Svs vs monolith. Single vs dual. - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By qguy
post #1 of 11 Old 03-25-2020, 07:57 PM - Thread Starter
Liked: 0
New to the forum, but have already found great advice and info. I recently started my first real setup with klipsch rp280s and the rp-450 center. Now I just need the deep end. My budget is 900-max 1000 and unfortunately it has to be from Amazon. My room is 12 x 23 with my projection screen on the 12' wall and main seating position about 9 ft away. Lvp flooring over concrete. No treatment right now. I'm really the only one that will be in there so m I'm not super super concerned with making sure other seats have equal bass as the mlp. I'm currently trying to decide between a pb-2000 pro or the monolith 12. Dual pb-1000s or dual monolith 10s is also an option. I'm coming from a Vizio soundbar + sub and I haven't really experienced a real sub in a home theater, let alone a dual setup. Which would you recommend between the 4 options? I want something clean, that can go deep and kick me in the chest! And I probably won't be able to upgrade for a while. Thanks in advance.
Subluco is offline
post #2 of 11 Old 03-25-2020, 08:01 PM - Thread Starter
Liked: 0
Oh, and I'm Running a Yamaha TSR-7850R, if that matters
Subluco is offline
post #3 of 11 Old 03-25-2020, 08:19 PM - Thread Starter
Liked: 0
Sorry for the spam posts but forgot to mention: ceiling height is 8'. 65% movies 35% music. Also, with a 1year old, I don't expect to be anywhere close to reference level on a daily basis. But looking forward to cranking it up once in a blue moon.
Subluco is offline
post #4 of 11 Old 03-26-2020, 08:12 AM
qguy's Avatar
Quoted: 307 Post(s)
Liked: 168
I like SVS, I have the PB12-NSD, but the specs on the Monolith 12 is 1 level above the PB2000. The only advantage that I see here is SVS's legendary customer support
mthomas47 and drh3b like this.
qguy is offline
post #5 of 11 Old 03-26-2020, 08:51 AM
Quoted: 119 Post(s)
Not to pry but why is amazon the only option?
EDIT:
As to your other question, I would always do dual over 1 if you are worried about more than just how loud it will be.
badtlc is offline
post #6 of 11 Old 03-26-2020, 09:47 AM - Thread Starter
Liked: 0
Amazon is my only choice because I have a lot of store credit. Otherwise I'd probably go hsu, as that seems like the most recommended subs on here.
Subluco is offline
post #7 of 11 Old 03-26-2020, 10:49 AM
Quoted: 119 Post(s)
You are around 2,200cuft. That is a decent sized room.
If you can do a 30 day test with free return, I would recommend starting with (2) PB-1000 and see how you like it. It will give you as much or more output as (1) PB-2000 but it will give you a more level and even response through the bass range and throughout the room if you decide it matters.
badtlc is offline
post #8 of 11 Old 03-26-2020, 11:30 AM - Thread Starter
Liked: 0
Thanks for the advice. Is there a huge difference between the pb-2000 and the newer pro model with the high excursion driver?
Subluco is offline
post #9 of 11 Old 03-26-2020, 11:52 AM
anaththeanswer89's Avatar
Quoted: 51 Post(s)
Liked: 34
Highly recommend SVS. I have two PB-2000s and they are a dream.
R55Ti Tower Speakers x2 | R5Bi Bookshelf Speakers x2 | R56Ci Center Channel Speaker | SVS PB-2000 x2 | RBH A607 x4 for atmos | Yamaha RX-A2050 | Sony VPL-45ES | Carada 126" BW Screen
anaththeanswer89 is offline
post #10 of 11 Old 03-26-2020, 12:24 PM
Quoted: 119 Post(s)
I apologize for not knowing the answer to your question. Hopefully an SVS expert will chime in.
badtlc is offline
post #11 of 11 Old 03-26-2020, 12:31 PM
mylan's Avatar
Quoted: 249 Post(s)
Liked: 218
The Pro has an additional 50 watts, an extra port, and is app controlled, having heard neither would imagine still that there is a perceptible difference.
mylan is offline
