Help with wireless subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-31-2020, 11:05 PM - Thread Starter
newHTowner's Avatar
Quoted: 22 Post(s)
Hi Guys,
I have two SVS subwoofer hooked up to a Marantz AV7705. As they are across the room from one another, one is hard wire and the other one is linked via wireless system (Sunfire). Both SW are set to auto-off. Unfortunately, the wireless one is constantly on and giving feedback even though the hard wire one is turning off automatically when the AV7705 is off.
Not sure how to fit it.
Any ideas?
newHTowner is offline
post #2 of 9 Old 06-01-2020, 10:59 AM
bobknavs's Avatar
Quoted: 2891 Post(s)
Liked: 2092
Could you elaborate on what you mean by "giving feedback"? I don't understand.
bobknavs is offline
post #3 of 9 Old 06-01-2020, 10:03 PM - Thread Starter
newHTowner's Avatar
Quoted: 22 Post(s)
Basically the subwoofer does not turn off and every five minutes or so would have several loud low frequency pulses - I have checked all cross wiring, etc. and can't find anything wrong. I'm guessing that the wireless set up is emitting a constant frequency pulse to keep the two unit linked and somehow the SW is sensing this as audio signal hence it stays on????
post #4 of 9 Old 06-01-2020, 10:41 PM
bobknavs's Avatar
Liked: 2092
Feedback has a particular connotation for me, and what you describe ain't it.
The only wireless sub connection I've used is an Outlaw Audio OAW4 transmitter/receiver pair. It did nothing like what you describe. It's a 2.4GHz system.
bobknavs is offline
post #5 of 9 Old 06-02-2020, 10:44 AM
RayGuy's Avatar
Quoted: 3570 Post(s)
Liked: 3382
Swap the two subs. Does the problem stay with the sub or with the wireless connection?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #6 of 9 Old 06-03-2020, 10:40 AM - Thread Starter
newHTowner's Avatar
Quoted: 22 Post(s)
Originally Posted by RayGuy View Post
Swap the two subs. Does the problem stay the with the sub or with the wireless connection?
Ok. Thanks for all the suggestion. Let me clarify - essentially the noise that I'm hearing is SW "pops", basically popping noises, low frequency. I've tried swapping the SW that is hooked up to the wireless system and same problem. So frustrating.
post #7 of 9 Old 06-03-2020, 10:57 AM
RayGuy's Avatar
Liked: 3382
So that points to the problem being the wireless system. Look at the system from Outlaw Audio, then return the current.
https://outlawaudio.com/shop/index.p...roller=product
Or, the SVS has also been well reviewed:
https://www.svsound.com/products/sou...-audio-adapter
RayGuy is offline
post #8 of 9 Old 06-03-2020, 09:35 PM
bobknavs's Avatar
Liked: 2092
That's a suggestion that I wish I had made.
bobknavs is offline
post #9 of 9 Old 06-04-2020, 09:00 AM
Ed Mullen's Avatar
Quoted: 566 Post(s)
Liked: 1152
Hi Guys,
Any ideas?
This sounds like interference from other 2.4 GHz sources in the home. Make sure the Sunfire RX/TX units are not placed too closely to other source of 2.4 GHz in the house - like streaming devices, Wi-Fi routers, smart phones, certain baby monitors, etc. Also try to get the TX/RX 'line of sight', which can help prevent drop-outs and reconnections (which often are manifested as a pop).
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
