Crossover Frequency for Subwoofer question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By badtlc
post #1 of 13 Old 05-21-2020, 02:46 PM - Thread Starter
CaptainSensible's Avatar
Recently moved so:
Most modern receivers are equipped with Audyssey software and hardware (mic) to calibrate your system.
I'm sure this has been asked before, but do some of you still do it the old fashion way where you spend like an hour or two trying to get the right crossover frequency for your sub and match it with your speakers for the best optimum sound?
How accurate do you find this method?
Also, do any of you still do the subwoofer crawl? (I'm thinking yes since Audyssey can't physically place the subwoofer where you want)
CaptainSensible is offline
post #2 of 13 Old 05-21-2020, 02:52 PM
badtlc's Avatar
Quoted: 661 Post(s)
Liked: 295
Originally Posted by CaptainSensible View Post
Recently moved so:
Each crossover setting will impact the response of your system. I think most on here probably use REW and a calibrated USB mic to test the different crossover settings and choose the one that integrates the speakers the best. This is probably the most accurate method.
As for the sub crawl there are many different version of it this days. Some will put the sub in the MLP and carry their USB mic around to different locations to find the best starting point. Some will put the mic at the MLP and move the sub around taking REW sweep measurements at each location to compare the response curves and then pick the best location based on that. Yes, you should do some version of this if you can.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
badtlc is online now
post #3 of 13 Old 05-21-2020, 02:55 PM
bobknavs's Avatar
Quoted: 2855 Post(s)
Liked: 2066
Maybe this is overly precise, but the only current AVRs (audio video receivers) with Audyssey are Denon and Marantz. The other mass-market makers have software for the same purpose, but proprietary. (No licensing fees to Audyysey.)
I haven't done a sub crawl, mainly because the placement options for my subs are rather limited. I have two subs, and experimented with all the placements thare are available. (None were very good.)
The crossovers (probably actually adjustable low pass filters) in my subs are switched out. I let the AVR handle the crossover function.
Your mileage may vary.
bobknavs is offline
post #4 of 13 Old 05-21-2020, 03:00 PM - Thread Starter
Looks like I'm in for quite an adventure. I just moved into a house so I no longer have to limit my subwoofer's bass. I can now play Eminem's Killshot really loud if I want to! (just to test the bass)
post #5 of 13 Old 05-21-2020, 03:08 PM - Thread Starter
I have a Denon. It's neither a top of the line, nor low end, just middle of the pack
Denon AVR-S930H but it handles really well.
post #6 of 13 Old 05-21-2020, 03:14 PM
torii's Avatar
Quoted: 4392 Post(s)
Liked: 2550
if you spend the time to setup your system with rew and speaker/sub placement...you might find audyssey doesnt do anything/much.
Name:	aud on vs off.jpg
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is online now
post #7 of 13 Old 05-21-2020, 03:18 PM - Thread Starter
Ok, so I had no idea what the hell REW was until I found this: https://www.roomeqwizard.com/
Is this what you mean?
post #8 of 13 Old 05-21-2020, 03:25 PM
torii's Avatar
Liked: 2550
yes
torii is online now
post #9 of 13 Old 05-21-2020, 03:39 PM - Thread Starter
Alright. Thanks. I'll see which of these is better. Independent nerds vs commercial nerds.
post #10 of 13 Old 05-21-2020, 06:10 PM
Quoted: 20 Post(s)
If you set your crossover on your receiver, I was told you should bypass it on your sub. If you cant bypass it, you crank it all the way to the right. I am not a professional by any means, but my subs sound a whole lot better this way.
RonnieBlack2nd is offline
post #11 of 13 Old 05-21-2020, 06:31 PM - Thread Starter
Yeah, no. I don't think it is a good idea to crank the subwoofer all the way up in case the settings don't lock. It could damage the subwoofer.
post #12 of 13 Old 05-21-2020, 06:36 PM
badtlc's Avatar
Quoted: 661 Post(s)
Liked: 295
They were talking about the crossover setting being maxed out, not the gain/volume. The crossover being set as high as possible is the correct setting for most people/installations.
smcmillan2 likes this.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
post #13 of 13 Old 05-21-2020, 06:46 PM
smcmillan2's Avatar
Quoted: 1123 Post(s)
Liked: 945
As badtlc stated, crossover on the sub itself as high as it will go or if there's a bypass option, use that. Without knowing the specific make/model that's all we can give you.
Then let Audyssey do it's thing.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
