Polk PSW505 Very Quiet - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By johnson636
post #1 of 8 Old 05-22-2020, 12:31 AM - Thread Starter
Bethzur's Avatar
I have a Polk PSW505 that's around 6.5 years old. It seems to have failed. Sound levels are very, very low, even with the volume turned up to max. I'm using speaker outputs. Amp works and powers my bookshelf speakers just fine. I connected a phone to the line level inputs, and same thing: really low audio.
I opened it up and I don't see any obvious problems. I have one with the BASH amp.
Are there common issues with the BASH amp in these units that are fixable? A new amp is about what I paid for the sub, so that's out.
Bethzur is offline
post #2 of 8 Old 05-22-2020, 08:11 PM
johnson636's Avatar
Quoted: 1715 Post(s)
Liked: 1209
This one is easy...New Subwoofer
rhelliott2 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 8 Old 05-22-2020, 08:50 PM
superkyle's Avatar
Quoted: 1079 Post(s)
Liked: 512
This was actually the first sub I owned. The amp went out on mine also. It would turn on but not output any power. They are not very reliable. Unfortunately for this one I would say it is likely dead. But good thing there is plenty of offerings on the site to help you get back to banging
Always destroying exergy!
superkyle is online now
post #4 of 8 Old 05-22-2020, 09:35 PM - Thread Starter
Bethzur's Avatar
I am looking at new subs.
I'm likely going to take the Klipsch rw-12d from the family room and put it in my (much smaller) office. I'm looking at subs that are more suitable for a large space. Lots of good options, but they tend to be much more expensive. We'll see what the budget allows. Hopefully they will last. (I'm looking to maybe spend < $1500.)
I was hoping for somewhat of a fix for the Polk to get by, but such is life. It was working Tuesday I know, and then by Thursday it was mostly dead. I think I moved it to install my new speaker stands for the bookshelf speakers. Who knows what happened. I think I got about 2.5 usable years out of it. Really quite pathetic. This will definitely be my last Polk product.
Bethzur is offline
post #5 of 8 Old 05-22-2020, 09:53 PM
lizrussspike's Avatar
Quoted: 1507 Post(s)
Liked: 2289
Brother @Bethzur , there are a lot of subs out there. I went from dual PSW 505 to dual PSA XV15...for $1500 you can get great dual subs! Need to check ID subs companies, as some will offer discounts for duals.
This would be an incredible upgrade and within your budget:
https://www.avsforum.com/forum/209-a...-psa-xv30.html
lizrussspike is offline
post #6 of 8 Old 05-22-2020, 11:28 PM - Thread Starter
Bethzur's Avatar
Thanks for the reply. I'm exploring the usual brands recommended here. Again, this is to replace the working Klipsch rw-12d. I figure it will be totally fine for my office since the Polk was totally fine.
For the family room, I'm currently leaning toward a SVS PB-3000. It seems expensive compared to the HSU and Rythmik, but I do like the longer warranty, free returns and the DSP functions. My family room is large and open on one side, plus it has a vaulted ceiling. Getting things to sound good is difficult. Plus the web site for Rythmik is an embarrassment and pseudo-sciencey. HSU use BASH amps which my limited experience says aren't very durable. I'm hoping that the SVS amps are better.
It seems like many subs fail after 2-3 years, and I'm not aware of another company offering a 5 year warranty on the amp. I just need to save a bit and hope for a sale.
Bethzur is offline
post #7 of 8 Old 05-23-2020, 07:14 AM
corwiniii's Avatar
Quoted: 85 Post(s)
Liked: 214
I think you have a great budget to work with for either a great single or dual subs. All the companies you listed have great offerings in that range, along with PSA (look at the new TV models).
As you're finding, it comes down to what's most important to you. What you'll get from Rythmik and Hsu is less fluff and more sheer output for the dollar. SVS subs are great, but you're paying more for add-ons and conveniences; which is fine. SVS is more expensive because of that fancy website, apps, digital interfaces, and the "free" returns (you understand it's built into the sub cost).
Rythmik might not have the fanciest web site (I'll leave the pseudo-sciencey comment alone), but their subs are among the best in the industry and value for the dollar. Skim through the forums, you wont find many complaints of their amps failing after 2-3 years.
Klipsch RP-8000F L/R | Klipsch RP-504C C | elemental Designs A6-6T6 MTM surrounds | Rythmik FV18 Rev2 Paper Cone Black Matte + Elemental Designs A5-350 Restored! | Denon AVR-S920W | Vizio P75-C1
corwiniii is online now
post #8 of 8 Old 05-23-2020, 07:30 AM
Liked: 2289
@Bethzur , I have PSA subs, and pretty sure they have 5 year warranty. have had my XV15se for 7 years now, and still working great. Def see which ID company has a great deal, and possibly free shipping on returns, in case you did not like that particular sub....
