What method do you use to time align sub/s with mains? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By bobknavs
post #1 of 22 Old 05-31-2020, 07:04 PM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
As there are few ways of doing this, what method do you use?
Philips752 is offline
post #2 of 22 Old 05-31-2020, 08:52 PM
bobknavs's Avatar
Quoted: 2900 Post(s)
Liked: 2094
Audyssey XT32/SubEq.
KidHorn and eljaycanuck like this.
bobknavs is offline
post #3 of 22 Old 05-31-2020, 09:30 PM
badtlc's Avatar
Quoted: 817 Post(s)
Liked: 367
I have tried a couple:
  • If my crossover is at 80hz, I play an 80Hz test tone in REW and then watch the real time SPL level. I look for a null and then when I find it, I add about 7ft to it. This method essentially gets the subs/mains perfectly aligned at the crossover frequency but when it came to listening with my ears it didn't sound good at all.
  • Using REW, run sweeps from 10-200Hz. I increase the sub distance setting by 1' at a time reviewing the full sweep after each run until I find a curve that I like the best. This works well I think.
  • Using the time align feature in REW I take a 10-200Hz sweep of the sub on its own and the front towers together without the sub. I then open both plots within the time alignment tool and pick the crossover frequency (normally 80 but sometimes 100) and then REW tells me how far to adjust the sub distance setting. This seems to work OK.
I know other users use an REW method where they take a plot of the sub by itself and the front speakers by themselves and then use REW's ability to simulate what a change in delay would do to the curves. REW produces a predicted combined curve and after finding a curve they like they input that delay into the sub distance setting. It supposedly works well but I have not done it.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
AVR: Denon AVR-X3500H
badtlc is online now
post #4 of 22 Old 05-31-2020, 10:26 PM
simplyderp's Avatar
Quoted: 70 Post(s)
Liked: 29
I run Dirac Live and verify with Room EQ Wizard
LG C9, Genelec 8341A, 8030C, Rythmik G25HP, Emotiva XMC-1, GIK Acoustics
simplyderp is offline
post #5 of 22 Old 06-01-2020, 06:03 AM
imureh's Avatar
Quoted: 3581 Post(s)
Liked: 4885
Use the time alignment tool in the latest beta release for REW. Makes it really simple
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #6 of 22 Old 06-01-2020, 06:44 AM
eljaycanuck's Avatar
Quoted: 2170 Post(s)
Liked: 3160
eljaycanuck is offline
post #7 of 22 Old 06-01-2020, 06:53 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10958
The Alignment tool in REW works great if your AVR room correction software isn't setting the distances correctly..
basshead81 is offline
post #8 of 22 Old 06-01-2020, 11:59 AM
KidHorn's Avatar
Quoted: 1901 Post(s)
Liked: 1307
Back in the old days, the phase knob was used for that. You would turn the knob until the bass sounded loudest/best. Nowadays, use software.
KidHorn is offline
post #9 of 22 Old 06-01-2020, 11:10 PM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Do you confirm with REW or similar?
Or fine tune.
post #10 of 22 Old 06-02-2020, 12:07 AM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Dont forget its around the 80hz xover too, in your example should look at 40-160hz for the best summation.
Which one did you finally use and which method going forward?
post #11 of 22 Old 06-02-2020, 12:09 AM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
How do you verify in REW, run sweeps or use the alignment tool.
post #12 of 22 Old 06-02-2020, 12:11 AM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Which auto correction do you use and do you use it for time alignment.
post #13 of 22 Old 06-02-2020, 12:14 AM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Originally Posted by eljaycanuck View Post
Audyssey MultEQ XT32 w/ Sub EQ HT
You trust what Audyssey does for time alignment subs.
post #14 of 22 Old 06-02-2020, 12:17 AM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Do you do both.
post #15 of 22 Old 06-02-2020, 12:20 AM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Some still have that don't they. Like a variable phase.
Do you use auto calibration time alignment then confirm with a software such as REW.
post #16 of 22 Old 06-02-2020, 10:07 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10958
Do you do both.
Yes. I found that with my 4 subs I need to add 3 ms of delay to the sub that I sit closest too. After Audyssey calibrates my setup I always find that the bass sounds like it's passing by me in all directions like a phase issue. After the added delay it then sounds like I am being hit by the bass in all directions. The odd thing is you can't see a difference in the response either with or without the delay added. So only thing I can figure is there is just enough of a difference between the mic placement and my ears. So what I perceive as a phase issue doesn't show up on the measurement and the delay doesn't change doesn't effect the response either.
post #17 of 22 Old 06-02-2020, 10:20 AM
nbk13nw's Avatar
Quoted: 94 Post(s)
Liked: 57
Would that be 1.1ms per foot for the closet sub when adding a delay?
Sent from my SM-G988U using Tapatalk
Yamaha CX-A5200, Yamaha MX-A5000, Sanway DSP-6KQ, XBox One X, Panasonic DMP-UB900, NVIDIA Shield, D-Link 16-Port Gigabit Switch, Caavo, Control Center, 2 x JBL Studio 590 Mains, 1 x JBL Studio 520C Center, 2 x JBL 580's side surrounds, 2 x JBL 530's rear surrounds, 4 x RSL C34E's ATMOS, 4 x Chane SBE-118's
nbk13nw is offline
post #18 of 22 Old 06-02-2020, 02:43 PM
Liked: 3160
I run Audyssey, then check my FR curve with OmniMic and adjust if/as necessary.
post #19 of 22 Old 06-02-2020, 11:38 PM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Do you do both.
Have you got measurements of the subs and the mains separate, and mains combined. If you like and not a problem for you can you post these with the phase showing as a overlay, as a photo. Computer got going so hence the photos.
Also can you tell me the crossover.
post #20 of 22 Old 06-02-2020, 11:42 PM - Thread Starter
Quoted: 169 Post(s)
Liked: 41
Do you have Omnimic measurements of the subwoofers and mains separate and the subs together and mains together. If you want to you can post them as a photo and list your crossover. Please show phase.
post #21 of 22 Old 06-03-2020, 12:57 AM
simplyderp's Avatar
Quoted: 70 Post(s)
Liked: 29
I just do a sweep
post #22 of 22 Old 06-03-2020, 06:28 AM
badtlc's Avatar
Quoted: 817 Post(s)
Liked: 367
I just don't get enough time to really test this stuff to the level I am comfortable with. I would say the trial-and-error method of adjusting the sub distance 1 ft, run sweep, and repeat is probably the safest method.
I wish there was a reliable easier method.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
