Rhythmik F15HP vs FV15HP - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 3 Post By imureh
  • 1 Post By johnson636
  • 1 Post By eljaycanuck
  • 2 Post By jsc79
post #1 of 10 Old 03-29-2020, 08:57 PM - Thread Starter
Quoted: 92 Post(s)
Liked: 51
Looking for a new subwoofer and I think I’m down to these 2. I watch 70% movies and 30% music. I only have room for 1 subwoofer at this time. I am leaning toward the sealed sub as I do not want boomy bass, I prefer tight, punchy and accurate. My room is 20 ft x 20 ft x 9 ft ceiling height.
Any advice on which way to go? I’ve never had a ported sub before. It’s an expensive decision
Thanks in advance
SD1290 is offline
post #2 of 10 Old 03-29-2020, 09:22 PM
imureh's Avatar
Quoted: 3499 Post(s)
Liked: 4715
Thanks in advance
That is a large room. I would go ported for sure. The Rythmik ported offer clean, articulate bass. I would go with an FV18 if can accommodate budget and size wise....
eljaycanuck, spyboy and Vg247 like this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #3 of 10 Old 03-30-2020, 01:01 AM
Liked: 26
agree with Ray.
I owned FV15HPs b4.
Very powerful 15" Ported beast with lot of headroom. Dual FV15hp will pressure the room definitely.
It's the KING Legend of 15" Ported subs
For Low + Mid bass slam - Yah will go for Dual FV18s.
Enjoy HT
100% HT Lover 2.35:1 150' CYRUS Phantom Grey MK II 4k/UHD
BenQ W2700 4K HDR Source: Oppo 203 & Zidoo Z9S
1996 Sunfire Cinema Grand l Denon AVR-X4400H Pre-out @7.2.4
M&K Sound LCR950 THX Select2 Series Dual Rythmik FV18s @900WRMS ea aluminum cone
Dual Sunfire True Subwoofer EQ Sub 5: HSU Research MBM-12 MK2 (nearfield)
ronnlim is online now
post #4 of 10 Old 03-30-2020, 04:10 AM
johnson636's Avatar
Quoted: 1733 Post(s)
Liked: 1242
One shouldn't consider sealed over ported because of myths. A properly designed and well implemented subwoofer, whether sealed or ported, will result in "tight, punchy and accurate" bass. I'm sure Rhythmik does a great job with designing their sub whether sealed or ported
bear123 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 10 Old 03-30-2020, 04:57 AM
eljaycanuck's Avatar
Quoted: 2124 Post(s)
Liked: 3090
Large room + mostly movies = ported sub. Servo-controlled Rythmik FV15HP ftw!
drh3b likes this.
eljaycanuck is offline
post #6 of 10 Old 03-30-2020, 10:27 AM
qguy's Avatar
Quoted: 378 Post(s)
Liked: 186
I have the sealed F15 Not HP model, I used this exclusively for music only. For movies I use ported subwoofers. If I were to choose one sub only, I would choose the Ported subwoofer as it would be 100% perfect for movies and 90% perfect for music. If I were to choose the sealed sub, I would be getting 100% for music and 50% for movies
qguy is offline
post #7 of 10 Old 03-31-2020, 06:20 AM
badtlc's Avatar
Quoted: 652 Post(s)
Liked: 291
It appears based on testing a Rythmik ported sub does not have that issue. I have tried finding good THD data with little luck but from most reviews it appears that Rythmik ported are on par if not slightly better than sealed subs from non-servo sub makers.
badtlc is online now
post #8 of 10 Old 03-31-2020, 06:22 AM
jsc79's Avatar
Quoted: 563 Post(s)
Liked: 824
Data bass has enough measurements on the FV15HP and fv18 to make your head spin including THD numbers.
d-rail34 and derekmoore like this.
jsc79 is offline
post #9 of 10 Old 03-31-2020, 12:00 PM
badtlc's Avatar
Quoted: 652 Post(s)
Liked: 291
Yes they do. I don't really like the low resolution of their graphs, though, as you can't really compare the numbers between subs. It would be nice to be able to extract more detailed numbers from their data or at least have higher resolution graphs, especially above 25Hz.
post #10 of 10 Old 03-31-2020, 12:07 PM
jwskud's Avatar
Quoted: 232 Post(s)
Liked: 522
The other responses get it right - go ported. With the high/mid/low damping option on the FV15HP, you can get the best of both worlds in a single unit. This FAQ link might also help.
Chane A2.4 center, Chane A5.4s L/R, Chane A1.5s surround, Kenwood KS-505HTs rear
Sub: Klipsch R-120SW [wish list = Rythmik FV18 Rev2 (paper cone)]; Rythmik FAQ
Onkyo TX-RZ620, Samsung 4k 43NU7100, PS3
Protection: Tripp Lite Isobar 8 and 4 Ultra; Aircom T10; VCE SP250-2P-CA
jwskud is online now
