26 of 27 Old 02-26-2020, 09:14 AM - Thread Starter
Ccondo1's Avatar
Quoted: 236 Post(s)
Liked: 50
Can I turn them 90 degrees sideways and not impact the sound at all?
post #27 of 27 Old 02-26-2020, 10:00 AM
Quoted: 653 Post(s)
Liked: 491
You can point them in any direction you want. As long as the driver and or ports have about 2-3” (yes inches) clearing from walls. Any movement of the sub can effect on sound though. But as a matter of practice pointing the sub at you is never strictly necessary
Bass is generated inside the subwoofer, usually around the motor of the driver and inside the port, and spreads out omnidirectionally. Think of it as a light leaving a round light bulb. Does it matter if it’s pointed at you or the side of the bulb?
I bet your have your subs are firing at you, rn? Don’t worry, I see it all the time. But it’s totally unnecessary to do that.
