Minidsp 2 x 4 HD help.. - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By cptkarl
  • 1 Post By WisconsinEric
  • 2 Post By WOKNROX
post #1 of 14 Old 03-28-2020, 09:55 PM - Thread Starter
ccarzoo's Avatar
Quoted: 57 Post(s)
Liked: 30
On the advice of a lot of members here, I ordered a imik-1, minidsp 2x4 hd to help out two VTF 15H MK2's and an MBM Sub 12. My 7.2.4 Denon 6400h also has Audessey XT32... is the equipment needed before after or at all with the program?
"Go Blue"
ccarzoo is offline
post #2 of 14 Old 03-28-2020, 10:03 PM
imureh's Avatar
Quoted: 3566 Post(s)
Liked: 4853
You should present your subs to Audyssey post mindsp changes, time alignment etc
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #3 of 14 Old 03-29-2020, 03:50 AM
johnson636's Avatar
Quoted: 1756 Post(s)
Liked: 1282
If you use a house curve, make sure to load it after audessey. Otherwise, Audessey will attempt to flatten it out. At least that's what I do.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #4 of 14 Old 03-29-2020, 06:59 AM
Swoosh830's Avatar
Quoted: 185 Post(s)
Liked: 40
Do you present yours as one sub or two separate subs as one normally would without the MiniDSP?
Swoosh830 is offline
post #5 of 14 Old 03-29-2020, 07:44 AM - Thread Starter
ccarzoo's Avatar
Quoted: 57 Post(s)
Liked: 30
I have no idea... i wnt have the second subs until Tuesday... currently the #1 sub is connected to the Denon sub 1 putput... and has the mbm split off it, and the #2 sub is coming from the sub port..my dsp and mic will be here sometime this week. I feel so overwhelmed. Audessey is easy enough co figure.
"Go Blue"
ccarzoo is offline
post #6 of 14 Old 03-29-2020, 08:36 AM
cptkarl's Avatar
I have been reading information on AVSForum for about a year to help with understanding how to get the most out of my older system and help me on my upgrade path but I only joined up today because of your question. Please do yourself a huge favor and go find the YouTube channel called:
Home Theater Gurus
The guy that runs it is a member here on AVSForum (sorry I don't remember his username off the top of my head), he presents his topics step by step and provides the basics for beginners but also provides all the detail required to understand the topic at a more advanced level. For your Sub question and how to get started with multi-sub and miniDSP watch episode 8 then 7 (at the start of episode 7 he asks you to stop and watch 8 before 7). Then watch the whole series from the beginning, it contains a massive amount of good info on every topic related to home theater.
Enjoy your new gear!
pixphipau likes this.
5.2 Speakers - Front Mirage OMD28, Center Mirage OMD-C2, Surround Mirage OMD15, Sub - PSA TV18, AVR - Yahmaha RX-V2600, Amp - Parasound 2250 v.2, 4K-UHD - Panasonic DP-UB820, Display - LG C9 65", Other - miniDSP 2x4HD, Monster Power HTS2600, PS4, 9865HDC (cable box)
cptkarl is offline
post #7 of 14 Old 03-29-2020, 08:49 AM
imureh's Avatar
Liked: 4853
I present mine as one. If you time align them in mindsp then you can show them as one.
post #8 of 14 Old 03-29-2020, 09:19 AM
WisconsinEric's Avatar
Quoted: 179 Post(s)
Liked: 214
I have found this to be a pretty confusing process too because it seems like there are several paths you can take that in the end all sound pretty good to me! Plus different people here all champion their specific method as the best or most logical approach.
In the end what I went with was using both subwoofer preouts on my AVR into both MiniDSP inputs, then MiniDSP outputs 1 and 3 to my subwoofers. Then I ran XT32. Then I adjusted the AVR trim levels from -10 to -5 and slightly bumped up the gain on my subs to make an approximately 10 dB house curve. Then I used the MiniDSP to fine-tune the sub EQ on the output side.
Would love to know if a critical error was made in my process!
WisconsinEric is offline
post #9 of 14 Old 03-29-2020, 09:32 AM
badtlc's Avatar
Quoted: 795 Post(s)
Liked: 361
By any chance would you be willing to show your results using miniDSP with Audyssey and then take miniDSP out of the system and compare to what Audyssey XT32 can do on its own?
badtlc is online now
post #10 of 14 Old 03-29-2020, 12:16 PM
pixphipau's Avatar
Quoted: 148 Post(s)
Liked: 61
.following as im wondering what way to go for minidsp and audyssey
pixphipau is offline
post #11 of 14 Old 03-29-2020, 10:04 PM
WOKNROX's Avatar
Quoted: 542 Post(s)
Liked: 441
@ccarzoo
Heres the thread you need to follow..
REW subwoofer alignment Video using MiniDSP complete walk through!
jamiebosco and Todd G. like this.
Orotund Desert Theater;7.7.4,14'x20'x10',100amp service, JVC RS620,120" ATscreen, Carada Masquerade Masking, OPPO203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5ch ,Crown xls2500, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom Cabinets Fully build, SS-BS Inwall Triad Silver LCR, 4 Atmos Core5, Subs-miniDSP-HD2x4, 4 HSU VTF-15H-MK2, 3 MBM, 2 Rows of 3 Seatcraft Excalibur Lx Seats & more.
WOKNROX is offline
post #12 of 14 Old 03-29-2020, 11:06 PM
jamiebosco's Avatar
Quoted: 1014 Post(s)
Liked: 2656
The video above is excellent, and will make it much easier to understand!
as does the following guide https://www.dropbox.com/s/w7jmpozner...%20Version.pdf
TV: Panasonic 65" P65ST60 AVR: Denon AVR-X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Seaton SubMersives x 3
jamiebosco is offline
post #13 of 14 Old 03-30-2020, 05:08 AM - Thread Starter
ccarzoo's Avatar
Quoted: 57 Post(s)
Liked: 30
Originally Posted by WOKNROX View Post
@ccarzoo
Thanks guys, I will get into this as soon as I have a minute free.
"Go Blue"
ccarzoo is offline
post #14 of 14 Old 03-30-2020, 08:33 AM
Todd G.'s Avatar
Quoted: 228 Post(s)
Liked: 534
I recommend watching the video while setting up REW/miniDSP/UMIK-1, and using them along with the rest of the video. But you'll need to set aside a couple hours to be safe. Great info and a huge help.
Basement bat cave: JVC RS2000 (calibrated), 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
