Monolith 10 110volts to 220volts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-21-2020, 03:33 PM - Thread Starter
Liked: 0
svs and hsu has a tutorial on converting corresponding voltages..
svs is via remove jumper trick and hsu is a switch inside its psu..
Do you have any idea how to convert monolith 10 to 220volts?
monolith tech support seems bad.. They suggested a stepdown transformer..
pretty basic and common sense..
clintmark is offline
post #2 of 3 Old 05-21-2020, 06:35 PM
badtlc's Avatar
Quoted: 562 Post(s)
Liked: 247
I don't see any indication that the monolith amp can handle 220V. It appears it is limited to 120V only. You would indeed need a step down transformer but that only works if the power frequency is still correct. If your power source isn't 60Hz, you will be at risk of doing damage.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ (̶2̶)̶ ̶F̶V̶X̶1̶2̶ V1812
badtlc is offline
post #3 of 3 Old 05-22-2020, 10:52 AM
bobknavs's Avatar
Quoted: 2825 Post(s)
Liked: 2029
From Monoprice's Q&A for the model:
Is the 10 inch THX subwoofer 120 VAC only, or can it run on European/Asian 220 VAC with replacement power cord?
New User U on Nov 19, 2018
BEST ANSWER: Just 120 VAC.
Reply Inaccurate New User U Staff on Nov 19, 2018
I take it to mean that the sub isn't sold into the European market, so it may lack the power transformer taps that would give a simple change between North American and European voltages.
Unless you can find someone who has hacked the hardware and is willing to share information, Monoprice's suggestion may have to stand.
bobknavs is offline
