Sub recommendation for a new HT system - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By corwiniii
post #1 of 12 Old 06-25-2020, 09:31 PM - Thread Starter
Liked: 0
I am building now my first HT system to my new apartment and I need some advice which subwoofer to choose.
My seating place will be in a long living room. I will have a big window from one side, and the other side will be open to the rest of the house.
Dimensions:
• The distance between the seating place and the speakers are 8.5 feet
• The length of the living-room + kitchen open space is 44 feet (The seating place is in the end, just small part of it.
• Ceiling height - 9 feet
• Overall volume ~4500 cubic feet + some more small space
The speakers that I ordered are:
Front: Elac Debute B6.2
Center: Elac Debute C6.2
Rear: Elac Debute OW4.2
I am debating which sub to buy:
1. SVS pb-1000 at $499.99
2. or PB-2000 (not the pro), currently on sale at $699.99
3. Something else?
I am relocating from the US, and I'm taking it with me. So I cannot test it in their place.
I need the best bet... one chance
I will be using it especially for movies.
I want to have high quality sound, but not to disturb the neighbors so much.
Niv Dob is offline
post #2 of 12 Old 06-25-2020, 09:34 PM
Squirrel!'s Avatar
Quoted: 875 Post(s)
Liked: 558
PartsExpress.com ...DIY
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #3 of 12 Old 06-25-2020, 09:50 PM
Sorny's Avatar
Quoted: 190 Post(s)
Liked: 228
What's the budget?
If you're relocating from the US, then I'd strongly recommend you look at HSU Research.
You won't find better subs for the money unless you DIY.
MiniDSP 2x4HD, UMIK-1, REW... The holy trinity for running multiple subs.
Espon 5050UB, 120" screen, AppleTV4k, Harmony Elite, Sony UBP-X700, Pioneer Elite VSX-LX504, Outlaw 7000x, MiniDSP 2x4HD, 2x HSU TN1220HO subs, 2x HSU VTF-15H Mk2 subs, Defintive Technology speakers: CLR2002 x3 for FR, C, FL; BP2x SR & SL; BP1.2x SBL & SBR; ProMonitor 800 x4 height speakers.
Sorny is offline
post #4 of 12 Old 06-25-2020, 10:58 PM - Thread Starter
Liked: 0
Originally Posted by Sorny View Post
What's the budget?
I was thinking about ~$500 (something like the pb-1000).
But in case it won't be strong enough, I can spent a bit more, but the roof is $700
Is VTF-2 MK5 Subwoofer will be better than the pb-1000?
Niv Dob is offline
post #5 of 12 Old 06-26-2020, 03:33 AM - Thread Starter
Liked: 0
I have been reading for hours
My choices for now are:
1) pb-2000 (not pro) - in sale at $699.99
2) HSU VTF-2 MK5 - $539 + $65 shipping = $604
Warranty doesn't matter since I ship them out of the US..
I read that my elac b6.2 fron speakers can get down to 35hz,
does this means I should get the pb-2000 which have a stronger lows?
Which one is a better deal?
Niv Dob is offline
post #6 of 12 Old 06-26-2020, 07:44 AM
badtlc's Avatar
Quoted: 795 Post(s)
Liked: 361
Yes. It is likely better than a PB-2000 too.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
AVR: Denon AVR-X3500H
badtlc is offline
post #7 of 12 Old 06-26-2020, 09:15 AM
phatfreeza's Avatar
Quoted: 148 Post(s)
Liked: 268
unlikely that the elac bookshelves go down to 35hz with any real authority. You would be crossing over much higher. Both subs will work well with your speakers. My vote also goes to the HSU its bang for buck!
My HT: 7.3.4
Spoiler!
phatfreeza is offline
post #8 of 12 Old 06-26-2020, 11:12 AM
Quoted: 100 Post(s)
Liked: 129
Yes, you will cross your mains at 60-80 minimum. 80 being typical. Don't focus on them for sub choice per se. Its not really the determining factor.
AVR: Yamaha TSR-7850, Fronts: DCM TP260, Center: DCM TP160C, Sub: Premier Acoustic PA-150
Deaf-Forever is offline
post #9 of 12 Old 06-26-2020, 01:21 PM
Sorny's Avatar
Quoted: 190 Post(s)
Liked: 228
VTF-2 will trounce a PB1000, and is likely better than the PB2000 as well.
Sorny is offline
post #10 of 12 Old 06-26-2020, 11:09 PM - Thread Starter
Liked: 0
I'm so happy!
I actually hates the pb-2000 metal grills but didn't want to compromise audio quality
So I will probably go with the VTF-2, but I have two questions:
1) Would the VTF-2 will function well also in low volumes watching?
2) Do I need to decouple it from the floor with something like SVS SoundPath? (it will be in a hard tiles floor apartment)
Niv Dob is offline
post #11 of 12 Old 06-29-2020, 12:32 AM
head_unit's Avatar
Quoted: 778 Post(s)
Liked: 419
I actually hates the pb-2000 metal grills...1) Would the VTF-2 will function well also in low volumes watching?
I just put an SVS SB-3000 into a Focal Aria 5.1 system. Everything well thought out, really impressive, and really adds authority to the lows. Having said that, I met Dr Ph Hsu once, he was a nice guy AND really knows how to make cranking subs. BUT does that VTF-2 have a remote? To me a remote is a MUST for a sub. And absolute MUST-in part because of your question. Human hearing is extremely level sensitive at low frequencies (Search "Fletcher Munson") PLUS bass levels of records can vary a lot, and so you simply have to be able to modify the sub level on the fly.
head_unit is offline
post #12 of 12 Old 06-29-2020, 03:10 AM
corwiniii's Avatar
Quoted: 102 Post(s)
Liked: 249
I've never thought to myself "you know, the thing missing from my subwoofer is a remote", but that's just me. One can already change the subwoofer level on the fly, by using the AVR remote and increasing the trim, or getting up and increasing the subwoofer gain knob a notch, or using a miniDSP (if you have one) to increase the gain, etc. I also don't mess with the levels (BEQ aside) once the subwoofer has been dialed into the system. IMHO, I wouldn't let a remote set a subwoofer apart; it's all about pure output per dollar, period. It's also one more thing to break or lose. :shrug:
Deaf-Forever likes this.
Klipsch RP-8000F L/R | Klipsch RP-504C C | Klipsch RP-500SA atmos | elemental Designs A6-6T6 MTM surrounds | Rythmik FV18 Rev2 Paper Cone Black Matte + Elemental Designs A5-350 Restored! | Denon AVR-S920W | Vizio P75-C1
corwiniii is online now
