Which Subwoofer Cable Should I Use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-26-2020, 05:35 AM - Thread Starter
Quoted: 109 Post(s)
Liked: 27
I am going to setup a miniDSP for my 4 subwoofers. So I need another long cable for one of my rear subwoofers bc they are currently split off of one cable. I usually use Monoprice or Blue Jeans but amazon is showing delivery dates like a month out. So I ordered one from PartsExpress along with the minidsp. It’s an Audtek 25 ft rca cable. I’m sure it’s fine but I remembered that I already have a spool of quad shielded rg6, and I can get some compression connectors from the store. The cable will be run in my soffit and it’s a pain in the ass to access so I’m not looking to do it a second time. There is some high voltage wires in there also for recessed lights and for the projector outlet. So I’m just curious if anyone has an opinion on if one is a safer bet than the other or if I should just use whatever is easiest.
Marantz SR7011 | Marantz MM7025 | Outlaw 5000 | Klipsch RP 8000 | Klipsch RP 504C | Klipsch RP 502S | Klipsch RP 5000 | Klipsch CDT 5650 | Polk V60 | Klipsch SPL 120 (2)|
HSU VTF3 MK5 (2) | Crown XLS 1002 | Buttkicker LFE Mini (4) | Eaton 5PX 1500|
JVC RS1000 | Silver Ticket 120” 16x9| Panasonic UB820 | Apple TV 4K | URC MX 450
dwander is offline
post #2 of 4 Old 03-26-2020, 05:54 AM
corwiniii's Avatar
Quoted: 44 Post(s)
Liked: 106
I'm not an expert, but I've had great success with the coaxial cable, especially in wall since it's usually rated for that with the shielding. So that's always my preference when I can do it for runs in wall. Also, when I'm taking the time to pull wires, I always tack on an extra string/cord for future use. I've learned it's helpful for that future wire pull to the same or nearby location.
Good luck.
Klipsch RP-8000F L/R | Klipsch RP-504C C | Rythmik FV18 Rev2 Paper Cone Black Matte + Elemental Designs A5-350 Restored! | Denon AVR-S920W | Vizio P75-C1
corwiniii is offline
post #3 of 4 Old 03-26-2020, 06:25 AM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 380 Post(s)
Liked: 163
Originally Posted by dwander View Post
I already have a spool of quad shielded rg6.
I think you just answered your own question
I just went through a similar quest. From my reading the only time you really need RG6 is when you are running it near power lines.
Otherwise the most important issue for RCA is the quality of the connector as long as the cable is of reasonable quality itself.
niterida is offline
post #4 of 4 Old 03-26-2020, 06:52 AM - Thread Starter
Quoted: 109 Post(s)
Liked: 27
Sounds like the way I will go. Im not too confident in the connectors I just bought but I can always get better ones and swap them in later on.
dwander is offline
