Rythmik fv18 rumble filter question - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By imureh
  • 1 Post By enricoclaudio
post #1 of 24 Old 03-27-2020, 04:06 PM - Thread Starter
Quoted: 56 Post(s)
Liked: 27
I have dual fv18s and I use them mostly for movies should I leave rumble filter on or off?
Xcakez is offline
post #2 of 24 Old 03-27-2020, 05:19 PM
darthray's Avatar
Quoted: 2634 Post(s)
Liked: 4410
ON, as recommended by the instructions on the quick Guide. And also having dual FV18, with the Aluminum drivers. And been mostly Movies like you, I would also set the Limiter to On. Since the recording vary so much, and some of them been on the hot side
Darth
darthray is offline
post #3 of 24 Old 03-27-2020, 06:17 PM
imureh's Avatar
Quoted: 3499 Post(s)
Liked: 4715
You can turn if off unless you are playing EoT intro at reference levels. You will have enough headroom with dual FV18s to run with the rumble filter off. The limiter is the one that needs to be on all the time.
jamiebosco likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #4 of 24 Old 03-27-2020, 06:26 PM - Thread Starter
Quoted: 56 Post(s)
Liked: 27
ok limiter is on and I never listen at refrence level for anything that's just crazy loud for me
Xcakez is offline
post #5 of 24 Old 03-27-2020, 06:35 PM
imureh's Avatar
Liked: 4715
You should have no problems with turning the rumble filter off
post #6 of 24 Old 03-27-2020, 09:18 PM
Liked: 26
Me running dual FV18, with the Aluminum drivers.
Followed the guide filters on.
Cheers
100% HT Lover 2.35:1 150' CYRUS Phantom Grey MK II 4k/UHD
BenQ W2700 4K HDR Source: Oppo 203 & Zidoo Z9S
1996 Sunfire Cinema Grand l Denon AVR-X4400H Pre-out @7.2.4
M&K Sound LCR950 THX Select2 Series Dual Rythmik FV18s @900WRMS ea aluminum cone
Dual Sunfire True Subwoofer EQ Sub 5: HSU Research MBM-12 MK2 (nearfield)
ronnlim is offline
post #7 of 24 Old 03-28-2020, 02:26 AM
Liked: 26
Cheers
Both Filters OFF now with low damping!
ronnlim is offline
post #8 of 24 Old 03-28-2020, 07:43 AM
jsc79's Avatar
Quoted: 563 Post(s)
Liked: 824
Are you running yours off? Reason I ask is I know you run yours hot and do BEQ(I do both as well).
In my open floor I’m flat to 14hz and I ran some sweeps with it off and it does make a significant improvement for me. Just a little timid on the possibility of damaging the subs.
I’m not a EOT intro at reference type. I’m running 2 port mode +8 hot with MV -10 at the highest.
jsc79 is online now
post #9 of 24 Old 03-28-2020, 08:30 AM
imureh's Avatar
Liked: 4715
Yep mine has been off since day one. No issues at all and I don't think you will either.
post #10 of 24 Old 03-28-2020, 08:36 AM
jsc79's Avatar
Quoted: 563 Post(s)
Liked: 824
I’m gonna go for it and see what it “feels” like. Lol
jsc79 is online now
post #11 of 24 Old 03-28-2020, 10:44 AM
Liked: 26
Yah bro got to try it.
I have a Rythmik f18 dude shared with me he had off it since he owned Rythmik 12, 15 and now thriple F18s. Now he's on low damping.
Me running Dual @2 port mode + 12db hot with MV -15 to -18 with Rumble filter off + Low damping which can go deepest with extension.
Next is to try the PEQ on mode with +3Gb Gain.
ronnlim is offline
post #12 of 24 Old 03-28-2020, 10:45 AM
Liked: 26
Bro if you dont mind, how about your PEQ Mode on your Dual FV18s.
Thank you.
Ron
ronnlim is offline
post #13 of 24 Old 03-28-2020, 10:48 AM
imureh's Avatar
Liked: 4715
Thank you.
Ron
Hey Ron, yeah I have the PEQ on as well for the extra +3db at 63hz. I also have a minidsp that I have used to get a nice house curve as well as an optimized FR. That has made a bug difference in how the subs sound now.
Ray
post #14 of 24 Old 03-28-2020, 11:31 AM
Liked: 26
Ray
wow fantastic.
Same dude told me to set at PEQ on as well for the extra +3db and in between at 50hz and I am going to test it tomorrow. Really appreciate his advice and yours too.
Wonder how sustainal difference since we r both using FV18. Midbass running hotter?
And volume level? I at 1 o'clock
Thanks so m appreciated Ray. Helpful bro.
ronnlim is offline
post #15 of 24 Old 03-28-2020, 11:35 AM
tvuong's Avatar
Quoted: 2958 Post(s)
Liked: 3001
^^ How do they sound?
tvuong is online now
post #16 of 24 Old 03-28-2020, 12:00 PM
imureh's Avatar
Liked: 4715
wow fantastic.
Sure, no worries my friend. Do you have paper cones of alu ones? I run my bass pretty hot like +12db plus I have house curve and I use BEQ! My gains are at 2pm. Since I using minidsp to boost certain frequencies it may not be an apples to apples comparison to yours. I was shooting for a 92-94db combined spl at MLP for the subs which puts them about +12db from where Audy set them for a -10.5db trim level in AVR
post #17 of 24 Old 03-28-2020, 01:00 PM
corwiniii's Avatar
Quoted: 87 Post(s)
Liked: 224
Are we talking just in a dual sub scenario turning rumble off? Or even in single sub scenario? I've kept mine enabled out of fear, and generally just following directions. My second sub isn't helping much at all below 20Hz. But while my sub + house curve is hot, I don't get past -10MV on my Denon AVR.
Klipsch RP-8000F L/R | Klipsch RP-504C C | elemental Designs A6-6T6 MTM surrounds | Rythmik FV18 Rev2 Paper Cone Black Matte + Elemental Designs A5-350 Restored! | Denon AVR-S920W | Vizio P75-C1
corwiniii is offline
post #18 of 24 Old 03-28-2020, 02:17 PM
imureh's Avatar
Liked: 4715
You should be just fine turning it off as well.
post #19 of 24 Old 03-28-2020, 09:04 PM
Liked: 26
Many thanks for u fast sharing.
Ray bro, I am running Dual Aluminum drivers
Me running Dual @2 port mode.
after AVR AccuQ done
[email protected] +12db hot
Rumble filter off
+ Low damping
with MV -15 to -18
I got a UMIC Mik. Ray- should i get a minidsp? thinking BEQ feature and time align the subs and thinking what else is the benefits.
ronnlim is offline
post #20 of 24 Old 03-28-2020, 09:08 PM
imureh's Avatar
Liked: 4715
Rumble filter off
+ Low damping
with MV -15 to -18
Yeah. Minidsp is a great tool. I would highly recommend it and especially for use with BEQ
post #21 of 24 Old 03-28-2020, 09:25 PM
Liked: 26
1 more curious check Ray
How far you place your dual FV18s from the back wall?
I am currently placing them 7 inch back.
Am still considering to place further like 10 or 12 inch further front as i find it hard at times to adjust the back dials....
Thanks a lot.
Ron
ronnlim is offline
post #22 of 24 Old 03-29-2020, 08:48 AM
imureh's Avatar
Liked: 4715
Thanks a lot.
Ron
Ron, I would let the sub frequency response determine whether it should be a little further up from the wall or not. Once you have set things up you should not have to mess with the dials in the back especially if you are going to get a minidsp. Even a few inches here or there can have an impact on the FR of the sub relative to the MLP
Ray
post #23 of 24 Old 03-29-2020, 10:58 AM
enricoclaudio's Avatar
Quoted: 4312 Post(s)
Liked: 5678
Rumble filter should be ON all the time. The rumble filter on the FV18 and FV25HP is set at -6dB @ 10Hz so it won't affect most movies content. Basically it's a cone excursion protection when paying EoT introductory scene.
darthray likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik G22 (x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #24 of 24 Old 03-29-2020, 10:36 PM
Liked: 26
Thanks so much enricoclaudio.
2 questions:
1. The Rumble filter OFF mode should not spolit the driver easily I guess unless for EOT opening scene.
Let say if the subs are still in warranty, the cone it should be covered I guess?
2. At @AVR +12db hot, will it be an issue if too much? I tried +5DB no kick lol.
Thanks so much for your advice.
Cheers
Enjoy HT
Ron
ronnlim is offline
