Subwoofer SPL reading is too high to EQ to 75-80 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By head_unit
post #1 of 4 Old 06-28-2020, 08:23 PM - Thread Starter
Liked: 0
Question Subwoofer SPL reading is too high to EQ to 75-80
Hi there,
I just synched up my four subs using the delays in MiniDSP.
Now my issue is EQ. My SPL readings fluctuate above the 75-80 range. This makes it impossible to EQ.
Any ideas what I should do to calibrate this? Did I miss anything? I am following the suggestions from the Hour and a half youtube video, but those have SPL readings that already seem to be in the range for EQ.
I attached my calibrated subwoofer reading.
I am running four Fathom IWSv2-SYS-213 in case that helps with what calibration I should use for EQ.
I am running a 4x10HD MiniDSP with the REW.
Prior to adding delays to the subs, I placed the mic at the MLP and played pink noise on each sub. Each seemed to fall in the 75-80 range. And when combined, they appear to be at 80. Yet the measurement sweep is way above that.
Appreciate the help! Sorry for being totally new to all of this.
Name:	Sub aligned.jpg
yanivfromca is offline
post #2 of 4 Old 06-29-2020, 12:16 AM
head_unit's Avatar
Quoted: 783 Post(s)
Liked: 421
I have not run that kind of setup. I did recently do a first pass with an SVS SB-3000 and Audyssey; Audyssey said the sub gain should be in whatever range. When I ran calibration, sub was too hot, had to turn it down.
--> I'm thinking you should turn down all the sub gains a chunk and try again.
yanivfromca likes this.
head_unit is offline
post #3 of 4 Old 06-29-2020, 12:19 AM
head_unit's Avatar
Quoted: 783 Post(s)
Liked: 421
Oh if that doesn't do it, it would be interesting to see:
- Individual sweep of each sub
- Combined sweep
Four subs come to think of it would equate to I *think* (it's late!) +12 dB of gain if all in phase. So it's not surprising you're running too hot.
post #4 of 4 Old 06-29-2020, 10:22 AM - Thread Starter
Liked: 0
- Combined sweep
Thanks for the help. Sounds like I should do the following:
Mic in MLP
Front Panel for Subwoofers: Lvl = Reference, LP Filter = 12db (or should this be off?), LP Freq (130 which is max), e.l.f Trim = 0, Phase = 0, Polarity = 0, Master Volume (Currently at 0) = Adjust below 0 to get a lower SPL reading
Try to hit slightly below 75 for each subwoofer. And a combined 75 reading (before adding delays).
Add delays and run a sweep to see if still hot. Adjust and start over if needed.
On an unrelated note, once that is done, and before I run Audyssey, do I need to lower the crossover down to 80hz from the 250 for all that is used for the REW setup? Or does Audyssey do that automatically?
Thanks! Will have an update only thursday.
rew eq , spl , subwoofer eq
