Pioneer SW-8MK2 runs hot - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-27-2020, 11:21 AM - Thread Starter
Liked: 0
Unit is less than a year old and I am unable to keep my hand on the metal connection plate. Is this normal?
Richard Howarth is offline
post #2 of 3 Old 06-28-2020, 11:59 PM
phatfreeza's Avatar
Quoted: 157 Post(s)
Liked: 298
amps do get hot if you push em. Is this something you've recently noticed? Was it always cool to the touch and now its suddenly really hot? What is your gain set at for the subwoofer? What is it set at in the avr? Is it shutting down on you or making weird noises? If you're really worried, turn down the gain on the sub otherwise let it be and if it poops out then you have an excuse to subgrade
My HT: 7.3.4
Spoiler!
phatfreeza is online now
post #3 of 3 Old 06-30-2020, 12:06 PM
RayGuy's Avatar
Quoted: 3579 Post(s)
Liked: 3396
Sounds like you are asking that tiny sub to fill a large room with big bass. Not going to turn out well, I'm afraid ...
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
