Installing Different Size Amp in Sub Box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-09-2004, 11:00 PM - Thread Starter
TMaxxTim's Avatar
I have a JBL PB12 Subwoofer that nees a new amp. What would I need to do to the box since the new amp isn't as tall as the old one, it is wider though which shouldn't be a problem to cut out. I know I can't just leave it but I'm NO audio expert, what's the best way to modify the Sub Box so I can put the new Amp into it? The one I have now is about 13 inches tall and the one from partsexpress.com is 9" Tall it says. Thanks for any help
Tim
TMaxxTim is offline
Closed Thread Subwoofers, Bass, and Transducers
