Sub Recommendation- $500 Canadian Budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 06-27-2020, 01:32 AM - Thread Starter
Liked: 0
I had a Polk Audio PSW10 but found it didnt get loud enough. For $500 Canadian, what sub, or two subs, should I get for a rap music system?
Josh Vance is offline
post #2 of 19 Old 06-27-2020, 10:54 AM
eljaycanuck's Avatar
Quoted: 2165 Post(s)
Liked: 3152
The PSW10 has very limited capability as a subwoofer. If you were in the U.S., the Monoprice Monolith 10" and SVS PB-1000 would be no-brainer choices. Up here, it's not so easy. Personally, I'd increase the budget and get an SVS PB-1000 from electronicsforless.ca or sonicboomaudio.com, authorized SVS dealers. The current price seems to be $699 + HST (shipping incl.).
-- Edit -=-
Alternatively, you could look at subs such as:
- BIC RtR EV1200 (~$470, shipped, at amazon.ca)
- BIC F12 (~$326, shipped, at amazon.ca)
eljaycanuck is offline
post #3 of 19 Old 06-27-2020, 12:22 PM
indebtbassfreak's Avatar
Quoted: 1631 Post(s)
Liked: 3067
pretty hard to get anything decent in the $500 Canadian range,,, hopefully you can bump up your budget a bit. Performance wise the Monolith 10" would be a great sub for your music choice in the $800 or less range. A RSL Speedwoofer 10" would be about $600/$650 Canadian landed and its a good performing sub for music but will not dig as deep as the Monolith or SVS PB1000. It will however play strong into the upper 20's Hz depending on room/set up.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #4 of 19 Old 06-27-2020, 01:25 PM - Thread Starter
Liked: 0
How would a Polk HTS 12 perform do you think?
post #5 of 19 Old 06-27-2020, 02:23 PM
Liked: 3152
I've read that they're pretty decent subs and fairly "punchy". At their current sale price of ~$450 they're probably worth a shot (especially if you buy them from a place like bestbuy or visions that has a good return policy).
post #6 of 19 Old 06-27-2020, 02:39 PM - Thread Starter
Liked: 0
Imma try the BIC I think. I've heard a lot of good things.
post #7 of 19 Old 06-27-2020, 05:21 PM - Thread Starter
Liked: 0
So, I got a quote from RSL for the Speedwoofer, and its $94 to ship to Canada. All in all, I could get either the RSL or the SVS PB1000 for the same price at $700 Canadian. Which do I get?
post #8 of 19 Old 06-27-2020, 05:28 PM
Liked: 3067
From what ive read, the Speedwoofer will be more articulate/punchy for music, but the SVS will dig much deeper. The SVS (if there are any problems) would likely be the easier rout to rectify as you would be buying from Electronicsforless in Canada and not dealing with boarder issues after the purchase.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #9 of 19 Old 06-27-2020, 06:09 PM - Thread Starter
Liked: 0
Fair enough. I'll get the SVS when it's back in stock.
post #10 of 19 Old 06-27-2020, 07:58 PM - Thread Starter
Liked: 0
Actually, one last question. Would it be better to do 2 F12s over one PB1000?
post #11 of 19 Old 06-29-2020, 06:11 AM
Osamede's Avatar
Quoted: 86 Post(s)
Liked: 66
I have a Polk HTS 10 that I bought used, been operating it for a few weeks now. in the library sub-section of an open plan three room area. TheIt does a very good job for the price is my subjective impression. It's getting down into the mid 20's in-room.
The HTS12 is a bigger driver, so you'll get even more sound power and go down a bit deeper closer to 20Hz real in-room response.
Obviously if you have the budget a ported SVS is probably going to be the ideal, but on a limited budget, I wouldn't hesitate if you have a good deal on the Polk HTS12. And if you can go used and find two of these, that's going to give you a smoother response overall than any single sub solution.
Osamede is offline
post #12 of 19 Old 06-29-2020, 07:34 AM
avtoronto's Avatar
Quoted: 211 Post(s)
Liked: 87
I suspect SVS is going to be announcing a "PB-1000 Pro" model shortly so you may want to wait a bit.
Elunevision 4K 112" Audioweave motorized screen, Epson Pro Cinema 4040 projector, Emotiva XPA-5 amplifier, Denon AVR X4400h receiver, XTZ M6 LCR, XTZ S5 surround, XTZ 1X12 and Definitive Technology Powerfield subwoofers, RSL C34E Atmos speakers, Apple TV 4K, Panasonic DP-UB820
avtoronto is offline
post #13 of 19 Old 06-29-2020, 08:22 AM
Osamede's Avatar
Quoted: 86 Post(s)
Liked: 66
If you're on a limited budget "pro" means they want more money. The channels will be reducing prices on existing models now, to get the stock levels down. So now's a good time to buy if new. But used market is ideal when you dont have cash to throw at this hobby.
Osamede is offline
post #14 of 19 Old 06-30-2020, 12:47 AM - Thread Starter
Liked: 0
Imma be honest, I got the F12. I heard it's better than the Polks.
post #15 of 19 Old 06-30-2020, 08:07 AM
avtoronto's Avatar
Quoted: 211 Post(s)
Liked: 87
There is a PL200 BIC sub for sale in Brampton on FB Marketplace right now, asking $450.
post #16 of 19 Old 06-30-2020, 04:06 PM
Liked: 3152
FWIW, amazon.ca has the BIC PL-200 for ~$446, shipped, brand new.
post #17 of 19 Old 06-30-2020, 09:32 PM
avtoronto's Avatar
Quoted: 211 Post(s)
Liked: 87
Does anyone have experience with this sub?
post #18 of 19 Old 06-30-2020, 10:40 PM
Quoted: 100 Post(s)
Liked: 129
Read the budget sub-woofer thread for starters. Its a budget sub with budget performance. Its not anything close to what you have been looking at.
AVR: Yamaha TSR-7850, Fronts: DCM TP260, Center: DCM TP160C, Sub: Premier Acoustic PA-150
Deaf-Forever is offline
post #19 of 19 Old 07-01-2020, 05:56 AM
avtoronto's Avatar
Quoted: 211 Post(s)
Liked: 87
Will do. Thanks for the suggestion as I was unaware of that thread.
