Subwoofer recommendations for $1500 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 33Likes
post #31 of 77 Old 05-19-2020, 11:37 AM
Spewdom's Avatar
Quoted: 374 Post(s)
Liked: 307
Originally Posted by smk505 View Post
Would these two subs beet rythmek FV18 or lara sound V1812? They are cheaper than a single sub
Originally Posted by nonametofame View Post
Best bang for that price?
Two subs:
Hsu VTF3-Mk5
There really are no other contenders. If you up your budget, or just prefer one monster sub, then I do recommend the single Monoporice 15"
Two subs are recommended by most, but if buying a single sub there is no way I'd spend almost $700 more for the Rythmik FV18 over the Monolith 15 when looking at output of both. You're really going to have to decide the max you want to spend and what that's getting you.
Spewdom is online now
post #32 of 77 Old 05-19-2020, 11:41 AM - Thread Starter
smk505's Avatar
Quoted: 38 Post(s)
Originally Posted by JD23 View Post
In terms of peak output and extension, two of the Hsus will definitely not equal a single FV18. If properly integrated, the dual Hsus can offer a smoother response across multiple locations than a single sub. However, if dual FV15HPs or FV18s are an option for the future, they will provide the best of both worlds.
How about SVS PB-4000 is on sale as outlet unit for $1500. For the price how would it compare to the rythmek 15 or 18 options?
smk505 is offline
post #33 of 77 Old 05-19-2020, 12:06 PM
badtlc's Avatar
Quoted: 661 Post(s)
Liked: 295
SVS has free returns. Just try it yourself and find out if you like it. Even if you don't, you pay nothing to return it. Afterword, you will have more knowledge about your situation and people on here will be in a much better position to give you better recommendations.
JD23 likes this.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
badtlc is online now
post #34 of 77 Old 05-19-2020, 12:47 PM
Quoted: 469 Post(s)
Liked: 367
Unless you value customer service.
indebtbassfreak likes this.
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is offline
post #35 of 77 Old 05-19-2020, 01:00 PM
Spewdom's Avatar
Quoted: 374 Post(s)
Liked: 307
Contacting Hobie of Monolith is easy. If CS is top priority then SVS should be bought by everyone.
post #36 of 77 Old 05-19-2020, 01:02 PM
imureh's Avatar
Quoted: 3499 Post(s)
Liked: 4715
Not necessarily. Rythmik is top notch as well. It also comes down how issues are solved. Sending in a 100+lb sub for any issue is not for everyone
derekmoore likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #37 of 77 Old 05-19-2020, 01:23 PM
Quoted: 469 Post(s)
Liked: 367
Exactly. You dont have to read many personal experiences to know there is a different level of service from Rythmik, Hsu and PSA. I guess you can add SVS to that too but you pay for it up front with them. It's just not itemized in their price tag, like their so called "free" return shipping.
corwiniii likes this.
post #38 of 77 Old 05-19-2020, 01:24 PM
Quoted: 469 Post(s)
Liked: 367
I respectfully disagree.
post #39 of 77 Old 05-19-2020, 01:26 PM
sjm817's Avatar
Quoted: 921 Post(s)
Liked: 403
Two subs:
Hsu VTF3-Mk5
I have a pair of the HSUs above. Could not be happier with them.
sjm817 is offline
post #40 of 77 Old 05-19-2020, 03:17 PM
Kini62's Avatar
Quoted: 2905 Post(s)
Liked: 2792
Audioholics has a very good review with data of the PB4000 and databass has the data for the FV18. Both were done by different peoples but both used similar testing methods. The results are comparable.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #41 of 77 Old 05-19-2020, 04:16 PM
bear123's Avatar
Quoted: 3497 Post(s)
Liked: 5329
The PB4000 is basically the same as the PB13 Ultra that was tested on Data-Bass. So you can compare it directly to the FV18 there. Depending on how each sub is setup, they are somewhat similar 16-50 Hz. The FV18 has a large advantage above and below those ranges, and a small to medium advantage within that range depending on configuration.
bear123 is online now
post #42 of 77 Old 05-20-2020, 06:24 AM
Hopinater's Avatar
Quoted: 3858 Post(s)
Liked: 13007
No... I disagree. I was recently PM-ing with a guy who is a long time SVS customer with A LOT of their equipment and he was very unhappy with their recent customer service, which I admit shocked me because I've always heard their CS was excellent. So I'm not sure what's going on there but this guy was angry with the way they gave him a run around. I hope that is an anomaly and not the start of a trend for SVS. Nonetheless it should not have happened because in the end SVS changed their stance and it was remedied but at great distress for the customer.
From my experiences on AVS and in personal situations I have found PSA to have excellent CS. I've had emails answered at 10:00 Saturday night that I sent just an hour earlier. Literally, no one else does that. But right up there in great CS is Rythmik and usually Hsu.
So if having great CS is important (and it should be when you spend a lot on a sub) PSA, Rythmik, Hsu and then SVS would be the four I would look at... and in that order.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is online now
post #43 of 77 Old 05-20-2020, 06:53 AM
Hopinater's Avatar
Liked: 13007
If it were me I would narrow my choices down to the PSA and Rythmik subs that have already been mentioned (multiple times) because they are all good subs and you're room is moderate in size and any of them should work well.
Also, this is AVS so expect to be told to stretch your budget, it's what we do. But remember the room is at least 50% of the equation and proper calibration of that sub in the room is a HUGE part of getting all you can from the sub you buy. Buying more and bigger won't matter unless you take the time to dial in your sub properly. So stick to your budget, buy the sub that you like and then dial it in and you should be very happy.
JD23 and derekmoore like this.
post #44 of 77 Old 05-20-2020, 06:56 AM
imureh's Avatar
Liked: 4715
Originally Posted by Hopinater View Post
There really is not much room for debate that PSA has the best CS
Some recent PSA customers would beg to disagree, hope its not a new trend for PSA either...
jamiebosco likes this.
post #45 of 77 Old 05-20-2020, 06:58 AM
Hopinater's Avatar
Liked: 13007
I haven't heard that, I hope that's not the case.
post #46 of 77 Old 05-20-2020, 07:20 AM
ack_bk's Avatar
Quoted: 1365 Post(s)
Liked: 1548
I have been using dual Monolith 15's almost daily for 3 years now. Zero issues. I actually got both for $1900 shipped during a freak sale. If I would have listened to the naysayers I would never have bought them. So my opinion. Yes, customer service will likely be not as good an experience as the SVS's and PSA's of the world. But the likelihood of having a major issue resulting in shipping a large heavy sub back is very, very, low. The likelihood of getting a Monolith sub with zero issues is very, very, high. I have owned SVS, Hsu, eD, Klipsch, etc, etc and the Monolith build quality is exceptional. It's a very well made, well designed subwoofer. I think the customer service concerns with Monoprice are overblown and usually not warranted. Yes, there have been some. But I bet if I dig around I can find an unhappy customer for any brand here. It happens.
I am also a very big advocate of dual subwoofers. I would say take an honest review of your room, goals, and budget. If you don't think adding a second sub down the line is possible, something like dual Monolith or Hsu subs should be on the table for sure. And most people won't do this, but measuring and understanding your room is very important. You can buy a very expensive subwoofer and if your placement and room are not ideal, you will never maximize the potential of the sub. It's like buying a Lamborghini Aventedor and only being able to drive it to 60mph.
There are lots of white papers out there explaining the benefits of dual subwoofers (Harmon/JBL, Earl Geddes, Audioholics, etc).
Hopinater likes this.
ack_bk is offline
post #47 of 77 Old 05-20-2020, 07:39 AM
Hopinater's Avatar
Liked: 13007
Absolutely. Measuring is vital.
post #48 of 77 Old 05-20-2020, 07:56 AM
Spewdom's Avatar
Quoted: 374 Post(s)
Liked: 307
No surprise people have to fanboy out and cheerlead for a company that isn't paying them. Or are they? Complete with an anecdote, too. The only knock, if you can call it a knock, against Monolith is that you currently have to send the entire sub back if something goes wrong. Other than that, acting like contacting Hobie if something goes wrong is somehow all that different than contacting Tom of PSA or Brian of Rythmik is disingenuous. If someone wants to spend an extra 700 bucks for being able to replace their own amp, then knock yourself out, I guess. But for pretty similar results for that much more money? No, thanks.
This is why people need to be honest about their max budget that they refuse to go above. The FV18 is almost $400 more than his budget. Why not just increase it until you have four JTR 4000ULFs and call it a day.
post #49 of 77 Old 05-20-2020, 08:32 AM
imureh's Avatar
Liked: 4715
How about helping people set their subs up properly and answer questions? You are underestimating the PIA it can be when you have to first take a 100lb sub when it arrives, then send it back if issue and then take it in when it arrives...and make that double hard if you have to take it up the stairs. Its for the OP to decide if they can spend $400 and get a lot better performance and CS at the same time. All we can do is recommend and let the OP weigh pros and cons
post #50 of 77 Old 05-20-2020, 10:28 AM
Quoted: 469 Post(s)
Liked: 367
Not trying to be a smarta$$ here but has Hobie ever been known to deliver the Monolith's personally on occasion? Or help carry a sub upstairs and set it up for a customer? How about spending time helping customers dial them in?
This might be the case IDK.
post #51 of 77 Old 05-20-2020, 11:04 AM
ack_bk's Avatar
Liked: 1548
OP needs to define his goals and ares of importance.
Output?
Extension?
Coverage from seat to seat?
Is he someone who is going to implement something like BEQ? What does he have experience with? Is he in a position with wife/family/neighbors/etc to really take advantage of a high output/high extension sub? Does he have size restrictions and placement restrictions for a larger sub?
What are the room details? Is it treated properly? Has it been measured? There is so much to this than just buying a $2K sub, dropping it into the room, and hoping for the best.
I always tell people to plan on spending almost as much on proper room treatment than the cost of the sub itself. There are some great compnies out there that you can hire that will work with you on a room treatment plan and ensure that encompasses all your speakers, not just your sub. The room can make or break it and you have to be able to EQ and measure.
ack_bk is offline
post #52 of 77 Old 05-20-2020, 08:30 PM
nodoubt's Avatar
Quoted: 513 Post(s)
Liked: 304
At the bottom
lmao, another svs hater.
lonely being at the top.
keep it up svs.
nodoubt is online now
post #53 of 77 Old 05-20-2020, 08:33 PM
imureh's Avatar
Liked: 4715
keep it up svs.
I have had more svs subs that you could even count. Truth hurts. Go read my impressions thread and see what I said about the pb16. But does that compare to my FV18? No way. Not even close.
post #54 of 77 Old 05-21-2020, 03:29 AM
Docethic's Avatar
Quoted: 355 Post(s)
Liked: 297
I was expecting the PC4000 to be a lateral move to my SS MFW-15 but it was not in the same league for sound quality and TR. The only help that SVS customer service was to tell me I was overdriving the sub and needed to upgrade. The fact that the MFW was enough for my room and the 4000 was not they would not address. I thought there was something wrong with my 4000 but they said it was working fine and would not notify me upon receiving the return if there was a problem or not. So yes customer service is very responsive and friendly, but i'm not sure if they are always helpful.
I don't think a Pb4000 and an FV18 would sound even remotely the same.
Numbers only tell one part of the story.
basshead81 likes this.
Docethic is online now
post #55 of 77 Old 05-21-2020, 09:55 AM
Kini62's Avatar
Liked: 2792
I agree they probably have a different sound signature. But as for SVS not being helpful, what did you expect them to do over the phone or via email in regards to you saying there was not enough output? It is what it is or was what it was. There was nothing more that they could have done in your situation. And of course there is the "every room is different and every end user is also different".
What sub did you end up with?
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
post #56 of 77 Old 05-21-2020, 10:32 AM
macgallant's Avatar
Quoted: 832 Post(s)
Liked: 559
I know it's the boring answer but Dual HSU VTF3 MK5 simply can't be beat at the moment.
I'm surprised no competitor has been able to rival this value yet.
$870 each sub(when you buy duals) and the compete against subs that cost between $1000-$1500
Speakers: KEF Q100, Q300, Q750, Q650C, Q50a / Fluance Signature Series/ DCM TP160S-CH Subwoofers: Outlaw Ultra X12 (x2) / BIC H100-IIReceiver: Denon AVR-X4500H, AVR-X1400H Integrated Amplifier: Yamaha A-S501/ Fosi Audio TPA3116 mini amp Extras: MiniDSP Umik-1 Amplifier: Emotiva BasX-A300 Next Speakers: Triangle BR03, Revel Concerta2 M16, Dynaudio Emit M20, Buchardt S400, Triangle Comet ez, KEF R3
macgallant is online now
post #57 of 77 Old 05-21-2020, 06:08 PM
nodoubt's Avatar
Quoted: 513 Post(s)
Liked: 304
truth hurts...lmao....
no hurt here, just get a kick at people here bashing svs.
i could give a ratts arse.
enjoy your puny lil 900 watt sub
post #58 of 77 Old 05-21-2020, 06:10 PM
imureh's Avatar
Liked: 4715
That puny little 900 watts kicks the 1500 watt butt. You seem to suffer from inferiority complex.
post #59 of 77 Old 05-21-2020, 06:13 PM
nodoubt's Avatar
Quoted: 513 Post(s)
Liked: 304
lmao, man your quick !
i suffer from a few things, but thats not one of them.
btw... my daddy can beat your daddy up!
post #60 of 77 Old 05-21-2020, 06:58 PM
steve1616's Avatar
Quoted: 32 Post(s)
Liked: 25
I actually have been searching for your review or impressions of the PB16Ultra but I can't find it. Can you tell me what post count it is or maybe see if you have a link for it. Thanks!
steve1616 is offline
