Wiring help - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bobknavs
post #1 of 7 Old 03-23-2020, 06:28 PM - Thread Starter
Liked: 0
Wiring help
I bought a subwoofer(500w) that has two 2 ohm voice coils, I wired them in series, making it run at 4 ohms, but I need it to run at 2 ohms because thats where my amp puts out its most power(600w)
can I plug each coil directly into each sub output on the amp?
the amp im using is a jbl gtr-601
If possible id rather not have to return it and swap it, but if I have to I can
Khaner is offline
post #2 of 7 Old 03-23-2020, 06:34 PM
darthray's Avatar
Quoted: 2537 Post(s)
Liked: 4146
This would result to have a 1 ohm load, that is very difficult for any Amp. That said so is 2 ohm.
Is this for a DIY project?
If so you will be getting better answers, to repost in here;
https://www.avsforum.com/forum/155-diy-speakers-subs/
If a car project, here;
https://www.avsforum.com/forum/160-car-audio-video-nav/
Darth
darthray is offline
post #3 of 7 Old 03-23-2020, 09:28 PM
bobknavs's Avatar
Quoted: 2672 Post(s)
Liked: 1903
Darth
It's a car amp. (Class D.) Possible to use it in home, but unlikely.
Connecting two 2 ohm loads to it is not recommended. They are paralleled, giving (as you posted) 1 ohm.
darthray likes this.
bobknavs is online now
post #4 of 7 Old 03-23-2020, 10:01 PM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 380 Post(s)
Liked: 163
I am going to assume he is installing this in a car.
But the answer is still "No it can't be done" because the amp is a mono amp and what appears to be 2 outputs is only actually one.
niterida is online now
post #5 of 7 Old 03-24-2020, 03:08 AM
Wayne A. Pflughaupt's Avatar
Quoted: 480 Post(s)
Liked: 410
As you know, the amp will run at 4 ohms or 2 ohms. If you want to operate both VCs for 600 watts, you’re going to need a second amplifier.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #6 of 7 Old 03-25-2020, 05:09 AM
mustang guy's Avatar
Wayne A. Pflughaupt
And if you want to run at 2 ohms, you will need to buy a second driver.
mustang guy is offline
post #7 of 7 Old 03-25-2020, 06:17 AM
Quoted: 480 Post(s)
Liked: 410
How do you figure that, since the driver has two 2-ohm voice coils? I’m not up on the latest car audio stuff, so I might be missing something.
Wayne A. Pflughaupt
Equipment List
