Yamaha MusicCast SUB 100 connect with MusicCast receiver and wired speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-23-2020, 07:28 AM - Thread Starter
Liked: 0
Question Yamaha MusicCast SUB 100 connect with MusicCast receiver and wired speakers
I have a Yamaha R-N803D network receiver with wired speakers. The receiver is connected with the MusicCast app. I have also installed the Yamaha MusicCast SUB 100 in the network with the MusicCast app.
I tried to connect the "amplifier room" to the "subwoofer room". However, the app says "Cannot be paired."
In that way I can't let the wired speakers and the subwoofer (via WiFi) play at the same time. It looks like the subwoofer can only be paired with other Musiccast (wireless) speakers and not with a receiver connected with wired speakers.
Is my conclusion correct or is there another way?
Jannock is offline
post #2 of 3 Old 05-23-2020, 10:14 AM
eljaycanuck's Avatar
Quoted: 2108 Post(s)
Liked: 3069
A Q&A on Crutchfield.com seems to confirm that wired+wireless don't mix. IOW, you can either go all-wired to the receiver, or all wireless using Yamaha MusicCast speakers + sub.
eljaycanuck is offline
post #3 of 3 Old 05-24-2020, 01:31 AM - Thread Starter
Liked: 0
Thanks very much for your reaction eljaycanuck!
Jannock is offline
musiccast , sub 100 , Yamaha
