how to connect two subs to one receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-06-2004, 01:51 PM - Thread Starter
krabapple's Avatar
Quoted: 485 Post(s)
Liked: 469
I've got a an AVR that has a single 'sub' output, but I need to connect it two powered
subwoofers. How can I do this (using line-level conneciton, not speaker-level)? They don't have to be 'stereo' -- in fact I will probably stack them on top of each other. Can I just 'split' the signal using an Rat Shack mono-to-stereo adapter cable and run one line to each sub?
krabapple is offline
post #2 of 12 Old 01-06-2004, 01:56 PM
Vlad_Dracule's Avatar
Splitting them would likely be the best way to do it.
Also I dont believe there would be much point to having a left and right (i.e. stereo) subwoofer setup. Most of the noise a sub outputs is too low of a frequency to be able to detect where it is coming from.
Vlad_Dracule is offline
post #3 of 12 Old 01-06-2004, 05:28 PM
Ian Fleet's Avatar
My sub has a line level in and out, so you could daisy-chain it with two subs.
I made a "Y" splitter once with coax cable and connectors. That was a five minute job.
Ian Fleet is offline
post #4 of 12 Old 01-06-2004, 06:12 PM
Burtgtp1973's Avatar
PLEASE someone correct me if iam wrong ... as iam sure someone will ,
the "professional " sales person at my local HT shop , told me that 2 subwoofers cancel each other out , any truth to this , or is he uninformed as iam ... ?
Hitachi 65" HD Widescreen
Denon AVR3801
Klipsch RF-35
Klipsch RC-35
Klipsch RS-35
SVS 20-39 PCi
Burtgtp1973 is offline
post #5 of 12 Old 01-06-2004, 06:40 PM
SledBC's Avatar
he's a ******, if you double the power and cone area you can expect to add 6db, at least thats what I know from car audio.....
BTW i have 2, yes....2 subs in my truck stereo and it sounds just fine :)
PS: This is what part of the alphabet would look like if Q and R were missing.
SledBC is offline
post #6 of 12 Old 01-06-2004, 09:05 PM
TMaxxTim's Avatar
I have 2 subs, I use a splitter, no loss in power or distortion or anything...sounds just like there are 2 ports in the back for it.
TMaxxTim is offline
post #7 of 12 Old 01-07-2004, 01:41 AM
tantalus's Avatar
AFAIK the two subs will have at least some canceling effect on each other. That is why an asymmetrical placement is recommended for a multiple sub set-up. This is not to say you won't get much more headroom with two subs; it just probably will not be fully twice the output of one sub alone. And, yes, a simple radioshack gold splitter is the way to go.
tantalus is offline
post #8 of 12 Old 01-07-2004, 03:20 AM
DrSpike69's Avatar
Stacking them or placing them next to each other will gain you a bit more head room. Asymmetrical placement will not gain as much but will gain some. All of these are good options for multiple subs. Like always play around with placement to get the most out of them for your room. But yes in some placements they can end up canceling out certain frequencies. But that can always be tamed by proper placement. :) Adding a second sub will not double the SPL however. But it will give quite a good gain.
~Dr. Spike
DrSpike69 is offline
post #9 of 12 Old 01-07-2004, 12:55 PM - Thread Starter
krabapple's Avatar
Quoted: 485 Post(s)
Liked: 469
Doesn't the line level out only output the high-passed signal, rather than the whole shebang? That's the case for my Velodyne F1000, I'm pretty sure. I used to run it into the poweramp-in jacks of an old pre- home theater receiver, in the days before there was onboard bass management (the recevier's preamp out was run to the line in of the sub)
post #10 of 12 Old 01-07-2004, 05:36 PM
GreatBop's Avatar
That is why there is a phase switch at the back of your subwoofer. that saves it from cancelling each other out.
GreatBop is offline
post #11 of 12 Old 01-07-2004, 05:49 PM
JRace's Avatar
Some are some arn't....depends on the sub.
JRace is offline
post #12 of 12 Old 01-07-2004, 05:50 PM
JRace's Avatar
That helps when the subs are in different locations.
Changing the phase when the subs are stacked could cause cancellation.
JRace is offline
Closed Thread Subwoofers, Bass, and Transducers
