How do you move a 150 pound sub up the stairs solo? - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #1 of 35 Old 04-03-2020, 08:03 AM - Thread Starter
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
First world problems.
I'm struggling moving 150 lb subs up the stairs by myself. Last night on this hand truck I almost threw my back out. I think the tires were sagging some which I'm hoping contributed to the problem of me not being able to hoist the hand truck up to even the first step. I'm 45 years old and weigh 170 and am somewhat thin (except for dad belly) and I don't work out. Any tips or tricks to get these guys up the stairs solo other than inflating the tires? I want to play with my new toys.
acribb is offline
post #2 of 35 Old 04-03-2020, 08:10 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10948
In your case it probably would of been easier to leave it in the box and roll it up the stairs end over end with it laid horizontal. That is how the guy from Z-reviews got a PB16 up into his apartment.
B T C likes this.
basshead81 is offline
post #3 of 35 Old 04-03-2020, 08:16 AM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
i'm 58 years old, weigh 185lbs and am also a gym rat and i've got two kids (of course they are 30 & 34 ) and i can do it.
get down low, keep it close to the body, get a good grip under it, lift with the legs and work those glutes and hump that thing up the stairs. if your tired when you get it up the stairs, put it down then use the hand cart. get a lifting belt and put it tight and up high with the buckle right over your navel.
now, get to it and show us (beyond what you wrote ) what your made of!
avtvhdbass and Swoosh830 like this.
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XSP-1, XPA5,UPA2, UPA200 & Mini X Amps, ATV4K 32gb
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is offline
post #4 of 35 Old 04-03-2020, 08:28 AM
PriamFromTroy's Avatar
Quoted: 33 Post(s)
Liked: 30
Borrow an appliance hand truck, they are designed to bring heavy things up stairs. Make sure no one is at the bottom of the stairs.
N8DOGG likes this.
PriamFromTroy is offline
post #5 of 35 Old 04-03-2020, 08:40 AM
JD23's Avatar
Quoted: 1023 Post(s)
Liked: 791
Good luck. I limited myself to an 85 lb. subwoofer so I could avoid that headache. I could have done the rolling it up the stairs technique, but I was concerned that the grimy box was going to make my staircase filthy. I do think you are better off leaving it in the well protected box during the journey up the stairs.
JD23 is offline
post #6 of 35 Old 04-03-2020, 08:58 AM - Thread Starter
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
It did not come in a box. These JTR subs come shipped on the pallet side by side encased in foam insulation board.
acribb is offline
post #7 of 35 Old 04-03-2020, 09:07 AM
karlsch's Avatar
Quoted: 150 Post(s)
Liked: 175
This is what I was going to recommend. They also come with straps that you use to secure the load. It will still be difficult because of the weight, but doable.
Karl S.
karlsch is offline
post #8 of 35 Old 04-03-2020, 09:07 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10948
You could remove the driver... that would make it a bit easier to move.
acribb and sigpig like this.
post #9 of 35 Old 04-03-2020, 09:12 AM
Quoted: 593 Post(s)
Liked: 299
Might be better off waiting until you can get a lot of help, its not worth it to get injured.
mik2h, PlanetAVS and rhelliott2 like this.
Leeliemix is offline
post #10 of 35 Old 04-03-2020, 09:15 AM
gil393's Avatar
Quoted: 106 Post(s)
Liked: 81
I'd try rolling, and if it will stand by itself on one shelf, the hump it up one stair at a time. Other than that, you will need to get a hand truck with the roller tread on the back designed to take refrigerators, etc. up stairs. If there is something at the top that will hold 150lbs, like an eye bolt into a 2x4, a come-along, or something similar might work as well. Be careful, a subwoofer is not worth throwing your back out for.
gil393 is offline
post #11 of 35 Old 04-03-2020, 09:26 AM
chucky7's Avatar
Quoted: 3924 Post(s)
Liked: 5569
Don't move the sub without protection! You are gonna damage the cabinet!
Use the foam insulation board as protection! Cut the boards to size to cover the whole sub. Measure twice and cut once!
Then put the sub on a functioning hand truck, or try to roll the sub up the stairs.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
chucky7 is online now
post #12 of 35 Old 04-03-2020, 09:35 AM
Quoted: 215 Post(s)
Liked: 112
DO NOT TRY MOVING IT WHILE DOWNHILL OF IT! It's not worth it. Either get another person or try the hand truck again.
lmidgitd is offline
post #13 of 35 Old 04-03-2020, 09:39 AM
Quoted: 76 Post(s)
Not one person asked him where’s he at to offer a hand with moving it!!!!
So I will
What’s your location? Maybe someone off the forum can lend a hand
darthray, sivadselim and ipca204 like this.
hessc50 is offline
post #14 of 35 Old 04-03-2020, 09:47 AM
Quoted: 33 Post(s)
Liked: 30
He is in Jacksonville, FL. His governor won't let a Yankee like me into the state right now.
post #15 of 35 Old 04-03-2020, 09:48 AM
Quoted: 389 Post(s)
Liked: 251
wookiegr is offline
post #16 of 35 Old 04-03-2020, 09:54 AM - Thread Starter
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
Thanks for the ideas.
Removing the driver should lighten the hand truck load up by 65 pounds. I like that idea. I will be sure to hand thread those screws in when I put it back in.
acribb is offline
post #17 of 35 Old 04-03-2020, 09:54 AM
johnson636's Avatar
Quoted: 1748 Post(s)
Liked: 1280
Very carefully
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #18 of 35 Old 04-03-2020, 10:35 AM
Quoted: 215 Post(s)
Liked: 112
That is a fantastic idea. If you have the means, lay down some plywood to act as a ramp. That helped me when I had to move my boxes.
lmidgitd is offline
post #19 of 35 Old 04-03-2020, 11:45 AM
zeus33's Avatar
Quoted: 1995 Post(s)
Liked: 2258
You ALWAYS want the tires to be fully inflated on a dolly before you use it.
Me? I just picked my Cap 2400s up and walked up the stairs with them. I'm a little bit bigger than you though.
If there's no way to get anyone to help, do this. Lay the sub on a thick moving blanket. Wrap a strap around the sub, pinching the blanket between the sub and the strap on the bottom (side facing the ground floor, not the stairs). Grip the moving blanket and the strap and pull the sub up the stairs. The moving blanket will protect the stairs/sub and also keep the leading edge from catching on each stair as it comes up and the strap will pull the sub up.
Make sure you have shoes on that grip your stairs well, or you will slip and bad things will probably happen to you, your house and the sub.
JD23 likes this.
zeus33 is offline
post #20 of 35 Old 04-03-2020, 11:48 AM
zeus33's Avatar
Liked: 2258
That will probably damage the wood on his stairs. Not recommended.
zeus33 is offline
post #21 of 35 Old 04-03-2020, 11:48 AM
Azekecse's Avatar
Quoted: 280 Post(s)
Liked: 296
Put some cardboard underneath secure the cardboard and with a rope tied to the back and sides pull it up the stairs. Make sure the cardboard is an inch or two above the base of the sub, around the perimeter. Just my quick thoughts. Hope this helps. Good luck and stay safe and well.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is online now
post #22 of 35 Old 04-03-2020, 11:59 AM
lizrussspike's Avatar
Quoted: 1564 Post(s)
Liked: 2414
To get my V3600 into the house and downstairs, I did as @zeus33 suggested. with a few blankets around the sub. If I were in sunny Florida Sir, I would. I live in the Midwest...without a lot of sun. Hope you can find some help, as that looks like a nice sub.
lizrussspike is offline
post #23 of 35 Old 04-03-2020, 12:02 PM
jamiebosco's Avatar
Quoted: 1012 Post(s)
Liked: 2652
I'm shocked no one has posted these now iconic JTR pictures on this thread yet!!
darthray, d-rail34 and avtvhdbass like this.
TV: Panasonic 65" P65ST60 AVR: Denon AVR-X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Seaton SubMersives x 3
jamiebosco is offline
post #24 of 35 Old 04-03-2020, 01:02 PM - Thread Starter
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
There was a time when I could easily pick up something like this but that was many years ago.
psyduck103 likes this.
acribb is offline
post #25 of 35 Old 04-03-2020, 02:17 PM
bobknavs's Avatar
Quoted: 2886 Post(s)
Liked: 2089
(snip)
Goddam amateur bodybuilders. :-(
bobknavs is offline
post #26 of 35 Old 04-03-2020, 02:23 PM
JD23's Avatar
Liked: 791
So I will
That would be against CDC guidelines. Maybe someone could help if he wants to wait until July or August.
rads03 likes this.
JD23 is offline
post #27 of 35 Old 04-03-2020, 02:31 PM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10948
Yep it will make it much easier. Honestly on these larger subs it would be nice if you could order them with the drivers not installed. It would make placing them into some rooms much easier!!
JD23 likes this.
post #28 of 35 Old 04-03-2020, 04:32 PM
darthray's Avatar
Quoted: 2682 Post(s)
Liked: 4542
@acribb
Your best bet, is to get a friend or two. Or even some neighbours, to help you out. Just buy them a few beer, once done.
Incident on a staircase, can lead to a life changing moment and not worth doing.
Darth
darthray is offline
post #29 of 35 Old 04-03-2020, 06:09 PM
wpbpete's Avatar
Quoted: 240 Post(s)
Liked: 208
For $65 you can attach this to that handcart or get a friend
wpbpete is offline
post #30 of 35 Old 04-03-2020, 07:47 PM
bobknavs's Avatar
Liked: 2089
(snip)
Budget a bit more for the car battery to run it.
Not to mention the repairs after it rips the eye screw out of the wall stud upstairs.
rads03 likes this.
bobknavs is offline
