Tiniest 2020 subwoofer to mount on a gangsta bling pendant - AVS Forum | Home Theater Discussions And Reviews
 27Likes
  • 3 Post By bear123
  • 2 Post By JD23
  • 1 Post By bobknavs
  • 2 Post By qguy
  • 5 Post By bobknavs
  • 3 Post By JD23
  • 2 Post By johnson636
  • 1 Post By the7mcs
  • 1 Post By MATTHEW PATIENT
  • 7 Post By rboster
post #1 of 23 Old 03-22-2020, 08:55 AM - Thread Starter
Liked: 0
Cool Tiniest 2020 subwoofer to mount on a gangsta bling pendant
1. less than 70 euros, 75 bucks.
2. It's for a big hollowed metal printed pendant* for a male bling chain. It will portray a female face and the subwoofer will be on the forehead, I can resize the 3d model so the subwoofer will fit perfectly. Give me several latest tiniest subwoofer names and I'll check them out.
3.I will also have to have a mini portable charger (anyone knows if a tiny battery or charger is better then this charger?)
Search Amazon for:" Dual USB Output Super Slim Power Bank Ultra Thin, Attom Tech 3000mAh Portable Charger Mini External Phone Battery Pack Small Dual Outlet,Emergency Phone Power Backup "
4. what's the best 3dDprinted material for resonance? Metal? Should it be hollowed out?
Give me the tiniest subwoofer links that will make noise please! This bling is going to rock! my name is Niu_Davinci on instagram, ill post the piece when it's done.
Check this out: The bling will have a whole on it's mouth just so the client can vape trough the pendant , so as to go Viral!
Niu DaVinci is offline
post #2 of 23 Old 03-22-2020, 08:57 AM - Thread Starter
Liked: 0
Forgot to mention it has to have bluethooth!!
post #3 of 23 Old 03-22-2020, 02:27 PM
bear123's Avatar
Quoted: 3226 Post(s)
Liked: 4836
I can't even begin to explain how lost I am.
bear123 is offline
post #4 of 23 Old 03-22-2020, 03:05 PM
Quoted: 33 Post(s)
Liked: 43
I'm not sure I follow whatever this is. Is it a subwoofer? Pendant? Vape? I'm so confused. Please elaborate.
Receiver: Onkyo TX-NR656
Speakers: Sony Core x7
Subwoofers: PSA V1510DF, Polk PSW505
Sn1per666 is offline
post #5 of 23 Old 03-22-2020, 05:25 PM
JD23's Avatar
Quoted: 748 Post(s)
Liked: 449
Is COVID-19-induced hysteria causing me to hallucinate? Is this real?
JD23 is offline
post #6 of 23 Old 03-22-2020, 08:33 PM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 368 Post(s)
Liked: 160
I think you just want a tiny bluetooth cube speaker that looks like a subwoofer - it certainly won't be a subwoofer.
Sony SRS-X11 might fit the bill - looks like a tiny subwoofer when you take the grille off.
niterida is online now
post #7 of 23 Old 03-22-2020, 08:37 PM
bobknavs's Avatar
Quoted: 2663 Post(s)
Liked: 1897
Hard to tell. People do some odd things.
Craig Peer likes this.
bobknavs is online now
post #8 of 23 Old 03-23-2020, 06:36 AM
darthray's Avatar
Quoted: 2521 Post(s)
Liked: 4094
The way I read the OP post, he is trying to get some members to purchase. A product that he have an idea for, made from a 3D printer. And is a big No No on this forum.
Darth
darthray is offline
post #9 of 23 Old 03-23-2020, 08:07 AM
qguy's Avatar
Quoted: 302 Post(s)
Liked: 166
I would like to have whatever the OP is having right now pls PM if is not legal
qguy is offline
post #10 of 23 Old 03-23-2020, 12:12 PM
craig john's Avatar
Quoted: 1443 Post(s)
Liked: 1743
I think it also needs a flashlight and magnifying glass so you find certain things in the dark.
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence.
My System
(Edited Feb. 2020 to add 4K and Atmos updates)
craig john is offline
post #11 of 23 Old 03-23-2020, 12:31 PM
Quoted: 2005 Post(s)
Liked: 1643
Needs to have a phone app too!
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #12 of 23 Old 03-23-2020, 01:17 PM - Thread Starter
Liked: 0
Bass dudes
Dam, this forum doesn't let me post links
Bass dudes, It's just a Big Bling pendant in the form of a face ( with no hair, hot female face ) with a tiny subwoofer on it's Forehead!
WHY:because It's a project for me to sell and wear myself, I often use a boombox which I have to carry on the hand, this way I'm handsfree!
Anyway, I found this tutorial, any better subwoofer than the one he uses? search "DIY Mini Bluetooth Subwoofer RC CAR SUB" on youtube so you know what I'm talking about.
PS:It has a hole on the mouth so you can vape trough the back of the sculpture and it makes a cool video for instagram.Forget that.
So is there a smaller subwoofer than the one mentioned in the youtube video, the 40mm diameter one? Maybe I could use a smaller one.
post #13 of 23 Old 03-23-2020, 01:17 PM - Thread Starter
Liked: 0
It's bluetooth dawg, see it on youtube
post #14 of 23 Old 03-23-2020, 01:40 PM
craig john's Avatar
Liked: 1743
A "handsfree" subwoofer mounted on the forehead of a bald female face for a male bling chain??? You could make the vaping port be her mouth! I bet they'd sell like hotcakes! Adding a flashlight and magnifying glass would really take it over the top.
Let us know before you take the stock public. I want in on the IPO.
Lombardi said it:
My System
post #15 of 23 Old 03-23-2020, 02:03 PM - Thread Starter
Liked: 0
this old forum stinks of troll piss, i'm out
post #16 of 23 Old 03-23-2020, 03:00 PM
bobknavs's Avatar
Liked: 1897
A tragedy.
Sn1per666, drh3b, Sorny and 2 others like this.
post #17 of 23 Old 03-23-2020, 03:02 PM
JD23's Avatar
Quoted: 748 Post(s)
Liked: 449
I'll trade you two rolls of toilet paper and one Clorox wipe for the subwoofer pendant.
rboster, Craig Peer and sigpig like this.
JD23 is offline
post #18 of 23 Old 03-23-2020, 05:33 PM
johnson636's Avatar
Quoted: 1500 Post(s)
Liked: 987
What the Hell did I just read
d-rail34 and Craig Peer like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #19 of 23 Old 03-23-2020, 11:00 PM
the7mcs's Avatar
Quoted: 527 Post(s)
Liked: 235
Ever heard of the show shark tank?
I’m sure one of those billionaires on that show will fund this idea for you
the7mcs is online now
post #20 of 23 Old 03-24-2020, 12:41 AM
Liked: 8
Do you think the transient response will be quicker than a 18 inch woofer
Dootinn is offline
post #21 of 23 Old 03-24-2020, 03:43 AM
Quoted: 145 Post(s)
Liked: 153
PB-4000.
gonna need a really really big chain around the neck though.
LG 55C8, Pioneer Elite VSX-LX503, Panamax M5400, Microsoft Xbox One X, Nvidia Shield Pro
Definitive Technology: BP9060 Front left/right/CS9040 center/A90 front Atmos/ProMonitor 1000 rear Atmos/Mirage: MX bookshelves rear left/right
Rythmik FVX15
MATTHEW PATIENT is offline
post #22 of 23 Old 03-24-2020, 05:14 PM
RayGuy's Avatar
Quoted: 3310 Post(s)
Liked: 3111
Wow, talk about not knowing your audience!
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #23 of 23 Old 03-24-2020, 05:23 PM
Moderator
rboster's Avatar
Quoted: 1720 Post(s)
Liked: 2509
I did look up "troll piss" and much like a cough or sneeze it can carry the coronavirus. That being said, we are disinfecting the entire site to control the spread of the virus due to the spread of troll urine on the site.
Pardon our mess
rboster is offline
bling , gangsta , subwoofer , tiniest , tiny
