Thoughts on new subwoofer options - AVS Forum | Home Theater Discussions And Reviews
 24Likes
  • 1 Post By eljaycanuck
  • 1 Post By Dargent0628
  • 3 Post By skylarlove1999
  • 3 Post By johnson636
  • 1 Post By badtlc
  • 1 Post By skylarlove1999
  • 2 Post By sbarnhar
  • 1 Post By bear123
  • 1 Post By jamiebosco
  • 2 Post By PlanetAVS
  • 4 Post By bear123
  • 3 Post By spyboy
post #1 of 23 Old 05-03-2020, 11:48 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 1
Hey guys looking for some input on new subwoofer options. I just picked up the Polk HTS 10 because I was able to get a really good deal on it ($190). The problem is after having it for two days it just is not cutting it. I am coming off of using a KRK S10 in this setup which I have decided to start using again for making music. The polk does not even compare to the KRK sub and is a major downgrade. The Polk actually has a pleasant sound that I would describe as smooth, but it is not loud, produces no impact, and is making a popping noise when pushed. I will be returning it if possible and if not I will be selling it. My system use is evenly distributed between movies and music and the sub will be incorporated into a 7.1 channel system. The sub cannot be huge which rules out the monolith 10 (and others like that). The options I am looking at now are:
SVS SB-2000 (original model) for $599
Emotiva S12 for $699
Rythmik L12 for $559
Monoprice Monlith M10-S
All of these subs are (out of my price range), so the prices are important. Any thoughts on these subs, or any others that you could recommend?
I also found a pair of the Emotiva Basx8's on ebay for $300. It is hard to find info on these as they are no longer made, but they seem solid. I expect some serious output after using the KRK, so does anyone know if two of these will do the trick as $300 is much more appealing to me.
I would like to clarify: I know that the Basx8 subs will not play as low as the other subs I mentioned, but The KRK was only rated to go down to 28hz which I believe is comparable with the Basx8. The KRK may not have gone as low as the subs I listed but it was loud and would shake the house. Any thoughts on two of these Emotiva's doing the same?
My room is roughly 1600 cubic feet, but features two open doorway on either side. I know this is terrible! but its what I have to work with.
Matt Olsziewski is offline
post #2 of 23 Old 05-04-2020, 03:47 AM
skylarlove1999's Avatar
Quoted: 2268 Post(s)
Liked: 2407
Save your money up and buy a Seaton JS 12
https://seatonsound.net/product/js-12-subwoofer/
Sent from my SM-G965U using Tapatalk
Tristan Jones
skylarlove1999 is online now
post #3 of 23 Old 05-04-2020, 04:13 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 1
I appreciate the input, but that is just not an option. the options I listed are already stretching my budget very thin.
post #4 of 23 Old 05-04-2020, 04:38 AM
eljaycanuck's Avatar
Quoted: 2161 Post(s)
Liked: 3150
According to the specs on its product page, the KRK 10s has a 160W amp and extension to 34Hz +/- ??dB.
It's not on your list but you might want to consider the well-rated, 350W RSL Speedwoofer 10S ($399, shipped).
(Note: It's currently out of stock in black; still available in white.)
Matt Olsziewski likes this.
eljaycanuck is offline
post #5 of 23 Old 05-04-2020, 04:44 AM
Dargent0628's Avatar
Quoted: 286 Post(s)
Liked: 179
I think your only two reasonable options are the RSL Speedwoofer ($399.00, free returns within trial period) or the SVS PB1000 ($499.00, free returns etc..). I am a big fan of the Speedwoofer--that little sub hits above it's weight class. I compared these two and slightly preferred the Speedwoofer, but I think my preference was purely subjective and hard to quantify. Really inexpensive options might be the Dayton 1000 or 1200--not the most sophisticated but they hit hard for movies.
Or you could do as suggested and save up for a $1300.00 sub .
Dargent0628 is offline
post #6 of 23 Old 05-04-2020, 05:00 AM
iceatola's Avatar
Quoted: 266 Post(s)
Liked: 235
Go to Amazon and purchase Bic F-12 sub. The best sound overall for under $250 😉
https://www.amazon.com/BIC-America-F...s%2C172&sr=8-3
Video: BenQ HT3550 4K Projector - Elite Screens Manual Grande Series - 128inch
Pre Amp: Marantz 7705/ Power Amplifiers: Emotiva XPA-3, UPA-700
JBL - Stage A190 Towers L/R , Stage A135 Center , Stage A190 surrounds , Atmos Klipsch rp-500sa
Subwoofer PSA 2xV1801 / Xbox One X, Nvidia Shield, Darbee Darblet 5000
iceatola is offline
post #7 of 23 Old 05-04-2020, 05:13 AM
Liked: 2407
He already wasted money on one subwoofer. Buy once cry once. Not a cheap hobby . You have to know that going into it. Used subwoofer market is a good place to stretch one's budget.
Tristan Jones
post #8 of 23 Old 05-04-2020, 07:01 AM
johnson636's Avatar
Quoted: 1748 Post(s)
Liked: 1280
I'd say you'd be better served saving your coin until you can purchase a serious subwoofer.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #9 of 23 Old 05-04-2020, 07:14 AM
badtlc's Avatar
Quoted: 794 Post(s)
Liked: 361
Are you wanting to stick to sealed? You get a bit more bang for your buck with ported. The monolith 10" (sealed or ported) is probably biggest bang for buck under $500. If you go just above consider the Rythmik LV12F or HSU VTF2.
skylarlove1999 likes this.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
AVR: Denon AVR-X3500H
badtlc is offline
post #10 of 23 Old 05-04-2020, 10:17 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 1
Was looking at the monolith. It's just a little bit too big. I may be able to consider it as an option, but not sure. I am not opposed to ported subs, its just that in this price range they all seem to be tremendous.
post #11 of 23 Old 05-04-2020, 10:24 AM
Liked: 2407
I would look at used subwoofers on US Audio Mart.
Tristan Jones
post #12 of 23 Old 05-04-2020, 10:39 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 1
Looking at the RSL right now and I am really impressed at what I see. The white will not do sadly so if i decide to go this route I will have to wait until it is back in stock.
post #13 of 23 Old 05-04-2020, 10:51 AM
Liked: 2407
There are a pair of used SVS PB 2000's for sale in the classifieds right now just saying.
Tristan Jones
post #14 of 23 Old 05-04-2020, 11:19 AM
sbarnhar's Avatar
Quoted: 20 Post(s)
Liked: 30
My criteria were the same as yours when I was looking a few months ago. Around $500-ish or less, physically smaller than most in the same price class (WAF very important in my case), 50% music/movie split, etc.
I ended up getting the Rythmik L12. This is in our family room, which is part of the typical downstairs open floor-plan. So it is probably "undersized" for the room by most people's standards on this forum. However, I am thrilled with it, and it is plenty for how my wife and I listen (we aren't looking to shake the whole house on bass-heavy movie soundtracks).
The bass is tight, clean, plentiful, not boomy, and a lightyears-improvement over the Atlantic Tech 262PBM I had before. It especially shines on music - dang it sounds good! I've been pumping Marshmello and Halsey all morning at fairly loud volumes, and it just makes me smile. I like this sub so much, I just ordered another one for our upstairs room where we have another 5.1 system for secondary viewing.
corwiniii and Matt Olsziewski like this.
Scott
sbarnhar is offline
post #15 of 23 Old 05-04-2020, 02:44 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 1
Anyway you can post a link to where they are on sale?
post #16 of 23 Old 05-04-2020, 02:47 PM
Liked: 2407
Right here on AVS forum in the classified ads under Audio. I don't think we are supposed to link to them in the discussion threads.
Tristan Jones
post #17 of 23 Old 05-04-2020, 04:19 PM
bear123's Avatar
Quoted: 3544 Post(s)
Liked: 5447
I think the Hsu VTF2.5 will offer the most output in the smallest footprint with real 16 and 20 Hz output. Within the upper end of your budget, only 15" wide which is small for a ported sub:
http://www.hsuresearch.com/products/vtf-2mk5.html
It is *tremendously* more capable than the Speedwoofer 10S, as in, 10 dB more output at 20 Hz. Would take 3-4 to match a single VTF2.5
Speedwoofer seems really well liked for a little less money but the Hsu will offer a lot more performance. Worth stretching your size constraints just a bit imo.
Since they were mentioned, PB2000's are quite large. The Hsu substantially outperforms it as well, overall, although the PB2000 will have a tiny advantage at 20 Hz.
bear123 is online now
post #18 of 23 Old 05-04-2020, 10:32 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 1
I realize now that it was the PB 2000'S mentioned and not the SB variation. The PB's are just too large and the same sadly goes for the hsu. If there is any thought on a winner between the RSL and the SVS SB 2000. I know that higher price doesn't always mean better, but being that the new generation is currently $799, the $599 that Newegg has the original version listed for seems like a pretty good deal. From what I understand there is not much difference between the two versions sonically. The SVS also features pretty advanced dsp technology for the price bracket it is in. For $599 would the SVS outperform the RSL at $399?
post #19 of 23 Old 05-04-2020, 11:30 PM
jamiebosco's Avatar
Quoted: 1012 Post(s)
Liked: 2652
Out of those 2 choices,I'd personally take the SVS.
Performance wise they are extremely close under ~40hz (give or take a dB here and there), with the SVS having a slight advantage above that.
The only downside of the SB-2000 is that you may not be able to get a second one down the line as it's a discontinued model
Edit*. seeing you were considering the $700 Emotiva, is there any chance of stretching the budget for 2 x Speedwoofer 10s's?? If so that'd be my first choice
jamiebosco is offline
post #20 of 23 Old 05-04-2020, 11:38 PM
PlanetAVS's Avatar
Quoted: 2477 Post(s)
Liked: 3526
What exactly is the price you can live with (or did I miss that)?
Since you want to avoid a large footprint and you have a 50% music use case, I'd stick to sealed. The RSL at $399 is a good bet. Another option if you can wait is the SVS SB12NSD, which they produce a couple of times per year @$399.
Otherwise I wouldn't waste your money again on something lower. Not ideal but go without until you can swing one of the two above subs.
PlanetAVS is offline
post #21 of 23 Old 05-05-2020, 02:23 AM
bear123's Avatar
Liked: 5447
The SVS is better than the speed woofer, but if your wiling to spend $600 to get something better, then I'd go with the Rythmik L12. It will outperform them both and be a clear upgrade, and is a little cheaper than the SB2000.
post #22 of 23 Old 05-05-2020, 03:11 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 1
Yep I am leaning away from the SVS for exactly that reason. I can't have a huge subwoofer, but two smaller subs is a possibility down the road. I am now leaning towards either the Rythmik L12 or the RSL Speedwoofer.
post #23 of 23 Old 05-05-2020, 06:37 PM
spyboy's Avatar
Quoted: 379 Post(s)
Liked: 322
I would get the Rythmik L12 over the Speedwoofer. The L12 has the servo and digs deeper.
spyboy is offline
