Is this good bass response? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By badtlc
  • 1 Post By badtlc
  • 1 Post By Sorny
  • 1 Post By ereed
  • 1 Post By CallingMrBenzo
post #1 of 11 Old 06-26-2020, 08:17 AM - Thread Starter
mitchlampert's Avatar
Quoted: 187 Post(s)
Liked: 85
I see a lot of folks posting these awesome looking, flat curves going well below 20hz and just wondered how I was doing. I have two Rythmik FV25HP's.
Name:	Sub No Fliter.jpg
mitchlampert is offline
post #2 of 11 Old 06-26-2020, 08:22 AM
imureh's Avatar
Quoted: 3591 Post(s)
Liked: 4916
Those are EQ'd responses. FR is more dependent on your placement and room so you should share that info. I assume this is a non EQ'd response? Do you have a minidsp?
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #3 of 11 Old 06-26-2020, 08:23 AM
badtlc's Avatar
Quoted: 849 Post(s)
Liked: 387
It looks OK. If you are looking for advice, I would do the following:
1) Take sweeps of your subs individually using time reference setting.
2) Move a sub to every possible location and do sweeps for every orientation at each location. Sometimes a turning a sub 90 or 180 degrees in the same spot changes the response in a good way.
3) After you have a collection of individual sweeps at all the locations and orientations with time reference, you can then use REW to determine which 2 spots and orientations are likely best for you. This is done using the alignment tool within REW. You can select any two curves and simulate their combined response. You can even adjust delay for each curve separately. This tool will give you a good starting point to set the delay between the subs for best integration.
4) Then put the subs in the locations and orientated.
5) Do some final REW measurements trying different delays for each sub to make sure you find the best delay difference.
6) Then you can start EQ'ing with MiniDSP.
It will take some work but you have a good start, IMO. You will get a nice curve at the end.
spyboy likes this.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
AVR: Denon AVR-X3500H
badtlc is offline
post #4 of 11 Old 06-26-2020, 08:44 AM
phatfreeza's Avatar
Quoted: 157 Post(s)
Liked: 298
i just ran audyssey again after doing some EQ-ing beforehand with minidsp. i have dual fv25hps like you. i have a few peaks to take care of but it looks like you could use some room correction with your peaks.
Name:	after audyssey.jpg
My HT: 7.3.4
Spoiler!
phatfreeza is online now
post #5 of 11 Old 06-26-2020, 09:14 AM - Thread Starter
Quoted: 187 Post(s)
Liked: 85
This is what I did to achieve the curve I posted. This was after all the above and then running ARC Genesis room correction. That's why I was asking. I wanted to know how some of you get these awesome looking flat curves!
post #6 of 11 Old 06-26-2020, 10:10 AM
badtlc's Avatar
Quoted: 849 Post(s)
Liked: 387
So if you have found the two best locations that combine the best and you are sure you got the best delay settings, the next step is EQ within MiniDSP. Once you get them good with MiniDSP your ARC will give you better results most likely.
Sorny likes this.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
badtlc is offline
post #7 of 11 Old 06-26-2020, 02:09 PM
Sorny's Avatar
Quoted: 196 Post(s)
Liked: 236
Most folks with nice flat curves are doing it with a MiniDSP and REW and a mic like a UMIK-1... That's how I did it.
**edited to add the before EQ graph**
ID:	2749518   Click image for larger version
Name:	4 ind and sum.png
badtlc likes this.
MiniDSP 2x4HD, UMIK-1, REW... The holy trinity for running multiple subs.
Espon 5050UB, 120" screen, AppleTV4k, Harmony Elite, Sony UBP-X700, Pioneer Elite VSX-LX504, Outlaw 7000x, MiniDSP 2x4HD, 2x HSU TN1220HO subs, 2x HSU VTF-15H Mk2 subs, Defintive Technology speakers: CLR2002 x3 for FR, C, FL; BP2x SR & SL; BP1.2x SBL & SBR; ProMonitor 800 x4 height speakers.
Sorny is offline
post #8 of 11 Old 06-26-2020, 09:37 PM
jamiebosco's Avatar
Quoted: 1015 Post(s)
Liked: 2658
I'm quite lucky in my current room that I get a fairly flat response with just Audyssey XT32, I can probably flatten this out a bit more with y miniDSP, but can't be bothered at the moment
TV: Panasonic 65" P65ST60 AVR: Denon AVR-X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Seaton SubMersives x 3
jamiebosco is offline
post #9 of 11 Old 06-26-2020, 10:01 PM
ereed's Avatar
Quoted: 2466 Post(s)
Liked: 1765
You should pick up minidsp just for BEQ alone!
CallingMrBenzo likes this.
Theater room: Sony 45es | 120" screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M | Funk Audio 18.0L (2), 21.0LX (2 coming soon) | MiniDSP 2x4HD | Crowson Tech MAs | Surgex XR 315 | CyberPower UPS | GIK room treatments
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8 |
ereed is offline
post #10 of 11 Old 06-26-2020, 11:45 PM
jamiebosco's Avatar
Liked: 2658
I have one, have had it for a few months now, I just can't be bothered using it
I really just watch movies for the movie itself, audio/bass is just the cherry on top (so to speak) I also watch a lot of my movies between 12am - 5am so deep bass isn't always needed at my place.
post #11 of 11 Old 06-27-2020, 11:01 AM
CallingMrBenzo's Avatar
Quoted: 823 Post(s)
Liked: 2104
Then get Crowson's and watch with BEQ, no excuses
imureh likes this.
Marantz 7011- Panasonic UB-820- Xbox One X -Nvidia Shield - JVC RS4910 * - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R -VOLT 6 Surrounds - Atmos: SVS Elevations Atmos X2, Volt 6 x 2- Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ *HOVER BOSS* UM-18, 2 JBL's, Maxxis Fat tubes, Behringer NX4-6000
CallingMrBenzo is offline
