Minidsp for subs - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By jsc79
  • 2 Post By derekmoore
post #1 of 17 Old 05-20-2020, 09:48 AM - Thread Starter
boxker's Avatar
Quoted: 71 Post(s)
Minidsp for subs
Okay, I've been trying to find the answer on AVS but can't seem to find it. I recently bought a couple of minidsp 2x4s. I wasn't paying attention, thinking they were Minidasp 2x4hd. In any case, I'm trying to figure out if I need to go through the hassle of returning them, get a refund, and go after the HD version. My plan is to use one for my 4 acoustechs (2 H-100IIs and 2 pl-200s) in my living room and the other for my 2 HSU VTF-2 MK5 in my dedicated theater.
Will the standard model work well, or do I need to return them and get the HD version.
Thanks for any advice.
YOU ARE HERE! Life EXISTS and Identity! That the powerful play goes on and you may contribute a verse. That the powerful play goes on and YOU... may contribute a verse. ......what will your verse be?
boxker is offline
post #2 of 17 Old 05-20-2020, 10:05 AM
imureh's Avatar
Quoted: 3499 Post(s)
Liked: 4715
If you can get a refund then go for the HD version
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #3 of 17 Old 05-20-2020, 10:05 AM
badtlc's Avatar
Quoted: 661 Post(s)
Liked: 295
What is the largest difference in distance to the MLP you "might" have in your rooms? The biggest shortcoming of the 2x4 nonHD version it can only delay a sub up to 7ms. If I remember right, this means if you think you might have a sub more than 7' further away then another sub in the same room, the nonHD might not work for you.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
badtlc is online now
post #4 of 17 Old 05-20-2020, 11:22 AM - Thread Starter
boxker's Avatar
Quoted: 71 Post(s)
Well in my living room I have 2 4 feet away from mlp on either side and the other 2 are 9.5 feet away on either side. And in my Theater I have 1 10 feet away and the other 7 feet away.
boxker is offline
post #5 of 17 Old 05-20-2020, 11:55 AM
badtlc's Avatar
Quoted: 661 Post(s)
Liked: 295
Then the next thing to look at is the voltage clipping issue. What voltage does your AVR use for its sub output?
Front: Polk S55
Center: Polk S30
Rear: Polk S10
post #6 of 17 Old 05-20-2020, 12:20 PM - Thread Starter
boxker's Avatar
Quoted: 71 Post(s)
I don't know. In my living room, I'm using a Marantz SR 6012 and in my theater, I'm using a Marantz AVR 7705.
boxker is offline
post #7 of 17 Old 05-20-2020, 12:34 PM
badtlc's Avatar
Quoted: 661 Post(s)
Liked: 295
I think if you want to run the subs hot you might be at risk of clipping. You might research that a bit more.
I understand your situation as the HD version is more than double the cost. It is a much better unit, though. You will likely have a lower stress level if you can return the non-HD.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
post #8 of 17 Old 05-20-2020, 01:17 PM - Thread Starter
boxker's Avatar
Quoted: 71 Post(s)
Yeah, I decided to return the 2 standard version. I was just wanted to get to messing around with it. I have a lot to figure out. As I side note. my living room receiver is a 6013 not 6012. I don't know why I typed that.
boxker is offline
post #9 of 17 Old 05-20-2020, 05:25 PM
enricoclaudio's Avatar
Quoted: 4312 Post(s)
Liked: 5678
Get the 2x4 HD. You also get 10 x PEQs per input/output instead of 5 on the non HD. Also, the miniDSP 2x4 HD can be upgraded to DDRC-24 with Dirac Live. The HD can be connected to the miniDSP wi-DG and be controlled via WiFi, the non HD can’t do that.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik G22 (x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #10 of 17 Old 05-20-2020, 08:55 PM
Quoted: 92 Post(s)
Liked: 51
Any of you guys order minidsp direct from their site? I didn’t realize they are out of country, how long did it take to arrive?
SD1290 is online now
post #11 of 17 Old 05-21-2020, 04:20 AM
Quoted: 327 Post(s)
Liked: 450
i ordered a UMIK-1 from them in march and had it in my hand 3 days later.
i was a bit shocked to say the least....so in my experience, it was super fast.
LG 55C8, Pioneer Elite VSX-LX503, Panamax M5400, Microsoft Xbox One X, Nvidia Shield Pro
Definitive Technology: BP9060 Front left/right/CS9040 center/A90 front Atmos/ProMonitor 800 rear Atmos/SR9040 surround left/right
Rythmik FVX15
MATTHEW PATIENT is offline
post #12 of 17 Old 05-21-2020, 04:24 AM
chevman's Avatar
Quoted: 83 Post(s)
Liked: 68
The turn around is actually very quick considering how far they are. They use DSL and once shipped, it comes into the states in a day or two, add another 2-3 once in-country and you're are plugging it in. That is unless there are unforeseeable setbacks such as being out of part of something you ordered. I ran into that, but it still wasn't bad. The wait time for shipment is around 6 business days.
Video: 65" Sony 900X XBR; Sony X800M2 Blue Ray; OTA Tivo Roamio; Apple TV 4K
Audio Electronics: Rotel Pre-amp RSP-1066, RMB-1075 120x5 Amp; Schiit Modi 2 Uber DAC; Denon 2930CI DVD; MiniDSP DDRC-88A/BM
Speakers: Klipsch Forte III, CDT-5800 II (Surround); B&K Sounds CSC-1 (Center); Dual SVS SB 3000's
chevman is online now
post #13 of 17 Old 05-21-2020, 05:58 AM
badtlc's Avatar
Quoted: 661 Post(s)
Liked: 295
They have several north american distributors listed on their site. I have found that you can end up saving a bit in taxes and shipping by trying some of the distributors instead of buying directly from MiniDSP.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
post #14 of 17 Old 05-21-2020, 07:09 AM
Quoted: 92 Post(s)
Liked: 51
Thanks for the responses, every US distributor looks to be sold out of the umik 1 microphone, but the direct site said they had them in stock
post #15 of 17 Old 05-21-2020, 07:18 AM
jsc79's Avatar
Quoted: 563 Post(s)
Liked: 825
I bought mine from deer creek Audio. Fast shipping and I would recommend them.
derekmoore and WOKNROX like this.
jsc79 is online now
post #16 of 17 Old 05-21-2020, 07:27 AM
Quoted: 469 Post(s)
Liked: 367
^ +1 to DCA. Also check Cross Spectrum Labs if you haven't already.
EDIT: I dont see the HD version on the CSL website, but you might want to send them an email to double check. The site appears a bit neglected.
jsc79 and WOKNROX like this.
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is offline
post #17 of 17 Old 05-21-2020, 07:54 AM
jsc79's Avatar
Quoted: 563 Post(s)
Liked: 825
The WI DG is also convenient(not necessary, although it is a must have for me out of convenience ). You can download a remote app on your phone and toggle through your configurations. You can also load sub eq files, BEQ files through your laptop wirelessly.
I use config one with a house curve for most of my listening, config 2 without curve for nighttime when kids are down, config 3 for BEQ, and config 4 empty and for experimenting with different eq. The widg makes it really easy to switch between those.
One note- the widg can be a bit flakey and disconnect with Windows pc’s. It’s annoying but the convenience far outweighed this minor nuisance.
jsc79 is online now
