Help me pick a sub (or dual subs) and all my questions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 40Likes
post #31 of 129 Old 04-17-2020, 08:44 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
is the monolith 10 better than the SVS PB-1000?
Tony Wong is offline
post #32 of 129 Old 04-17-2020, 08:53 AM
johnson636's Avatar
Quoted: 1757 Post(s)
Liked: 1284
That is a very broad and subjective question.
SaskCanesFan likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #33 of 129 Old 04-17-2020, 08:58 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
how does it compare? which will you pick
post #34 of 129 Old 04-17-2020, 09:13 AM
johnson636's Avatar
Liked: 1284
If it were me, I'd get both, do my own comparison in my room, and keep the one I like the most
darthray and d-rail34 like this.
post #35 of 129 Old 04-17-2020, 09:29 AM
d-rail34's Avatar
Quoted: 684 Post(s)
Liked: 1496
Originally Posted by badtlc View Post
It all depends on your goals and listening levels. If you want LOUD and deep, movie theater like bass you will need serious subs. You can get some great deep bass with the following (around $600):
HSU VTF2
Rythmik LV12F
This is probably the entry level for folks on this board.
The SVS PB-1000 is also an option and will be a bit cheaper but it is not on the same performance level as the above 2. SVS has free returns so you might be best suited to start with the PB-1000 and see if you like it. If it isn't enough you can send it back and start figuring out your plan forward.
The monolith ported THX 10" is a great sub too but they don't have free returns if it is not enough. The RSL speedwoofer might have free returns and worth a demo, too.
Slow down and take a deep breathe...woosa. You're all over the place and basically sending yourself into what's called "analysis paralysis".
Since you've already ordered the Monolith 10 go ahead and demo it whenever it arrives, and if you feel that it's lacking, add a little more to your budget and go with something in a 12"-15" variety.
Also, while you're waiting for it to arrive, I'd suggest that you educate yourself on how to set up your sub so that you will get the best performance/experience out of it. There are plenty of knowledgable folks on here that are more than willing to help steer you in the right direction as long as you're willing to listen and take instruction. I say this because there is so much more to setting subs up properly than just placing them where one thinks it may look the best, plugging it in, powering it on, and then calling it a day. Keep in mind that just because something looks the best doesn't always mean it is the best.
That said, from everything that I've read/heard, the Monolith 10 is the best performer of the choices listed in this thread. Aside from the Rythmik or Hsu, that is.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelf (4) w/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S/Rythmik T-Shirt (1)
d-rail34 is online now
post #36 of 129 Old 04-17-2020, 09:41 AM
johnson636's Avatar
Liked: 1284
post #37 of 129 Old 04-23-2020, 07:07 PM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
just got the monolith today. Installed it with my yamaha 7850 and tested the bass with some heavy bass music.
very deep bass. maybe more than what i am loooking for or used to. My ear drums were shaking well after stopping the music
also lookwise it looks better with the grill off. but overall its looks are not great.
I think I am going to swap it out for something less and more pleasing look
post #38 of 129 Old 04-24-2020, 03:04 AM
eljaycanuck's Avatar
Quoted: 2170 Post(s)
Liked: 3160
just got the monolith today. ... very deep bass. maybe more than what i am loooking for or used to. ...
If you haven't already done so, you could try running the sub in sealed mode and in THX mode, and also running your AVR's auto-cal (YPAO).
... overall its looks are not great.
KEF 12 Kube. RSL Speedwoofer 10S.
eljaycanuck is offline
post #39 of 129 Old 04-24-2020, 04:28 AM
Spewdom's Avatar
Quoted: 395 Post(s)
Liked: 317
You can always change settings to produce less bass. But you won't be able to get that bass back in a sub that cannot produce it.
eljaycanuck and d-rail34 like this.
Spewdom is online now
post #40 of 129 Old 04-24-2020, 05:25 AM
Quoted: 593 Post(s)
Liked: 299
Sounds like you didnt run the auto setup and is running the sub very hot. Run the auto setup. And then enjoy.
Leeliemix is offline
post #41 of 129 Old 04-24-2020, 07:39 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
but when i run my ypao or testtone. when it gets to the sub, there is nothing
post #42 of 129 Old 04-24-2020, 07:42 AM
Quoted: 593 Post(s)
Liked: 299
How did you connect it?
post #43 of 129 Old 04-24-2020, 07:54 AM
Liked: 3160
If you've hooked up the sub per the sub's owner's manual and you've run YPAO per the AVR's owner's manual you should be getting something.
post #44 of 129 Old 04-24-2020, 08:03 AM
d-rail34's Avatar
Quoted: 684 Post(s)
Liked: 1496
As @Spewdom said, you can't get back what isn't there. With AV equipment it's always better to have more then not enough. And with speakers & subs it's definitely better to have extra headroom to avoid them being overdriven so that you will have good, clean, distortion free sound.
Next step for you is proper setup (placement, YPAO, dialing in). Here is a link to the sub calibration thread to help you understand how to get the most out of your sub(s).
https://www.avsforum.com/forum/113-s...eferences.html
I also agree with @Leeliemix that you may not have ran your auto cal properly.
Lastly, you chose the best performing sub out of the choices you had, so stop worrying so much about how it looks. Unless you'd prefer a beautiful sub that sounds like ****. If that's the case then by all means, have at it. Lol
post #45 of 129 Old 04-24-2020, 08:27 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
ypao to the mic jack on the receiver
its mostle about the looks. it look ugly. and its too big. cant hide it. i dont even know in what situation I would need all that bass.
should i try the svs 1000 and try that out?
I am currently testing out subs.
post #46 of 129 Old 04-24-2020, 08:30 AM
badtlc's Avatar
Quoted: 802 Post(s)
Liked: 364
The SVS SB-1000 might be worth your time. It will be smaller since it is sealed and definitely not have the same output.
There might be some piano black options out there if you are interested.
What about gloss white? Rythmik L12 sealed (small enclosure) comes in gloss white:
http://rythmikaudio.com/L12.html
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
AVR: Denon AVR-X3500H
badtlc is online now
post #47 of 129 Old 04-24-2020, 08:35 AM
d-rail34's Avatar
Quoted: 684 Post(s)
Liked: 1496
Those 2 subs are the same size, but if you want to try it out, that's completely up to you. It's your time & money.
post #48 of 129 Old 04-24-2020, 08:44 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
I might come circle back to it after i try out the others
post #49 of 129 Old 04-24-2020, 09:00 AM
Quoted: 593 Post(s)
Liked: 299
The sub, how is it connected?
At a given volume a bigger sub isnt supposed to be louder unless set up wrong, its just supposed to be cleaner and able to keep up when increasing the volume.
Just to make sure, you are not using LFE+main or other double bass setting?
post #50 of 129 Old 04-24-2020, 09:03 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
sub is connected via coax to the yamaha
post #51 of 129 Old 04-24-2020, 09:05 AM
Quoted: 593 Post(s)
Liked: 299
To the LFE out on the yamaha?
post #52 of 129 Old 04-24-2020, 11:08 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
I definitely feel the vibration on the sub. So I know its getting a signal. I had my crossover set at arounf 75-80 on the sub
thx and all other settings are on
db I think it was at 0
I played around upperthe db and was definitely heavy bass (deafening bass)
phase didnt apear to make a different - 0, 90, 180 tried it all
Here is how its connected
YAMAHA -----> single RCA -----> COAX(WALL) ------> RCA SPLIT -----> LFE on monolith
post #53 of 129 Old 04-24-2020, 11:17 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
here is what it looks like
Name:	Screen Shot 2020-04-24 at 11.16.40 AM.png
post #54 of 129 Old 04-24-2020, 11:32 AM
wdeydwondrer's Avatar
Quoted: 48 Post(s)
Liked: 35
Got my monolith 10 in yesterday and can't begin to describe how happy I am with it, stepping up from a dayton 12 budget sub.
So just my observation on this post but a couple things. You do not need the y splitter for RCA signal on the sub. Just plug the single out into one of the rca jacks (even says in the manual). Leave the switches on thx setting for initial run though since extended will just make it louder (more distortion possible on top end). Leave the crossover at the highest mark possible since you have the amp doing the work (crossover should be disabled if thx is selected but won't hurt to leave it at max). Leave phase on zero unless you need it, you'll know if you need it. Put the port plug in if you feel your bass is going too low, that will help the roll off a bit higher. Sub in corner will also increase volume but do a sub crawl to figure out where you may like to place it (I was stuck in where I can given my room, but whatever).
Once done and placed, then run your auto calibration. If the sub is still too hot (your amp showing like -12 db correction) you can move the gain knob into the negative numbers to cut some off and then re-run calibration so your amp gain is -12 to -6 leaving you room to cut a couple db off in amp if you'd like. Every recommendation I've read is to make sure the sub is always at least -5/-6db on the amp. Then make sure all your speakers are set to small, raise the crossover (in amp) of all your speakers to 80hz if lower than that, and see what a movie sounds like at that point.
My impression was that the monolith was providing lower bass I just didn't have before, and the bass I did have was at a higher volume versus before. Just running a couple bass boosted test tracks made it absurd BUT by the time I was finishing my first movie with it, the sub had completely blended in and made the movie 100% better. Loud knocks or bangs were reinforced with volume matching the sound field so you could "feel" the door slam like you would if you were 6 feet from a real door slam. I would suggest just giving it a few days and a decent listen after you get it calibrated. still too much bass, turn the gain down.
Stepping up to a 12'' quality sub isn't going to solve your problem any more than trading this for a 10'' svs sub. At your price point these are all in the same relative performance group. Don't get too tied up in reviews and numbers and comparisons cause you'll start seeing BIG differences where there may be a 1-2db difference that could quite possibly not even show up in your room. I personally would also NEVER buy an audio product based on it's looks over it's sound production, but that's just me.
Good luck!!!
wdeydwondrer is offline
post #55 of 129 Old 04-24-2020, 11:45 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 0
Good luck!!!
but all subs have a LFE white and red. what is supposed to be plugged?
post #56 of 129 Old 04-24-2020, 12:03 PM
Quoted: 593 Post(s)
Liked: 299
If one of them is labeled LFE on the sub use that, but either is fine if not.
post #57 of 129 Old 04-24-2020, 12:08 PM
Quoted: 593 Post(s)
Liked: 299
Dont forget to increase or decrease the gain on the sub until the auto setup sets it between -11.5 and -6dB
And follow the rest of the advice in the detailed post above.
post #58 of 129 Old 04-24-2020, 12:11 PM
Quoted: 48 Post(s)
Liked: 35
All subs don't necessarily have multiple in but on the monolith it's described in the manual. If you don't have LFE on your amp then you would plug your stereo pre-outs into these so the sub can filter the bass out of the stereo stream. With an LFE signal either input works.
post #59 of 129 Old 04-24-2020, 02:58 PM
Liked: 3160
It's in the owner's manual.
post #60 of 129 Old 04-25-2020, 09:10 PM
letterk's Avatar
Quoted: 22 Post(s)
Liked: 4
I have the Monolith THX 10” in my casual room. I have the Monolith THX 12” in my more serious room. Amazing subs. All subs are black boxes.
letterk is offline
