The audyssey in my Denon receiver thinks my subwoofer is 22ft away when it's only 7ft - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 1 Post By imureh
  • 1 Post By JD23
  • 1 Post By tvuong
  • 1 Post By pajama sam
  • 1 Post By badtlc
  • 2 Post By idknuttin
post #1 of 17 Old 05-23-2020, 11:20 AM - Thread Starter
Liked: 2
Just got a subwoofer to compete my 5.1 setup. I ran audyssey to calibrate everything and it measures the distances of all the speakers from the listening position correctly except the subwoofer. The subwoofer is only about 7ft away from the main listening position but audyssey thinks it's 22.1ft away. This can't be correct?
idknuttin is offline
post #2 of 17 Old 05-23-2020, 11:26 AM
imureh's Avatar
Quoted: 3558 Post(s)
Liked: 4841
For subs that distance has nothing to with physical distance. That is effectively a delay that Audyssey is calculating to align you subs to your mains
Soulburner likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #3 of 17 Old 05-23-2020, 12:10 PM
JD23's Avatar
Quoted: 1034 Post(s)
Liked: 816
Your subs may have significant DSP delay.
garygreyh likes this.
JD23 is offline
post #4 of 17 Old 05-23-2020, 11:35 PM
tvuong's Avatar
Quoted: 3001 Post(s)
Liked: 3082
I ran audyssey to calibrate everything and the subwoofer is only about 7ft away from the main listening position but audyssey thinks it's 22.1ft away. This can't be correct?
You probably connect your sub wirelessly? Wireless module adds additional delays (distances).
pajama sam likes this.
tvuong is offline
post #5 of 17 Old 05-24-2020, 08:04 AM - Thread Starter
Liked: 2
Is that necessarily a bad thing, does it represent the quality of the sub?
post #6 of 17 Old 05-24-2020, 08:05 AM - Thread Starter
Liked: 2
Not wireless
post #7 of 17 Old 05-24-2020, 09:52 AM
chucks0's Avatar
Quoted: 605 Post(s)
Liked: 1569
As long as your AVR accurately time aligns all of the speakers / subs, it isn't a problem. Most modern subwoofers use some form of DSP which introduces additional delay. I know Rythmik is one of the companies that does not use DSP.
Electronics: Denon X4400, Vizio M65
Sub: Rythmik FV18-PC x 2
Speakers: 3 x Chane A2.4 LCR, DIYSG Volt-6 Surrounds
chucks0 is offline
post #8 of 17 Old 05-24-2020, 01:35 PM
tvuong's Avatar
Liked: 3082
Not wireless
What sub(s) are you using? That is a huge discrepancy in distances.
tvuong is offline
post #9 of 17 Old 05-24-2020, 01:45 PM
pajama sam's Avatar
Quoted: 28 Post(s)
Liked: 24
If your sub has a phase adjustment make sure it's set to zero.
pajama sam is online now
post #10 of 17 Old 05-24-2020, 02:22 PM - Thread Starter
Liked: 2
Not wireless
Dayton audio sub 1200
post #11 of 17 Old 05-24-2020, 02:23 PM - Thread Starter
Liked: 2
The phase was set to 180 when I did the audyssey calibration.
Should I set it to 0 and recalibrate?
I thought the you should set the phase to whatever sounds better to you based on the room and where the sub is placed?
post #12 of 17 Old 05-24-2020, 02:39 PM
badtlc's Avatar
Quoted: 795 Post(s)
Liked: 361
Set phase to 0. Re-run audyssey. Then tweak after it is done.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
AVR: Denon AVR-X3500H
badtlc is offline
post #13 of 17 Old 05-24-2020, 02:44 PM
nathan_h's Avatar
Quoted: 3034 Post(s)
Liked: 2128
No, and no. It's totally normal, and has more to do with the room size and how bass waves are acting in your room than anything specific to the subwoofer.
Respectfully, I have found that changing the phase AFTER audyssey runs tends to cause more harm than good. Part of the delay that Audyssey sets acts a lot like adjusting the phase knob, so altering the phase knob afterwards can undermine the calibration, in my experience. Ymmv.
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is offline
post #14 of 17 Old 05-24-2020, 02:55 PM
badtlc's Avatar
Quoted: 795 Post(s)
Liked: 361
Nobody told him to mess with phase after running audyssey. He needs to set it to zero and re run audyssey.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
badtlc is offline
post #15 of 17 Old 05-24-2020, 03:15 PM
nathan_h's Avatar
Liked: 2128
I apologize. I misunderstood the direction to "tweak" phase after "it" (which I took to mean Audyssey) is done.
My current setup.
nathan_h is offline
post #16 of 17 Old 05-26-2020, 03:45 PM - Thread Starter
Liked: 2
Thanks guys, I set the phase to 0 and ran the audyssey calibration again and now it says the sub is 9.6ft away which makes much more sense.
badtlc and pajama sam like this.
post #17 of 17 Old 05-26-2020, 04:44 PM
badtlc's Avatar
Quoted: 795 Post(s)
Liked: 361
good! have fun tweaking!
Front: Polk S55
Center: Polk S30
Rear: Polk S10
badtlc is offline
