SVS pb16 ultra or rythmik fv15hp - AVS Forum | Home Theater Discussions And Reviews
 15Likes
  • 1 Post By jamiebosco
  • 2 Post By basshead81
  • 6 Post By basshead81
  • 1 Post By darthray
  • 1 Post By liverpool_for_life
  • 3 Post By tvuong
post #1 of 16 Old 03-20-2020, 01:53 AM - Thread Starter
annapl's Avatar
Quoted: 62 Post(s)
im in confusion between SVS pb16 ultra and rythmik fv15hp
i now have dual pb2000 which i feel great for movies and it lacks midbass chest slam
what i need is chest slamming bass
suggest me between SVS pb16 ultra and rythmik fv15hp
annapl is offline
post #2 of 16 Old 03-20-2020, 02:31 AM
jamiebosco's Avatar
Quoted: 953 Post(s)
Liked: 2481
Fv15HP out of those 2 choices. PB16U will have a decent performance advantage under ~30Hz, but not enough to justify the very large price delta - IMHO
The PB16U is great - but much more expensive than the FV15HP, in fact you should probably be comparing the FV25HP to the PB16 ($$wise) - the FV25 has a tonne more midbass slam over the PB16U and slightly better deep bass performance to boot
darthray likes this.
TV: Panasonic 65" P65ST60 AVR: Denon AVR-X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Seaton SubMersives x 3
jamiebosco is online now
post #3 of 16 Old 03-20-2020, 04:55 AM
basshead81's Avatar
Quoted: 371 Post(s)
Liked: 10564
Value wise the Rythmik is a better offering imo and stronger below 16hz but the SVS is no slouch.
I would also consider the FV18, JTR Cap 2400, and especially the PSA TV3612 if you are wanting chest slam and strong ULF.
There is a thread where a member compared the PSA TV3612's to the PB16's that you might want to check out. Last page has some YT videos.
https://www.avsforum.com/forum/113-s...l#post59365104
darthray and rhelliott2 like this.
basshead81 is offline
post #4 of 16 Old 03-20-2020, 05:57 AM - Thread Starter
annapl's Avatar
Quoted: 62 Post(s)
i am not buying new my friends are selling these subs i am having confusion in picking one of the subs svs pb16ultra or rythmik fv15hp
i need more chest slam
annapl is offline
post #5 of 16 Old 03-20-2020, 06:41 AM
basshead81's Avatar
Quoted: 371 Post(s)
Liked: 10564
I would lean towards the FV15HP, but there are some things I would look into first because it might not be a sub issue.
Have you measured your room response to what it looks like? You could easily have a dip or cancellation in the frequency response killing your midbass around the crossover region. It's pretty common and often the subs get blamed when the problem is a setup and/or placement issue.
post #6 of 16 Old 03-20-2020, 06:53 AM
darthray's Avatar
Quoted: 2545 Post(s)
Liked: 4165
The FV15, as the single band PEQ option. I use this setting on my FV18's, for the same reason and work well for me. That said the FV15, is more comparable to the PB4000. And the SVS also have an app, where you should be able to boost those frequencies.
My suggestion, since you are buying from a friend. Is trying both at home in your own environment, to see what sub work better for your need.
While they are bulky and heavy, it might be worth you're time.
Both subs are great, and each have there own advantage. Another option to look at, would be the offering from PSA if you decide to buy new;
https://www.powersoundaudio.com/pages/subwoofers
They are know to be very strong in the mid frequencies, where the chest slam occur.
Darth
basshead81 likes this.
darthray is offline
post #7 of 16 Old 03-20-2020, 08:02 AM
Quoted: 79 Post(s)
Liked: 40
+1. If this issue is not ruled out, one can end up chasing one's tail.
liverpool_for_life is offline
post #8 of 16 Old 03-20-2020, 11:40 PM - Thread Starter
annapl's Avatar
Quoted: 62 Post(s)
i have no idea how to measure in room response any guides?
annapl is offline
post #9 of 16 Old 03-21-2020, 12:08 AM
torii's Avatar
Quoted: 4122 Post(s)
Liked: 2403
to measure a room...most download free software called room eq wizard REW....have a laptop with usb....and buy a specific mic like umik 1.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #10 of 16 Old 03-21-2020, 12:09 AM
torii's Avatar
Liked: 2403
another way to measure room is free by using test tones and spl app on phone. play a test tone and plot spl on graph paper from 10-500 or whatever...
torii is offline
post #11 of 16 Old 03-31-2020, 11:37 AM - Thread Starter
annapl's Avatar
Quoted: 62 Post(s)
lets forget price if choice is between only SVS pb16 ultra and rythmik fv15hp what should i choose?
annapl is offline
post #12 of 16 Old 03-31-2020, 11:50 AM
imureh's Avatar
Quoted: 3309 Post(s)
Liked: 4381
They will be close thought I think the Rythmik may dig deeper. A better comparison would be the FV18 and still save you a chunck of cash. Are you limited by space? especially height wise?
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #13 of 16 Old 03-31-2020, 12:01 PM
tvuong's Avatar
Quoted: 2865 Post(s)
Liked: 2820
Darth
^^ This. Easiest way to find out for yourself. Nobody here knows for sure which one is better for YOU in YOUR room
tvuong is online now
post #14 of 16 Old 04-01-2020, 07:55 AM
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
How big is the room ?
Have you tried moving one of the PB2000 directly behind your chair ?
qguy is online now
post #15 of 16 Old 04-01-2020, 11:34 AM
Liked: 0
I would go with the 16 ultra. I’ve demoed them side by side and it is was a pretty noticeable difference. The SVS seemed to move a ton of air and has awesome accuracy.
Audiohobb is online now
post #16 of 16 Old 04-01-2020, 12:43 PM
qguy's Avatar
Quoted: 308 Post(s)
Liked: 170
Something to consider, SVS cost $2500 vs Rythmiks $1400, Once you factor the discount for 2 Rythmiks, I think you can get 2 Rythmiks for the price of one SVS
EDIT: I missed the buying used part, if buying used and cost is not an issue, the SVS should have an advantage as it is the bigger subwoofer. Do a demo and buy the one that you like.
qguy is online now
